Old 09-01-2011, 07:11 AM   #1021
wee
Default spring setup
dragonfire
so what do you think of the spring setup that i have been using on low
traction track?
well i have tried taking out 1 screw on top deck to have more flex, there
is too much oversteer ! same setup, tyre, spring ane etc...
our track here in mine particular area, after a raining day, you drive the car,
and loose stones and a layer of white dust on the kit. thats what i call
low loose track!
anyway pls adv.on my spring setup
tks
SERPENT S733 , S966 , S811 , S400 , S411 TE & S747 SOON.......
POWERED BY NOVAROSSI ( GP )
POWERED BY HOBBY WING V3, SPEED PASSION AND LRP (EP)
wee is offline   Reply With Quote
Old 09-01-2011, 08:20 AM   #1022
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by wee View Post
dragonfire
traction track?
low loose track!
tks
try kit orange front spring, and white rear, and 1.2 rear bar.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-01-2011, 01:31 PM   #1023
Jinjiro7's Avatar
I had the same issues as you when I used the kit setup. What really helped me was a wheelbase change by moving back the rear arms. On the rear, I used 5mm shims front and 1mm back.
Also used 0.5 shims instead of the 1mm on the rear suspension blocks.
But try the wheelbase change first.
Originally Posted by azz187 View Post
Does anyone have a solid setup they can post for med traction asphalt?
Ran the kit setup on the w/e and struggled to stop the car from spinning out on power through corners. The car is fast out of the box, but is hard to drive. (for my skill level at least)
I've tried heavier diff oil and longer wheel base to start with, any other suggestions?? Any help would be great...
Cheers
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 09-01-2011, 04:22 PM   #1024
Trader Rating: 23 (100%+)
I had that problem too. I switched to 2000 WT Mugen oil in the rear diff and Sorex tires and the car hooked up extremely well. The track had medium traction but the surface was somewhat cold (due to rainfall earlier on during the day). The other change I did was to decrease droop on the front and rear by 1 step from the stock setup.
madness is offline   Reply With Quote
Old 09-01-2011, 05:42 PM   #1025
mattwoodcraft's Avatar
you could try turning your steering EPA down so its not full lock i find that doing this also helps, you dont always need to run it at 100% depending on the track i have mine down at 80% and still has heaps of steering.
currently im running 4 hole pistons in the rear of my shocks with 40wt oil which is working very well
mattwoodcraft is offline   Reply With Quote
Old 09-02-2011, 01:17 AM   #1026
Wat pistons and oil u running in the front?
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-02-2011, 03:01 AM   #1027
3 hole pistons with 50wt in the front
Old 09-02-2011, 03:19 AM   #1028
Did u find it help the back end more stable coming on power
Old 09-02-2011, 03:36 AM   #1029
this is one of the reasons why i done it in the rear just have the car squat down while punching it out of the corners..
on most of my provious TC i have always done this.this way i just start putting differant oils in to see what it feels like.
the other thing i have not yet tried also is what others have done is have 4 beval gears in you diff this will also help i am still waiting on my other diff to turn up so i can have 2 diffs with differant settings
Old 09-02-2011, 06:38 AM   #1030
Im already using the 4 gears . Did u find the thicker oil help in the
Rear ?
Old 09-02-2011, 09:00 AM   #1031
I have no problem at all, the car sits like its glued to the track!
The main secret is a smooth triggerfinger .
And as Jamison said, use correct tires! There is no way you
can find a good setup with poor tires and a happy triggerfinger.
joachimG is offline   Reply With Quote
Old 09-02-2011, 09:45 AM   #1032
Rear ?
I prefer to deal with the oil instead of placing additional gears. Going to 2000 in the rear worked wonders for me and of course, the Sorex 32R tires made a huge impact. I have found that the rear stays more planted with the use of thicker oil. Don''t go to high because it can get your car to push.
Old 09-02-2011, 10:38 AM   #1033
+1. Happy trigger finger, guilty as charged right here. I am an aggessive driver, and when I swithced from running foam tires on carpet to rubber tire i had problems. You have to be smoother with rubber tire. what I do is give myself some negative throttle expo and it helps me when I yank on the trigger.
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 09-02-2011, 11:41 AM   #1034
at the moment ive only used old tires ill try a new set tomorrow to c if that helps . im a smooth driver anyway but the back end a bit more planted then it is now...
Old 09-02-2011, 03:54 PM   #1035
Questions??
im in the chicago il. area. does anyone know the parts availability in this area? this car looks great,would like to go that way.everybody here runs the xray t3:
S411LE#63,eryx 2.0,kyosho ultima sc,B44.1,futaba.the short list. Ricky Bobby body club,member #4
atmeearacing is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
