Old 09-08-2011, 04:36 AM   #1081
mattwoodcraft's Avatar
Originally Posted by mwoods View Post
Has anyone done a back to back with the 2.50 mm and the 2 mm chassis ?
If so wat one do u think is better?
yep i have i prefer the 2mm chassi for me it made the car feel more conistant.
the rar end wasnt nearly as taily when i drove both of them
mattwoodcraft is offline   Reply With Quote
Old 09-08-2011, 04:46 AM   #1082
For those who don't kind a bit of.wrk you may be jnterested to know that the exceed light weight internals rorba 733 diff can be made to fit into a 411 diff. I forgot to weigh it before I began but with light weight internals and 1200 oil the diff weighs in at 22g. A new diff in the packet plus the extra shaft and 2 bevels (without oil) weighs in at 32g. It takes a bit of work to the out drives and mounting the main diff housing side main gear but when you get it together it feels better than the steel gears. I don't think the gears are a perfect fit so I think I need to do.some.more work on shimming but it does.go together.
Keep in mind that this gearset is not cheap for a few.plastic parts and alloy shafts.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-08-2011, 05:05 AM   #1083
Many Thanks Dragon,
Isn't the 733 Big bevel gears are using pin instead of Hex shape to lock on the outdrive?
Do you have the part no?
DanDan is offline   Reply With Quote
Old 09-08-2011, 06:10 AM   #1084
StevenOlsen's Avatar
Originally Posted by DanDan View Post
Many Thanks Dragon,
link to the LW gears
http://www.xceedrc.com/product/108248
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 09-08-2011, 06:42 AM   #1085
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Many Thanks Dragon,
the 733 has the same setup. this is where the 411 diff came from.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-08-2011, 11:39 AM   #1086
G-rem's Avatar
Originally Posted by G-rem View Post
Hy everyone,
can someone tell me the length of the central drive shaft (middle shaft alu) that supports the center pullies, item #401366, please
Thanks a lot
G-rem
No one can help me?!!!
Please, it's very important.
Bye bye
G-rem
G-rem is offline   Reply With Quote
Old 09-08-2011, 01:31 PM   #1087
Yep thats what I was told too... The main gears are pin driven rather than hex/bolt. You have to cut down one of the pins a bit as well to fit it together...
Powered by Falco
Old 09-08-2011, 02:23 PM   #1088
cheers im running the 2mm now but i got the std one aswell , ill prob use the 2.5mm wen the indoor carpet meetings start next month..
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-08-2011, 05:59 PM   #1089
esham's Avatar
yes you can how ever when you need to tighten the back motor mount screw you will need to remove the motor mount once you have set the mesh and tighten the front the motor mount screw
Thanks for your respond matt as always For me some how it quit massive to change spur / pinion for EP compared with GP as i experienced with or probably my method itself is wrong and complicated I have to unscrew the upperdeck and motor mount in order to change those..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- shu@esham
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-08-2011, 07:36 PM   #1090
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by esham View Post
Thanks for your respond matt as always For me some how its quite massive to change spur / pinion for EP; probably my method itself is wrong and complicated I have to unscrew the upperdeck and motor mount in order to change those..
YEP....but I'm used to it now. Still a PITA though
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-08-2011, 07:44 PM   #1091
Lol my last car was a losi jrxs-r. Chnaging the spur or pinion was about the same amount of effort... After that tuis setuo really sucks...
Powered by Falco
Old 09-09-2011, 02:59 AM   #1092
Pattojnr's Avatar
Default setting pinion mesh.
i see some guys are having problems. it is really dependant of what class or motor you are running. i am using the serpent 84T spur and a 19-20 T pinion, as i am running 3.5T Mod. everything is just easy. 2 motor screws can be accessed easily, and motor is out inseconds with out removing anything else.
i also run speed passion, so a motor change doesnt incurr any soldering either.
i just love how everything is. i wouldnt have it any other way.
but stock....... different story. remove spur, and top deck, ouch........
Serpent - Walter RC
Old 09-09-2011, 03:28 AM   #1093
G-rem's Avatar
can someone tell me the length of the central drive shaft (middle shaft alu) that supports the center pullies, item #401366, please.
WTF?!?
No one have had to dismont his central shaft yet? =)
Please, can you help me, it's just to know if that part is fittable in my own car.
G-rem
Old 09-09-2011, 03:40 AM   #1094
venom54's Avatar
Default STOCK PINION AND SPUR CHANGE
RE XRAY spurs come as low as 64 tooth and with the BIG hole for motor removal, no need to take the top deck off!
Common sizes available.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 09-09-2011, 04:41 AM   #1095
i now use the xray spurs to but you can also use the other spurs. i have been using a 70 spur i dont remove the top deck at all when i put my stock motor in just split the 2 peice mount a few more screws but can be done with very little effort if you dont have the xray spurs..
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
