Old 08-23-2011, 04:18 AM   #931
Originally Posted by mwoods View Post
yeah i am front and back
Ok putting the bracket in will reduce flex which more than anything makes the car easier to drive. Adding more droop will more likely give you understeer so you will just go slower (too much load on outside tyres). If your running kit springs then chances are that is your problem. I would also look at your oil weights. Are you running split weights or the same oil f/r?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-23-2011, 04:55 AM   #932
Im running 40wt front 35wt rear (sch oil) xray springs 2.4 and 2.6
The track im racing on is a bit bumpy . Im also using a 2.0 front rear block instead of the 1.0 thats in the kit .
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 08-23-2011, 04:58 AM   #933
hey all , wen running the one peice motor mount is it worth useing the l shape bracket so u can put the screw in the top deck just infront ot the motor? my car is lacking rear grip and is tale happy at the back .
also will it b worth going from 4mm downstop all round to 5 mm all round to get the car more stable ?
thanks
Adding more screws to the top deck is going to give the car less chassis flex - making the rear even stiffer. Some argue that using chassis flex is less effective then trying to set-up the suspension for the conditions, however, utilizing chassis flex in addition to a well-set-up suspension makes the car easier to drive.
In my first testing session, where I was running the car on a medium grip outdoor track (prepared parking lot - with sugar water), the S411 tends to like a little less droop versus some of the other cars I have ran. I've also went up in oil, again making the car very stable in high speed corners. Depending on the track you are racing at, you might want to go harder with the suspension (i.e thicker oil) to calm the back-end down.
What diff fluid are you running?
duckman996 is offline   Reply With Quote
Old 08-23-2011, 05:20 AM   #934
mattwoodcraft's Avatar
anybody know wher ethe chassi weights can be purchased from ?
been looking cant find any in stock
mattwoodcraft is offline   Reply With Quote
Old 08-23-2011, 07:05 AM   #935
RC MARKET's Avatar
later release !
RC MARKET is offline   Reply With Quote
Old 08-23-2011, 07:06 AM   #936
Im running 1200 wat i got in the kit .
Old 08-23-2011, 09:22 AM   #937
Jinjiro7's Avatar
Mwoods is your cars rear-end loose on power or off?
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 08-23-2011, 09:25 AM   #938
jrxs-r's Avatar
Originally Posted by JayBee View Post
Care to share your set-up?
Not quite yet... still have a few issues that I am working through. Will post as soon as I get a decent baseline setup.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 08-23-2011, 09:48 AM   #939
On power ...
Old 08-23-2011, 10:14 AM   #940
[QUOTE=duckman996;9562015]
im running 4mm droop fron and back wud it b worth going to say 5 n 5 or 6 front 5 rear?
cheers
Old 08-23-2011, 12:01 PM   #941
Jinjiro7's Avatar
Mwoods -> I ran the S411 on 3 different tracks now. Two in Toronto, Asphalt Home Depot Parking lot tracks with sugar water med traction and now tried it in Village Raceway track down in Royal Palm FL. Smooth concrete track with med+ traction.
My car did the same as yours with loose on-power coming out of corners. I tried droop first, but it didn't help much. Best change for me was two things:
1- Extended Rear wheelbase to use 5mm spacers on the front suspension block on the rear.
2-Use heavier springs up front. Use 16 LBS (Serpent Yellow) for med traction asphalt and now 19LBS (Serpent kit Orange) down in Village Raceway.
My droop has also been lowered to the 4mm mark. But that's up to you to fine tune after you sort out the wheel base and springs.
Wheelbase was where I saw the largest change from kit settings. I improved my 1sec lap times on the Toronto tracks just with that alone.
Ryan
www.drcrc.ca
www.fastcats.ca
Old 08-23-2011, 12:27 PM   #942
1- Extended Rear wheelbase to use 5mm spacers on the front suspension block on the rear. i did that wen i built the car
2-Use heavier springs up front. Use 16 LBS (Serpent Yellow) for med traction asphalt and now 19LBS (Serpent kit Orange) down in Village Raceway. i use xray 2.4 and 2.6 but the weekend b4 i used 2.6 2.8
one thing i think it mite be is the rear droop screws dont hit the chassis wen its on the ground , wat over all lenth u building ur shocks at
thanks
Old 08-23-2011, 06:50 PM   #943
Originally Posted by OVA View Post
Sorry JB
I can't find the shock oil conveter chart for all brands...I'll keep looking
Attachment 799101
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 08-23-2011, 08:00 PM   #944
Team STPN's Avatar
On power ...
I had the same issue and lowered the rear roll center from 1m to .5 m and no issue after that
Team STPN is offline   Reply With Quote
Old 08-23-2011, 11:28 PM   #945
On power ...
If you are running a kit diff then try 3000cst in your diff. When you change to 4 bevel gears the diff works a lot better on power so with 4 bevels I us 500cst oil and it is better again everywhere on the track.
Powered by Falco
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
