Serpent S411
#1291
Hi Guys,
I have seen this car perform a couple of times now and am thinking of getting one to run, without going through the pages of info on this thread can someone please answer a couple of questions for me.
Is there a V2 kit available with a 2.25mm chassis or do you need to buy it seperatly,
and there any other parts needed with the kit to get it to comp spec, i aways run on asphalt never carpet.
Any help would be great.
Rhys
Rhys
#1292
gear gear ratio
hi guy, i just got my s411. any suggestion for pinion with 84t - 48p spur? i'm running 11.5T with boost.
please advice
please advice
#1294
Hi Guys,
Rhys
Rhys
#1295
Hi Guys,
Rhys
Rhys
My suggestion would be to get a set of Medium and Hard arms, with Hard C hubs, knuckles and uprights. A spare gear diff will be good too.
The V2 kit is quite good, but only comes with the 2.5mm chassis. If there is someone willing to do a swap when you buy a kit, do it... 2.25mm will be mint.
The car is good. No dramas, no fuss, always on the ball.
#1298
Wel i have tested my S411 and i must say, it has way more
steering then my xray T3!!
The standard arms work good on low grip tracks but my car was a little bit
oversteered.
This is a really awesome car and i have the feeling i can even get more perfomance out of the S411!!
What is the differance between the v1 kit and v2 kit?
oversteered.
#1300
#1301
#1303
Hey guys,
I'm still deciding but i'm just about sold on the serpent, gotta love the underdog
What other differences are there betweent he V1 and V2 kits other than the 2.25mm chassis?
I've searched and cant find anything ( althought that doesnt mean much just as the wife about my searching skill lol )
#1305
There are many differances in the new batch of kits. The chassis is different to the standard one (narrower again, 2.25mm) and car has medium plastics throughout. There are a few other small bits and pieces also, the driveshafts have serpent 46mm etched into them now. Really like this car, but never have I had so many issues building a car with faulty parts!
I had a few shock balls and arm balls that needed to be replaced as the pin would not go through. This was annoying but an easy replacement. my other 2 issues on the other hand
My kit has come with 1 different size shock body (obviously from a 1/8) so i cant put any shocks on the car and will have to buy a replacement, another delay. The other issue I have is that the rear of the car has a big bind in the drivetrain. Tried different belts, essentric's, whole diff and bearing and it still exists. The belt has a bigh/low spot no matter what i try, the essentric's are visibly wobbling in the bulkheads as the drivetrain rotates. Im going to try and fit a prototype chassis that has been sent to me and see if that fixes the issue, but im not liking my chances.
Hope Serpent get the rest of the kits right as there are way too many things wrong with mine. Not the best first impression thats for sure!
