Old 08-14-2011, 11:02 PM   #871
mattwoodcraft's Avatar
use the xray spur gears they work the best and are a direct fit..
i was using 64p in the car but was having problems with chipping teeth i now use 48 pitch in mod
gera ratio for stock around 4.5 - 5 may be a good starting point
mattwoodcraft is offline   Reply With Quote
Old 08-15-2011, 12:13 AM   #872
esham's Avatar
Thanks Matt for your input and i did consider this for start and fine tuning it from there. Thanks again.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- shu@esham
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-15-2011, 12:44 AM   #873
alloy up rites for the rear, do serpent make them ? or maybe some Xray ones may fit anyone know
Old 08-15-2011, 02:15 AM   #874
corallyman's Avatar
Trader Rating: 97 (100%+)
Stormer Hobbies is showing part numbers for aluminum c hubs, steering blocks, and rear uprights as coming soon from Serpent.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-15-2011, 05:15 AM   #875
stormers i had forgotten to check there site
thanks
Old 08-15-2011, 04:45 PM   #876
rcscoot2539's Avatar
Well I had the car on the track for the first time yesterday and all I can say is WHOW this car is fast. Once traction started to come up I had a fast lap of 8.3 but ave. around 8.5 - 8.6, But the rearend was loose. My set-up at this time was hard arms front and rear - stock caster blocks - stock rear uprights - front geardiff w/ 500,000wt oil - rear geardiff w/ 3000wt oil - yellow springs in front w/ 500cst - white springs in the rear w/ 500cst. After changing the front spring to orange the car felt a little better but the rear was still to loose. So I put the hard caster blocks in the front and removed the rear sway-bar, did not like the car without the rear sway-bar. After making some adjustments to the radio ( steering expo ) the car was worse. Being that its a new radio I looked in the book and found I was going the wrong way on the expo., I also felt a lot of torque-steer, so I put the spool on and put it on the track for the last time. My fastest lap was a 8.0 and ave. lap 8.2 - 8.3. So if your not asleep yet here is my set up-
hard caster blocks
orange front springs - 500cst
white rear springs - 500cst
front spool
rear gear-diff - 3000wt
tires sweep 32
stock 17.5 ( blinky ) lrp x12
100-45 gearing
small indoor carpet track
If theres anything I didn't cover let me know.
PS John and I will be running the cars again this thursday night, he will have the 2.25 chassis and the new motor mount.
Sorry for the long post.
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 08-15-2011, 05:51 PM   #877
Jinjiro7's Avatar
Ran my first race weekend with the Snake. I installed the servo using the inside Servo mount and used double sided tape instead of the CF plate. Works great! This way it can clear my Kimbrough Servo saver. Servo did not move even with hitting the wood a few times.
Car is solid, responds well to setup changes. Improved my lap times by 1 sec from previous car. So very happy with that.
here are the servo pics:
h ttp://i104.photobucket.com/albums/m173/jinjiro7/2011%20S411/P1000314.jpg
h ttp://i104.photobucket.com/albums/m173/jinjiro7/2011%20S411/P1000313.jpg
Jinjiro7 is offline   Reply With Quote
Old 08-15-2011, 06:54 PM   #878
Originally Posted by rcscoot2539 View Post
Well I had the car on the track for the first time yesterday and all I can say is WHOW this car is fast. Once traction started to come up I had a fast lap of 8.3 but ave. around 8.5 - 8.6, But the rearend was loose. My set-up at this time was hard arms front and rear - stock caster blocks - stock rear uprights - front geardiff w/ 500,000wt oil - rear geardiff w/ 3000wt oil - yellow springs in front w/ 500cst - white springs in the rear w/ 500cst. After changing the front spring to orange the car felt a little better but the rear was still to loose. So I put the hard caster blocks in the front and removed the rear sway-bar, did not like the car without the rear sway-bar. After making some adjustments to the radio ( steering expo ) the car worse. Being that its a new radio I looked in the book and found I was going the wrong way on the expo., I also felt a lot of torque-steer, so I put the spool on and put it on the track for the last time. My fastest lap was a 8.0 and ave. lap 8.2 - 8.3. So if your not asleep yet here is my set up-
hard caster blocks
front spool
tires sweep 32
100-45 gearing
Wheelbase is stock front - rear is 1mm behind arm and the rest in front of arm - longer wheelbase
Old 08-15-2011, 09:42 PM   #879
hard caster blocks
front spool
tires sweep 32
100-45 gearing
Thank you!!! For the roll center do you keep the stock 1mm front and rear? And yes, the stock soft plastic parts are no good, atleast for our high grip track.... After changing to hard parts much better.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 08-16-2011, 12:14 AM   #880
i have also just put the hard arms on, the car really does drive better and more consisitant for mod.
Old 08-16-2011, 03:58 AM   #881
Default shock serpent
guys, I saw that among the parts, I found short shocks?
what to change and shock absorbers as standard?
biagio23 is offline   Reply With Quote
Old 08-16-2011, 04:54 AM   #882
Pattojnr's Avatar
Trader Rating: 19 (100%+)
serpent have 2 sizes of shocks. Short length shocks fit - 411, 733, front 966. longer shocks fit the rear of the 966. the only upgrade available for the shocks on the 411 are the TI-NI coated shafts (903226).
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Last edited by Pattojnr; 08-16-2011 at 05:03 AM. Reason: P$SS poor grammar, and probably still is. :)
Pattojnr is offline   Reply With Quote
Old 08-16-2011, 05:22 AM   #883
advfuel's Avatar
Trader Rating: 29 (100%+)
Hi Matt
Is the track open duing the Week for practice ?
advfuel is offline   Reply With Quote
Old 08-16-2011, 05:41 PM   #884
Yes...... But this Thursday I am going to try taking the 1mm shims out all the way around.
Old 08-16-2011, 06:42 PM   #885
Originally Posted by advfuel View Post
Hi Matt
i do not know i have neen asking i will find out..
i have been doing lots of set up practice in rockingham where the old off road track used to be, the drivers stand is there and a track is marked out, nice and close to home..
i will find out about west coast and let you know
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
