Old 10-15-2011, 08:36 AM   #1366
dawgmeat's Avatar
Originally Posted by mattwoodcraft View Post
i see serpent have released alloy front and rear hubs these will be on my shopping list for sure
http://www.serpent.com/product/401422/
http://www.serpent.com/product/401423/ NO PIC 2 Degree
http://www.serpent.com/product/401424/ NO PIC 4 Degree
http://www.serpent.com/product/401425/ NO PIC 6 Degree
dawgmeat is offline   Reply With Quote
Old 10-15-2011, 09:10 AM   #1367
JayBee's Avatar
Trader Rating: 31 (100%+)
Nice!!!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-15-2011, 12:10 PM   #1368
Hi,
Is there any UK drivers on here with a S411 ? which chassis do I need, 2.25 or 2.0mm. I heard the 2.5mm is a little stiff for the UK tracks ?
Also which top deck ?
Thanks.
S.A.W is offline   Reply With Quote
Old 10-15-2011, 03:16 PM   #1369
Originally Posted by S.A.W View Post
Hi,
Thanks.
If you back through the pages most guys seem to be running a 2.25 deck for the british outdoor tracks. If you jump on the serpent website there are some setup sheets that will give you a good idea as to what they are running...
Deepsouth is offline   Reply With Quote
Old 10-15-2011, 03:32 PM   #1370
dawgmeat's Avatar
Originally Posted by JayBee View Post
Nice!!!!
Pic
Old 10-15-2011, 06:35 PM   #1371
Proably a more important release is in the new fwd car. It looks to have a better steering rack with adjustable ackerman. I am keen to get that part and see if it fits...
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-15-2011, 08:24 PM   #1372
The Teacher's Avatar
Trader Rating: 47 (100%+)
I hope they make the 2 and 6 degree castor blocks in their composite material.....the 4 deg blocks that come with the kit are very strong don't see the need for alloy blocks...
The Teacher is offline   Reply With Quote
Old 10-16-2011, 03:45 AM   #1373
RC MARKET's Avatar
coming
RC MARKET is offline   Reply With Quote
Old 10-16-2011, 04:27 AM   #1374
Yeah I Am keen for thebsame thing... Alloy is something that gets bent and stays bent... Its not to bad for rear uprights thoughn
Powered by Falco
Old 10-16-2011, 04:27 AM   #1375
Pattojnr's Avatar
Trader Rating: 19 (100%+)
there are options coming. different plates. just have to wait.....
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-16-2011, 11:17 AM   #1376
Originally Posted by RC MARKET View Post
S411 New Option Parts Coming soon
DRIVESHAFT-SET CVD ALU/STEEL (2)
DRIVESHAFT CVD ALU (2)
BELT TENSIONER SET
BATTERY MOUNT CARBON F/R
Belt tensioner?? My top deck has no hole
xtaiji is offline   Reply With Quote
Old 10-16-2011, 11:35 AM   #1377
BELT TENSIONER SET
Any ideas when the delrin spool outdrive is available? Part number 401428.
valtsu23 is offline   Reply With Quote
Old 10-16-2011, 12:41 PM   #1378
I was under the impression that they are shipping now... If not soon as some team drivers have been using them.
Powered by Falco
Old 10-16-2011, 01:18 PM   #1379
Does the Xenon TC VSS spurgear fit the S411? anyone tried it?
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 10-16-2011, 03:48 PM   #1380
mattwoodcraft's Avatar
i also asked the same question from rcmarket, the best spurs if your running stock and they have all the sizes from 60-90 48p are the RW spur gears they are not off set like the xray ones and there is plenty of room for meshing and not running close to the belt i have been useining these and they are great RW spur gears
mattwoodcraft is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
