Old 08-24-2011, 12:21 AM   #946
Originally Posted by Dragonfire View Post
If you are running a kit diff then try 3000cst in your diff. When you change to 4 bevel gears the diff works a lot better on power so with 4 bevels I us 500cst oil and it is better again everywhere on the track.
ill give that a try on sunday , im using the 4 bevel gears already
will the hard rear up rights work plus the front hub/caster blocks?
cheers again....
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 08-24-2011, 02:28 AM   #947
mingnon's Avatar
Default Newbie gear set up question
Hi everyone, enjoying reading the thread. Have just built S411 and got it reasonably set up and gave it first run last night.
If possible can i msg someone regarding the spur gear and pinion gear setup so as i dont clog up your threads.
Cheers
Matt b
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 08-24-2011, 04:32 AM   #948
mattwoodcraft's Avatar
Originally Posted by Team STPN View Post
I had the same issue and lowered the rear roll center from 1m to .5 m and no issue after that
thats exactly what i shave done and its made a huge differance i also use the red springs on the front white on the back and have moved the rear wheel base back 1mm hard uprites front and rear with hard arms.
2mm chassi 2mm top deck 1.2mm rear sway bar
mattwoodcraft is offline   Reply With Quote
Old 08-24-2011, 04:33 AM   #949
what would you like to know about the spur and pinion
Old 08-24-2011, 04:47 AM   #950
Send a message via MSN to Mark Stiles
Despite people thinking softer has more grip soft springs also struggle with load. Too soft will see too much weight transfer and the tyres will not be able to coop. Its always about when you need the grip not what end.
As I understand it...
Stiffer springs create more lateral weight transfer and less roll.
Softer springs create less lateral weight transfer and more roll.
More lateral weight transfer will usually lead to a loss of grip at that end of the car mid-corner, since the load/force graph of a tyre is not linear. Therefore more weight transfer (stiffer spring) will mean more grip is generated at the outside wheel, but the loss of grip from the inside wheel will be more than the gain on the outside...
Yokomo - Reedy - Protoform - A-Paint - CML Distribution - Racer Magazine - Zen-Racing - MomentumRC
BRCA 1/12 Electric Circuit Section Chairman
Mark Stiles is offline   Reply With Quote
Old 08-24-2011, 04:52 AM   #951
Something that might be of interest;
http://teamserpent.com/2011/08/serpe...rca-nationals/
Old 08-24-2011, 04:59 AM   #952
Originally Posted by RC MARKET View Post
later release !
great i will be waiting as patiently as i can
Old 08-24-2011, 05:33 AM   #953
mingnon's Avatar
Hi and thanks for the reply
am running serpent s411, 21.5turn (no boost etc) in stock/blinky mode at local club (sma) in sydney.
Am really lost regarding the spur and pinion setup.
Currently has 84tooth spur and 24 tooth pinion (48pitch), Hobbywing extreme stock esc (60amp) and 7.4, 5000mah 30c lipo. The S411 has a ratio of 2.0 (from the manual)
Ran it last night, and its slow as a wet cat.
Turned the turbo and boost up to full and it ran well.
Am trying to work out if it is a gearing issue or an issues with the esc programming
Old 08-24-2011, 06:22 AM   #954
StevenOlsen's Avatar
you are gearing it all wrong when running 21.5 with no boost, you are gearing 7.0. you need to gear around 3.5-4.0 depending on track size.
i think you are doing somthing wrong when calculating the gear ratio the correct formula looks like this (spur/pinion)x2.0
hope it helped a little
Steven
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 08-24-2011, 01:20 PM   #955
mingnon's Avatar
Steven
Steven
thanks for the heads up, went back and checked and yeah all wrong
Aiming for the middle (3.7), will need to get a 74/40 and see if it will fit, might need to modify the motor mount plate to fit the pinion.
If it is okay to ask, where did you get the number for the gearing? have been trying to find a list as one race at is outdoor and fairly long and the other is an indoor carpet track at the local sports centre (about 1/6th the size of the outdoor)
Old 08-24-2011, 01:50 PM   #956
Steven
its from reading a bunch of treads here on rctech. readīng what others are gearing and/or is timing both the motor and the ESC. but the most importent testing it your self :-)
Steven Olsen
Old 08-24-2011, 03:20 PM   #957
mingnon's Avatar
Thumbs up
Steven
thanks for the heads up, have finally worked out the gearing to a sufficient level and will continue to read
time to look for spurs and pinions that will fit this, am in unknown territory as no one at the tracks have one of these nor have they seen one in the flesh. Im really impressed with the s411 and its quality, and its a huge step up (for me) from the learning car previously used.
Thanks for all your help
Old 08-24-2011, 05:11 PM   #958
Steven
I'm using the XRay spur right now however, The Associated Spurs work as well and are quite a bit less expensive.
duckman996 is offline   Reply With Quote
Old 08-24-2011, 11:50 PM   #959
RC MARKET's Avatar
they said end of AUG release !
RC MARKET is offline   Reply With Quote
Old 08-25-2011, 01:05 AM   #960
Steven
Whay day do you race at SMA. I have only had mine there once so far but will have to go back some time for some more testing.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
