Serpent S411
#887
So the maiden race didn't go as planned. I hit the wall a few times. Busted Front right CVD pin. Also rear blades were worn using 7turn and 13.5 turn brushless for approximately 10 runs.
The good news? I am averaging 1sec faster than the last time I raced there. And posted my best lap time ever on that track!
#889
#892
I'm wondering if this SPEC R - Drive Shaft Plastic Cup ( For Yokomo 3.5mm )) usable for 411 ?
#894
yes, much much harder. I don't think it is same materials as the hard arm. The colour is black (not dark grey like the hard arm). Very hard, had 3 more runs with the car last night and the blades still look brand new.
#895
Do you guys find that the bearings that come with the steering bridge are wobbly?
#898
Hi Kobiwan do you mean the Xray CVD pin with the flat ground to lock the set screw onto if so,Yes have replaced them all and also now using Top Aluminum axle pin holders(sleeves) just for extra insurance
#899
Yes, the pin will fit. Don't you find the Top sleeves a little loose.... I fit it on mine and it keep moving around.....
#900
