Old 09-06-2011, 05:21 AM   #1066
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by mattwoodcraft View Post
i havce never understood why people feel the need to winge and talk rubbish behind anyones back, but if they have nothing better to do well mate you must be doing something rite maybe just jelous...
your car was rocking i look forward to seeing it run again soon and your set up..
r&d will get you every where
well it didnt help me much, i had been crook for most of the week, i pulled my 8th out, cause i didnt feel well. then that happened. i guess i didnt help the situation afterwards, i got a bit carried away, so myslef must appologise for that. althugh i was more excited than anything, after seeing the times. makes the effort worth while, even with out the added inspiration
Cheers, Matt.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-06-2011, 02:46 PM   #1067
Pattojnr's Avatar
for the life of me i can not get the pdf small enough to be readable to post on here. so i guess, just PM me your email if you wish to look it over, and ill send it. or if anyone knows how to shrink a PDF file Thanks.
Serpent - Walter RC
Old 09-06-2011, 04:09 PM   #1068
Pattojnr's Avatar
Ok Success. found a pdf shrinker to shrink to RC tech Size. haha
so here it is.
Serpent - Walter RC
Old 09-06-2011, 09:18 PM   #1069
Patto, a couple of questions
What is the hole size of serpent pistons?
the lower block spacing on the front, is it 0.5mm FF and 3.0mm RF block?
You also have a very large split in springs, 13lb to 19.5lb seems huge, have you tried closer spring rates?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-06-2011, 09:24 PM   #1070
esham's Avatar
Hi guys, is it possible to use Kawada spur with this kit? Currently i'm using speedmind spur
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- shu@esham
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-07-2011, 02:59 AM   #1071
Pattojnr's Avatar
firstly, i will measure the holes for you.
yes that is FF 0.5 and RF 3mm.
Springs i tried kit, i changed the setup quite a bit, and a couple of weekends ago i put the kit springs back on the rear. just made it too twitchy for me.
i have just arrived, soem HPI Silvers to try, possibly this weekend if i feel i may need to try them. different track this weekend, so what normally works up in perth, sometimes works in Bunbury. but the track is also in reverse this weekend. i dont think i have ever run the track in the opposite direction. i havent put a lap down wiht the 411 there yet also. so new ground allround. just a comparison by feel, the serpent white spring felt harder initially then the silver HPI but then got softer as it was compressed. so totally different progression springs. i will be trying them, as i said, i have a NEW base setup . so i will still be trying some things. but mainly now, i think it will be shock setups.
Serpent - Walter RC
Old 09-07-2011, 04:17 AM   #1072
mattwoodcraft's Avatar
yes you can how ever when you need to tighten the back motor mount screw you will need to remove the motor mount once you have set the mesh and tighten the front the motor mount screw
mattwoodcraft is offline   Reply With Quote
Old 09-07-2011, 05:19 AM   #1073
Thanks for your reply.
I have tested my car with 6 screws on top deck on Sunday. Still using my 2.5mm chassis. I don't feel that much different on cornering but just tiny little bit easier to drive as you can throw your car into the turns with higher speed.
I found there is a problem with unscrew top deck for the flex, the screw holes on the top deck are so close to the edge and easy to get crack. I got 1 light crash with another car, just 1 light crash, and now my front screw holes (closer to center 2 holes) are having some very fine cracked hair line, I think it will break after few more pack runs.
Originally Posted by Dragonfire View Post
I normally prefer to remove the single screw over the.motor mount as part of my base setup. That said I have run the far with no.screws over both the motor mount and layshft and have not stripped any spurs. Its rather funny when u remove all screws as the top deck can rock back and.forth over the bottom deck. Handling wise it is the same.as any car with too much flex, loads of.understeer.
DanDan is offline   Reply With Quote
Old 09-07-2011, 07:00 AM   #1074
Pattojnr's Avatar
piston holes seem to be either 0.9 or 1mm.
Serpent - Walter RC
Old 09-07-2011, 07:22 AM   #1075
Has anyone done a back to back with the 2.50 mm and the 2 mm chassis ?
If so wat one do u think is better?
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-07-2011, 11:06 AM   #1076
G-rem's Avatar
Hy everyone,
can someone tell me the length of the central drive shaft (middle shaft alu) that supports the center pullies, item #401366, please
Thanks a lot
G-rem
G-rem is offline   Reply With Quote
Old 09-07-2011, 05:32 PM   #1077
The Teacher's Avatar
Trader Rating: 47 (100%+)
Well I just got my kit and I've started the build. I must say Serpent has done a nice job on this kit, very high quality... I do have one question, is there a way to change ackerman on this car?
The Teacher is offline   Reply With Quote
Old 09-07-2011, 06:13 PM   #1078
Brad the 411 uses a flipped block for the rear of the front arms. With that in mind 3mm on a flipped block is.equal to 0mm on a normally orintated block.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-07-2011, 06:30 PM   #1079
Cheers Rocko, that clicked to me last night, same as Tammy.
Patto - Unlikely the holes would be sub 1.0. The old Serpent / Xray plastic shocks used 1.0 holes, so likely to be 1.0
The 4 hole piston sounds like something interesting to play with.
Old 09-07-2011, 08:08 PM   #1080
I just change mine from 2mm to 2.25. I build my car with 2mm chassis and just want to try the different with the 2.25. The 2mm have a bit more steering but not very stable at high speed. The 2.25 push at low speed corner but very stable especially on high speed S.... I guess depend on the track layout you run your car at.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
