Like Tree13Likes
Old 10-11-2011, 06:56 AM   #1351
I assume is either uneven tightness on the screws or being too gentle as the screws hasn't fully tighten, or the large black o-ring hasn't seat correctly.
Just my 2 cents, hope this help.
Originally Posted by silvalis View Post
I actually just rebuilt it to check it, as I had it sitting around for 3 weeks and noticed that the rear belt was completely lubed up (and the insides almost dry).
I suspect it was coming out through both, as previously i noticed the teeth completely lubed up and earlier i found the plate where the screw heads are lubed as well.
Anyway it's been 24 hrs and no signs of leaking, so maybe I got lucky this time.
I'll still get some green slime anyway I guess.
DanDan is offline   Reply With Quote
Old 10-11-2011, 12:28 PM   #1352
RC MARKET's Avatar
S411 New Option Parts Coming soon
DRIVESHAFT-SET CVD ALU/STEEL (2)
DRIVESHAFT CVD ALU (2)
BELT TENSIONER SET
BATTERY MOUNT CARBON F/R
RC MARKET is offline   Reply With Quote
Old 10-13-2011, 09:33 AM   #1353
t4m1y4niac's Avatar
What is the internal drive ratio serpent s411?
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 10-13-2011, 09:53 AM   #1354
StevenOlsen's Avatar
2.0 its 19/38 :-)
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 10-13-2011, 10:26 AM   #1355
YR4Dude's Avatar
Trader Rating: 44 (100%+)
My experience with Serpent gear diffs is this:
  • Don't over fill but also don't under fill.
  • Don't over tighten and don't under tighten.
  • When tightening, tighten the screws evenly to prevent the o-ring from popping out.
Do it with the same care as you would when building your shocks and you'll have perfect leak proof diffs just like you would have perfect leak proof shocks.
YR4Dude is offline   Reply With Quote
Old 10-13-2011, 11:06 AM   #1356
dawgmeat's Avatar
Getting my kit in 2 weeks, where can I get the Ver 2 kit in the states?
dawgmeat is offline   Reply With Quote
Old 10-13-2011, 11:25 AM   #1357
RC MARKET's Avatar
19/38 = 2.0
Old 10-13-2011, 11:26 AM   #1358
RC MARKET's Avatar
rcmarket.com.hk
Old 10-13-2011, 12:27 PM   #1359
Akhor's Avatar
Originally Posted by RC MARKET View Post
rcmarket.com.hk
This is not the states...
I think stormer carries them.
--Blaine--
VBC D07, VBC D08
www.carcar.ca
Akhor is offline   Reply With Quote
Old 10-13-2011, 02:04 PM   #1360
mingnon's Avatar
Default motor mount
thanks everyone for the posts, as a newbie with the s411 they allreally help.
just a quick question regarding the motor mount. I'm running 21.5 blinky class, and to get the car geared down to a suitable level it needs to be running 64tooth 48dp spur gear. To change the pinion it requires removal of the chassis plate and spur gear holder/mounts to get at motor screws.
Is there a motor mount available that is vertical not horizontal (similar to sakura zero) if not has anyone got any ideas?
any help appreciated
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 10-13-2011, 07:31 PM   #1361
mattwoodcraft's Avatar
i run stock to with thr RW spur gears if you you mesh the gear with the one screw you can then just undo 3 screws on the 2 peice mount and then tighten up the other motor mount screw no need to remove the top deck. the RW spurs have extra holes in them so normally if you have a ball end driver you can do this also with out removing parts the spurs i use range from 60-66 been the largest for stock where i run..
serpent do not release a mpunt vertically the have a optional 1 peice mount
mattwoodcraft is offline   Reply With Quote
Old 10-14-2011, 02:28 PM   #1362
mingnon's Avatar
thanks matt, will give it a go, maybe its just me and having fat fingers, thanks for the advice
Old 10-14-2011, 08:08 PM   #1363
crabboy's Avatar
Trader Rating: 58 (98%+)
Just finished building my V2 kit and it went great, quite a plain looking car compared to Tamiya's and HB's. Hopefully will be giving it a run tomorrow.
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 10-14-2011, 08:17 PM   #1364
i quiet like the look of the alloy colours serpent use its not bright and out there rather stealth looking
i think you will enjoy the drive such a great TC to drive im looking forward to tomorrow the weather is good track temps up will make for a great day of racing
Old 10-15-2011, 05:02 AM   #1365
i see serpent have released alloy front and rear hubs these will be on my shopping list for sure
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
