Old 09-23-2011, 05:11 AM   #1216
I have had no problems.with CVD pins falling out however some have moved a little between rebuilds. I haven't bothered with "flat spotting" my pins but the trick I use is a touch of loctite on the grub screw then build the cvd "dry". Then lube with your prefernce of grease. When you rebuild simply spray out with motor spray and regrease without removing the grub screw (unless the pin has moved out of center). I find this works well.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-23-2011, 05:32 AM   #1217
Pattojnr's Avatar
Trader Rating: 19 (100%+)
never had issues, as i have stated maybe here or else where, i use Top racing slotted pins. at $4 or so for 8 pins, will do a full rebuild later as well. red loctite, just a little on the screw. and never will you have an issue.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-23-2011, 06:43 AM   #1218
Jinjiro7's Avatar
Originally Posted by chicky03 View Post
I'll try and have one today or tomorrow. John Kobleks car was good at the Gate Vegas warmup. He said it need more steering but its a really good starting point.
Clockwork racing has them. They are in Winnipeg. http://clockworkracingengines.com/co...90mm-ser400005
Nice to see a place in Canada where we can buy Serpent. I hope they sell parts! I want to try out the Hard arms and Delrin outdrives.
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 09-23-2011, 01:13 PM   #1219
Will61's Avatar
Originally Posted by BCDK View Post
Hi.
Try this carpet set up. It works great for us. Tried it on two dífferent tracks. On both tracks the fastest car in both one round as well as in longruns.
Thank you very much, i will give definitely try this out.
Cheers
Will M.
Will61 is offline   Reply With Quote
Old 09-23-2011, 05:19 PM   #1220
mattwoodcraft's Avatar
it only seems to bne one but i hope now problem solved i now have pins with flat spots in them, i was using red lcktight with grease no grease still come out but i now feel confident it will stay in
mattwoodcraft is offline   Reply With Quote
Old 09-24-2011, 09:59 PM   #1221
Had a pretty good result from the car this weekend at the FEMCA ISTC meet in Sydney. Qualified 5th but had the car going around really nicely missing out on being the fastest aussie in the last round of Qualy by only 4 tenths and only a few seconds behind Volker. Finals got rained out so no chance to move up but I must say I was quite happy being able to match the pace of some of Australias fastest EP guys inc Simon, Ryan, Ari and Tim. I attached the setup which I think is a slight compromise due to the lack of 6 deg c-hubs. If I had the 6 deg hubs (med or hard) I would have stood the front shocks up one hole and maintained steering with slightly more front end response.
Powered by Falco
Old 09-25-2011, 04:47 AM   #1222
RC MARKET's Avatar
good !
RC MARKET is offline   Reply With Quote
Old 09-25-2011, 05:14 AM   #1223
Pattojnr's Avatar
Well done.
what is with all the extra weight added to the car ? mine balances perfect with out any, and what were the rules for weight ? is it not the new lowered weight rule ? Cheers.
Serpent - Walter RC
Old 09-25-2011, 05:32 AM   #1224
Originally Posted by Pattojnr View Post
Well done.
IFMAR rules which are currently 1450g. I have recently started reducing the weight of the car and running LW bodies to further lower CG. Its got a few more screws left to go but when its done I will be able to add weight to adjust f/r bias for different tyres and account for the weight of a front gear diff at any time without effecting setup for the new 1380g rule. I think I forgot to add 10g next to motor mount but apart from that it has two full S411 weight kits on it (94g total)! I gotta say it looks funny to see 2 20g weights and 2 12g weights stacked up the middle of the car. I'll try to remember to take a pic tomorrow as its quite an unusual sight.
Powered by Falco
Old 09-25-2011, 08:18 AM   #1225
Trader Rating: 15 (100%+)
Pattojnr, how come you have started running the 1 cell 3.5? how different is the power delivery to the normal v3?
Cheers,
Alex.
al3x is offline   Reply With Quote
Old 09-25-2011, 09:12 AM   #1226
Pattojnr's Avatar
Cheers,
Alex.
the motor itself is much lighter. and i feel the power is better out of corners.
the weight was the main reason. still running 2S though. heat is not an issue.
Serpent - Walter RC
Old 09-25-2011, 04:19 PM   #1227
venom54's Avatar
Default GREAT RESULT
Well done with the car and result.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 09-25-2011, 06:03 PM   #1228
are you using a tweak station when you put all the weights ? how do you know where to put the weights for the best result ?
Old 09-25-2011, 10:22 PM   #1229
Benzaah's Avatar
Trader Rating: 21 (96%+)
Your brothers car was looking pretty good in stock as well. Did the set up vary much from yours to his? More consistency and he would have made the A as well. As usual the stock driving is so close and making the A takes a lot of effort.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 09-26-2011, 02:42 AM   #1230
azz187's Avatar
Hey Dragonfire.
I'm gonna give your setup a crack at my local track, are you running white serpent springs front and rear? Can't read the print sorry!
Also did the car have lots of grip with this setup? & do you think the setup would be ok with the standard plastic wishbones, hubs etc and 2.5mm chassis?
Cheers...
azz187 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
