Old 08-14-2011, 01:10 AM   #856
mattwoodcraft's Avatar
what belts are referrining to ?
mattwoodcraft is offline   Reply With Quote
Old 08-14-2011, 01:21 AM   #857
RC MARKET's Avatar
1.5 , 2.5 & 3.5 Suspension Mount released !
RC MARKET is offline   Reply With Quote
Old 08-14-2011, 01:36 AM   #858
JayBee's Avatar
Trader Rating: 31 (100%+)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-14-2011, 01:39 AM   #859
JayBee's Avatar
Ordered 2 of each from you
I'm looking for another shock set for the S411 and a set of the weights. Any places out there you know of guys? I've scoured rcmarket (which is where I get all of my spares) and nothing.....
Old 08-14-2011, 01:46 AM   #860
RC MARKET's Avatar
Thankyou !
Old 08-14-2011, 02:49 AM   #861
Trader Rating: 54 (100%+)
Fischer got taken out in A1 of Euro's
Jamison R is offline   Reply With Quote
Old 08-14-2011, 03:53 AM   #862
azz187's Avatar
Originally Posted by rcscoot2539 View Post
Yes you are correct about hard arms taking away traction, but on some carpet tracks that is what you need to do. The first local test with the car in kit form had way to much traction in the front. I like a car that pushes a little, like they say loose is fast. This weekend I will have the car on the track for the first time and I will be trying different set-ups, I am one that dose'nt believe in using parts from other car's to make a car go faster. Whitch means I will be using all Serpent parts. I will let everyone know what I find out next week.
Hey Rc scoot,
Have u run the hard parts yet? If so how did you go & are they worth the extra $$ over the standard bits?
azz187 is offline   Reply With Quote
Old 08-14-2011, 09:40 AM   #863
Originally Posted by azz187 View Post
Hey Rc scoot,
AZZ
Rc scoot and I hail from the same local track. We run carpet which typically has more traction than asphalt. He will be testing the car for the first time today as well as the Hard suspension parts. I ran it for the first time on the 5th. There is a differece between too much traction/grip and too much steering. I don't think you can ever have too much traction especially with rubber tire. That being said, when I tested it we found that the kit suspension parts are too soft and yield too much steering up front and makes the car inconsistant and hard to drive. The car had tons of traction and was fast, but too much steering which made the rear end loose. I had Paul Ciccarello Which is our team mangager helping me and no matter what we changed we couldn't take steering out of the car and thats when we realized how soft the kit a-arms were and narrowed it down to that. Our local track doesn't get as much traction as the bigger races we attend. We will be returning to The Gate in Cleveland Ohio where I first tested the car to try the hard arms on Sept. 16-17, they are having a Vegas warm -up race. RC scoot is supposed to call me today and let me know how it went today. I'm sure he will post his findings. But to answer your question on whether the parts are worth it, I say if you can afford it, it doesn't hurt to have different tuning options. I remember when I still ran Foam tires on carpet we ran Differnt strength arms front and rear. I hope this helped.
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 08-14-2011, 03:36 PM   #864
azz187's Avatar
Thanks for the info mate I'll be ordering some hard parts for sure.
I'm halfway through building my 411, the quality is much better then my tc6..
Great fun to build so far.
Old 08-14-2011, 03:42 PM   #865
RC MARKET's Avatar
good !
Old 08-14-2011, 04:56 PM   #866
placing hard arms on the front should assist in taking steering away. when i used to run corally i used derilium arms from and back no flex in those at all.
what about putting more shims under the blocks to raise the roll centre that should also assist in taking some steering away
Old 08-14-2011, 05:07 PM   #867
That will also make the front end more responsive making it easier to break traction on the rear when entering a corner or changing direction. I normally prefer it the other way round with more shims under the rear (rubber/asphalt)
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-14-2011, 05:29 PM   #868
JayBee's Avatar
Even with running a MOD motor?
Old 08-14-2011, 05:58 PM   #869
interesting here i was thinking it was the other way around.maybe i have got my self confused
thanks
Old 08-14-2011, 10:50 PM   #870
esham's Avatar
Hi everybody, i'm GP racer and going to start run EP with S411 .. still in assembling stage. I'm abit handicap interm of EP drive ratio/ spur/gear 48p or 64p etc. Not many friends to refer in local track as most of them running TRF and Xray . Can anybody recommend me the spur/pinion combo for my stock 17.5 motor? And my i know what other brand of spur gear that can suit S411. Thanks for your recommendation.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- shu@esham
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
