Old 08-28-2011, 06:44 AM   #991
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Dragonfire View Post
The core design was always going to offer that even before it hit the track. What we need now is another batch of option parts. I am keen for a replacement to the steering rack to offer spacing for ackerman adjustment. That will yield better performance again.
im really doubting the need for any more options. last 3 meets i have changed my car completely and have suffered, either due to setup , or track and weather conditions. today was a quick few laps just to see how it felt. no timing, but to be honest, after chaging chassis, roll centers, and toe plates, and even goign to Hard arms and hubs all round, the car felt almost the same as it has before. so that many changes, i was expecting steering issues, lack of it, and a planted rear end. but infact it was a tad loose on the back, and still the same amount of steering. so really not sure how to go now. ill leave it as is, and wait for the weekend, and see what the times are like. but it feels the same. haha. but nothing ventured, nothing gained.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-28-2011, 11:15 PM   #992
JayBee's Avatar
Trader Rating: 31 (100%+)
DITTO
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-29-2011, 02:59 AM   #993
Jeronemo's Avatar
Default S411 kit
Hi Guys
Can anybody confirm what chassis plate the kit is supplied with because the specs at A-mains says it is 2,5mm and the kit specs at RC Market is 2,25mm.
Can kits be ordered with diff options of chassis plates.
Serpent 411 ERYX , Speed Passion PRO , Trinity D3
BMI 1/12 Copperhead , HW 1 cell , Trinity D3
Futaba 4PKS FASST
Jeronemo is offline   Reply With Quote
Old 08-29-2011, 03:33 AM   #994
Originally Posted by Jeronemo View Post
Hi Guys
Mine came with a 2.5mm. As far as I am aware the 2.0mm and 2.25mm are only options and not part of any kit.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-29-2011, 03:41 AM   #995
Mine is going quite well too but I am looking for a way to square up the back end on power so I can drive out of the corners harder. This is the only weakness it has at the moment. I am keen to get the 3.5 blocks for the rear to see if this is what I am looking for. The other option that I have not played with is adjusting the track front and rear. This would be great if they offered lots of option blocks so you could narrow or widen each end by 0.5mm. At the moment I am thinking of trying 0-1 blocks on the front to balance the response of each end during change of direction.
Powered by Falco
Old 08-29-2011, 04:13 AM   #996
Pattojnr's Avatar
just tried all that, and i mean all of it. and i was left wondering what i actually need to do. cause it felt the same. haha i have the rear toe plate, and will be trying that. i can get the drive no problem but im looking for a better balance of steering and rear grip. i know it is possible, but it will all click one day. just have to keep trying stuff.
Serpent - Walter RC
Old 08-29-2011, 04:34 AM   #997
mattwoodcraft's Avatar
Hi Guys
2.5mm chassi and top deck all the rest are option parts
mattwoodcraft is offline   Reply With Quote
Old 08-29-2011, 05:01 AM   #998
Pattojnr's Avatar
im sure kit top deck is 2mm, chassis is 2.5mm. options are 2.5mm top deck, 2mm chassis, and 2.25mm chassis.
Serpent - Walter RC
Old 08-29-2011, 05:03 AM   #999
yep your correct for some silly reason i thought it was 2.5
Old 08-29-2011, 05:06 AM   #1000
Patto you goen to the spring cup next sunday at west coast
Old 08-29-2011, 05:12 AM   #1001
Pattojnr's Avatar
yes i am there. Mod and 8th scale. if you thaugth Mod was fast. hahaha go Sh%t a brick if you marshal the sweeper.
Serpent - Walter RC
Old 08-29-2011, 05:37 AM   #1002
i look forward to it
Old 08-29-2011, 06:03 AM   #1003
Pattojnr's Avatar
sort have have comp at the moment. see who can marshall the sweeper with out flinching. theres $10 on the line.
Serpent - Walter RC
Old 08-29-2011, 06:15 AM   #1004
wow seems worth it when putting your life on the line
Old 08-29-2011, 06:18 AM   #1005
Hi.
To solve your problem, try 3 - 3,5 or even 4 mm shims on the rear upright links and lower the shims on the inside on the bulkhead. The link (turnbuckles) must be more angeled. It works on a 417, why not on a 411...
BCDK is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
