Old 08-29-2011, 09:20 AM   #1006
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by BCDK View Post
Hi.
To solve your problem, try 3 - 3,5 or even 4 mm shims on the rear upright links and lower the shims on the inside on the bulkhead. The link (turnbuckles) must be more angeled. It works on a 417, why not on a 411...
thanks for the info. something to look at. when i say im looking for a better balance, the car is very drivable, and it holds the race time record, but i just know it can be better.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-29-2011, 01:05 PM   #1007
RC MARKET's Avatar
Originally Posted by Jeronemo View Post
Hi Guys
Can anybody confirm what chassis plate the kit is supplied with because the specs at A-mains says it is 2,5mm and the kit specs at RC Market is 2,25mm.
Can kits be ordered with diff options of chassis plates.
Yes We support 2.25mm Chassis !
RC MARKET is offline   Reply With Quote
Old 08-29-2011, 06:11 PM   #1008
Hi.
I tried that myself, one of the 1st things I did. Makes the car very unsettled when you touch anything, especially traction rolling off corner markers.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-30-2011, 06:38 AM   #1009
Serpent has finally released spurgears, both 64P and 48P.
Anyone knows when it hits the onlineshops?
joachimG is offline   Reply With Quote
Old 08-30-2011, 10:20 AM   #1010
You can find 48p in RCMARKET
Nitroblood is offline   Reply With Quote
Old 08-30-2011, 11:31 AM   #1011
RC MARKET's Avatar
wait moment have new price coming !
Old 08-30-2011, 05:55 PM   #1012
mattwoodcraft's Avatar
i waiting on the weights to turn befor another order, ar ethey due in soon ?
mattwoodcraft is offline   Reply With Quote
Old 08-30-2011, 08:20 PM   #1013
Akhor's Avatar
I see that lots of people are running 3000 cst in their diff. Do you know know what the equivalent Losi diff oil weight is?
--Blaine--
Losi 8ight-E 2.0, Mugen MBX 7, Mugen MBX 7 Eco
VBC D07, VBC D08
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is online now   Reply With Quote
Old 08-31-2011, 03:17 AM   #1014
azz187's Avatar
Default Setup for med trac asphalt
Does anyone have a solid setup they can post for med traction asphalt?
Ran the kit setup on the w/e and struggled to stop the car from spinning out on power through corners. The car is fast out of the box, but is hard to drive. (for my skill level at least)
I've tried heavier diff oil and longer wheel base to start with, any other suggestions?? Any help would be great...
Cheers
azz187 is offline   Reply With Quote
Old 08-31-2011, 04:22 AM   #1015
Trader Rating: 54 (100%+)
Cheers
Stand the rear shocks up 1 hole on tower. Use white rear spring,orange in front. Go to 45 losi shock oil in front 40 in back. I think 50/45 would even be better, but havent tried yet.
Make sure you are on the right tire. <-very important. S411 doesnt like cheap tires
Jamison R is offline   Reply With Quote
Old 08-31-2011, 06:40 AM   #1016
azz187's Avatar
Thanks mate, I'll be standing my shocks up for my next run, I'm also running the 2.5 mm chassis, would the 2mm chassis give more grip?
Anyone know what HPI springs are close to serpent orange and white?
Cheers..
Old 08-31-2011, 05:44 PM   #1017
2mm chassi wii generate more flex and give you better grip if your running mod put the hard parts on it settles the car down
Old 08-31-2011, 10:17 PM   #1018
Must use hard plastic parts!! I run mod with the stock arm the car keep spinning out. With the hard parts the car is way more stable. Especially at the high speed sections.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 09-01-2011, 12:22 AM   #1019
wee
Default spin out (on power)
hi guys
from mine finding, i use front spring (blue) and rear (pink) and is very stable.
if the car tends to flex, it will lose much traction. this is for low traction track.
if is to apply to high grip track, i would say steering not enough to go through a turn.
correct me if i am wrong on the finding
thks cheers
happing racing
SERPENT S733 , S966 , S811 , S400 , S411 TE & S747 SOON.......
POWERED BY NOVAROSSI ( GP )
POWERED BY HOBBY WING V3, SPEED PASSION AND LRP (EP)
wee is offline   Reply With Quote
Old 09-01-2011, 02:55 AM   #1020
Originally Posted by wee View Post
hi guys
thks cheers
happing racing
I wouldn't put it like that... I find that more flex allows each end to develop more grip at each end than the setup would allow from a stiff chassis. This is a good way to get a more driveable car if you are having problems with handling however more rear grip also means more understeer (and thus less potential for speed). As far as flex is concerned I only ever remove one screw from my top deck if I want more flex and that is the single screw above the motor mount. I find the others less effective for tuning. The 2.25mm and 2.0mm lower decks should also offer better traction with less understeer effect however it is a big change to go back if it doesn't help.
Powered by Falco
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
