Like Tree7Likes
Old 09-09-2011, 05:43 AM   #1096
mattwoodcraft's Avatar
Originally Posted by Pattojnr View Post
i see some guys are having problems. it is really dependant of what class or motor you are running. i am using the serpent 84T spur and a 19-20 T pinion, as i am running 3.5T Mod. everything is just easy. 2 motor screws can be accessed easily, and motor is out inseconds with out removing anything else.
i also run speed passion, so a motor change doesnt incurr any soldering either.
i just love how everything is. i wouldnt have it any other way.
but stock....... different story. remove spur, and top deck, ouch........
yep i am heraing you on this i to love the SP no need for soldering fast and easy changes
after the nats i will put my 3.5 back in and abuse my 411
mattwoodcraft is offline   Reply With Quote
Old 09-09-2011, 08:52 AM   #1097
What fdr you run on that 3.5t ??????
bertrandsv87 is offline   Reply With Quote
Old 09-09-2011, 08:56 AM   #1098
Smile
Forgot to ask about timing advance for your 3.5t ??? What is the motor temp after 6minutes ??? Does the s411 handle the power well ???
Old 09-09-2011, 09:13 AM   #1099
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i posted a setup sheet the other day, or it can be found here http://www.serpent.com/product/400005/setups/
Aussie setup. my FDR and everything on the car is Xceed oil in cst and Serpent springs. Handel the power ? absolutely. Mod runs 5 mins. motor temp is around 78C. i have just arrived the MMM 3.5T that uses the +10 timing board. so i will have to play again to keep temps down.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-09-2011, 09:24 AM   #1100
Pattojnr's Avatar
Originally Posted by venom54 View Post
RE XRAY spurs come as low as 64 tooth and with the BIG hole for motor removal, no need to take the top deck off!
Common sizes available.
Cheers
Ren
Ren, how you doing ? these spurs work a treat, and also the Spec R blades for the yokomo i got from you. just waiting on serpent to release the Derlin adaptors for the out drives, and ill be switching to them. Serpent now have spurs also, dependant of the chassis, if using 2 or 2.25, i wouldnt go for the 84T, go for something a little smaller. the 84T is nearly flush with the bottom of the chassis. the serpent spurs are very wide also.
just while i comment on those items, guys using the std Kit arms, do remove them and check them for straightness. the std arms are soft. and they flex, if you havent switched already to H or M arms, just pull them off and be checking them for straightness. i will be sure the front ones will be bent. making the cars caster variable, and inconsistant. your looking at the front of the front arm, from teh shock position your using to the C Hub pins. and its only the front part of the arms, so really they are buckled then as well. Droop and caster are effected. also middle pullies, guys running MOD, hold your spurs tight, and move each diff a little, if the pullies move before tryign to turn the spur, then your pins on the middle shaft are just about to turn inside your 19T pullies.
Serpent - Walter RC
Old 09-09-2011, 09:26 AM   #1101
172F ouch !!! 8.84fdr is pretty high though, even if you run no esc timing ... No ceramic bearings, I guess. The S411 is pretty efficient !
Old 09-09-2011, 11:04 AM   #1102
RC MARKET's Avatar
New Shock Spring , Weight & Titanium Pin released !
RC MARKET is offline   Reply With Quote
Old 09-09-2011, 06:00 PM   #1103
The Teacher's Avatar
Trader Rating: 48 (100%+)
RC MARKET, any release date on the 6 deg caster blocks?
Also, has anybody tried the low friction belts what are your thoughts?
The Teacher is offline   Reply With Quote
Old 09-09-2011, 07:43 PM   #1104
venom54's Avatar
Default low friction belts
We can assist with low frictioN belts currently both in stock.
cheers Heath
C/o RAB Hobbies
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 09-09-2011, 09:26 PM   #1105
Pattojnr's Avatar
well seen the derlin adaptors on Red RC. they are for use with the spool. also the new springs are coming.
Serpent - Walter RC
Old 09-10-2011, 05:05 AM   #1106
Cheers
Ren
The price of them is just ludicrous... Not sure what serpent have yet but the kit 84t is quite good.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-10-2011, 05:44 AM   #1107
i have seen this car at first hand in performance and handling and patto's 411 was on fire truly the best set up car i have seen running the 3.5 it was on rails
Old 09-10-2011, 05:57 AM   #1108
Pattojnr's Avatar
THanks Matt. it has come by trying lots of things. i have been hammered since i got the car by most, askign questions, and asking for setup. early on i didnt hand out a setup, cause the car was new to me, and still had lots to try. but Sunday did see a huge improvment, so i thaught it was a good setup to start to share around. i hope the MMM 3.5T can give me a little more, but will have to start again with gearing and settings. nows the time to be trying before the Nats arrive.
Serpent - Walter RC
Old 09-10-2011, 06:56 AM   #1109
Akhor's Avatar
If you put hard or medium a-arms on your vehicle how does it effect handling?
--Blaine--
VBC D07, VBC D08
www.carcar.ca
Akhor is offline   Reply With Quote
Old 09-10-2011, 07:12 AM   #1110
Pattojnr's Avatar
it can give you a better feel for one end of the car. use it as a tuning aid. the softer arm will generate a little more grip than the harder arm . for me, i had a decent setup, but when the M and H plastics were available i tried all H first. i lost steering, so i put on M on the front, and i found what i was after, the added bit of steering i was looking for. when i say i needed steering, due to the nature of the track im running on, i have no more than 80-85 D/R on my radio. i do not wish to just turn it up, i feel the car looses corner speed and it can unsettle the rear end. so i just needed to find that little bit extra steering, which i found with the setup.
Serpent - Walter RC
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
