Old 09-21-2011, 05:50 PM   #1201
Jinjiro7's Avatar
I hope that the prototype universals aren't weak don't fall apart like the Spec-R ones...
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 09-21-2011, 06:31 PM   #1202
corallyman's Avatar
Trader Rating: 97 (100%+)
Originally Posted by Dragonfire View Post
Yeah thats what I saw too... You have to be careful with the editable setup sheet because it dosen't display the.number properly when you use decimals like "1.5". I wish Serpent or someone else who is.handy with writing pdf's could make a better version that shows this properly and is smaller in size when saved (so we can post setups here where most ppl look).
I emailed Serpent a week or so ago, I got a response within hours, and was told that the problem will be resolved shortly. Vacation I think
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 09-21-2011, 07:26 PM   #1203
Send a message via ICQ to #iZzy Send a message via MSN to #iZzy Send a message via Yahoo to #iZzy
Originally Posted by mattwoodcraft View Post
the double jointed CVD do they use some sought of retainer to secure the pin and stop it form backing out, my front CVDs always work the pin out one side more than the other. anyone else experiance the same problem ?
double-joint prototypes are using shrinking hose - don't know if that will be the final version, but it works really good with that method.
Me, marc and some other team members "had" the same problem with the outworking pin, too. Maybe you can use here shrinking hose ? ... But we all (all team members) are checking our CVDs after every run, it's very very important to take care on them that there is no sand etc. because this results in Vibrations (a lot more in front as in rear). MAYBE you can use a small drop of threadlock, too. But we tighten the screw with maximum power, without threadlock :> I had no outworking pins more in the last 10 runs ...
no, serpent is REALLY precise and commendable if they're testing new products. no new product will be produce if they're not tested from any team member
Example double-joints: Marc run the prototypes on the german nationals (and 1-2 other team drivers, too). After the nationals they removed there "used" double-joints and give them to our serpent team-manager for analysis of weak points.
Team Magic Europe - HRC-Distribution - GM-Racing - LMI - MR33 - Tonisport
#iZzy is offline   Reply With Quote
Old 09-21-2011, 08:35 PM   #1204
rcscoot2539's Avatar
I'm selling my S411 for money reasons only, the car is great.PM me if anyone interested, It comes with a lot of spares
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 09-22-2011, 03:10 AM   #1205
mattwoodcraft's Avatar
great thanks i have been using a small amount of lock tight on the pins and checking after every run now. after every 5 runs im pulling them apart to clean and relube to
mattwoodcraft is offline   Reply With Quote
Old 09-22-2011, 03:51 AM   #1206
JayBee's Avatar
Trader Rating: 31 (100%+)
Marc's car looked excellent and super nimble in that small 'S' and 'hard-left' at the end of the straight. Asphalt season is just about over for us here, and its carpet running time now. Don't know if I'll be out much for it but it would be nice to get some more feedback of the S411 rug capabilities. Gonna eventually have 2 cars.....just gotta find a way to stop working so much
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-22-2011, 07:27 AM   #1207
Jinjiro7's Avatar
My front-end CVD pins use to back out every 2 runs when I first got the kit. So I just dremeled a flat spot on the pin where it meets the grub screw and no more issues. But I do this as standard for most of my cars CVDs when I first get them.
Ryan
www.drcrc.ca
www.fastcats.ca
Old 09-22-2011, 08:31 AM   #1208
I read the previous posts and I would have written exactly the same, as you just wrote. Flat spot the pin, use a small amount of threadlock, and you will never have any problem with the pins again.
I used the same on the previous cars - Tamiya 416X and 417. No problems at all.
BCDK is offline   Reply With Quote
Old 09-22-2011, 10:23 AM   #1209
Will61's Avatar
Hello, I'm looking for indoor carpet setup sheets to give me an idea of where to start off. I'm not that good so i need something easy to drive and gets me around the track without beign the Duechbag on the carpet Less Twitchy the better. If anyone has a pdf they would like to share that would be fantastic.
I looked on serpent site and i think all of those setups are outdoor.
Thank You
Will M.
Will61 is offline   Reply With Quote
Old 09-22-2011, 11:25 AM   #1210
Johnny Wishbone's Avatar
Thank You
Will M.
Hey Will,
If you can't get a setup, use a 416 or 417 for a starting base, it will be close and then adjust.
Who in Alberta is selling the cars as I see quite a few with the car now, or did you have to order it in?
GL
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 09-22-2011, 11:40 AM   #1211
chicky03's Avatar
Send a message via AIM to chicky03
Thank You
Will M.
I'll try and have one today or tomorrow. John Kobleks car was good at the Gate Vegas warmup. He said it need more steering but its a really good starting point.
Originally Posted by Johnny Wishbone View Post
Hey Will,
GL
Clockwork racing has them. They are in Winnipeg. http://clockworkracingengines.com/co...90mm-ser400005
Serpent America, Picco, Blitz Bodies, Team Titan, Desoto Racing, LRP, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa.
chicky03 is offline   Reply With Quote
Old 09-22-2011, 11:46 AM   #1212
Thanks Paul.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 09-22-2011, 01:54 PM   #1213
RC MARKET's Avatar
is new design more stronger !!
RC MARKET is offline   Reply With Quote
Old 09-22-2011, 04:14 PM   #1214
thanks ryan thats a great idea i will do this to my cvd pins today
Old 09-23-2011, 03:13 AM   #1215
Thank You
Will M.
Hi.
Try this carpet set up. It works great for us. Tried it on two dífferent tracks. On both tracks the fastest car in both one round as well as in longruns.
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
