Old 08-05-2011, 07:48 PM   #796
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Craig W View Post
that is the Gas spring kit. you will find you will use 2 colours of springs in that set. the rest are too hard for EP. the new springs coming have a TC on the end of the part number, just hope they can come out soon to be trying them.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-05-2011, 08:52 PM   #797
venom54's Avatar
Default SERPENT TOWEL IN STOCK
Originally Posted by kobiwan View Post
Anyone know who has a Serpent pit towel in stock?
We can help :
1869 SERPENT Orange towel.
PIT TOWEL
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 08-06-2011, 12:25 PM   #798
Jinjiro7's Avatar
Default s411
Hi guys,
I assembled my S411 kit and took it for its maiden run today. Rear was a little loose as mentioned by others here. But a little droop in the front fixed that.
When removing the front top bulkhead screw, it hits with the bottom shock tower screw, making it impossible to remove the top bulkhead without disassembling the shock tower
Have any of you encountered this issue?
Here is a picture for better explanation:
h t t p ://i104.photobucket.com/albums/m173/jinjiro7/SerpentS411-7a.jpg
Jinjiro
Jinjiro7 is offline   Reply With Quote
Old 08-06-2011, 03:28 PM   #799
Send a message via MSN to Mark Stiles
Originally Posted by Jinjiro7 View Post
Hi guys,
Jinjiro
You don't have to remove the tower for this. Just remove the other two screws as normal. Then you can undo the remaining two screws that are shielded by the shock tower screws a bit at a time until the upper bulkheads can be removed. It's really not any hassle at all and also means that you can't lose the screws!
Yokomo - Reedy - Protoform - A-Paint - CML Distribution - Racer Magazine - Zen-Racing - MomentumRC
BRCA 1/12 Electric Circuit Section Chairman
Mark Stiles is offline   Reply With Quote
Old 08-07-2011, 02:57 AM   #800
Actually I don't even bother putting the lower tower screws in, just the top two and you don't have the problem. The alternative is mentioned above.
Got a few runs in today and have the car running much more how I like it feel wise. The track conditions were quite poor with on/off rain and old tyres but generally it went around good considering. I ran.....
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-07-2011, 05:29 AM   #801
mattwoodcraft's Avatar
i took all my shims out of the rear with the 2.5 chassi to lower the roll centre more how ever maybe with a 2mm chassi i might have to put at leat .5 shim in maybe testing with the 2mm soon
mattwoodcraft is offline   Reply With Quote
Old 08-07-2011, 11:09 AM   #802
JayBee's Avatar
Trader Rating: 31 (100%+)
Trying dual geardiffs today. 3000wt in the rear w/ OFNA Diff-lock (feels a tick stiffer than the 600K stuff I have) in the front. We'll see how it goes.....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
Last edited by JayBee; 08-07-2011 at 06:05 PM. Reason: had to change the lubage viscosity....
JayBee is offline   Reply With Quote
Old 08-07-2011, 05:04 PM   #803
Originally Posted by JayBee View Post
Trying dual geardiffs today. 3000wt in the rear w/ OFNA Diff-lock (feels a tick stiffer than the 6K stuff I have) in the front. We'll see how it goes.....
What is OFNA diff lock?
Powered by Falco
Old 08-07-2011, 05:10 PM   #804
MikeXray's Avatar
Trader Rating: 72 (100%+)
Its kinda like 1,000,000 cst oil.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-07-2011, 06:11 PM   #805
veecee's Avatar
Trader Rating: 34 (100%+)
Default CSO Chassis
Originally Posted by mattwoodcraft View Post
thats great a new 2mm chassi almost half the price of the one i paid for not to long ago
I wouldn't lose too much sleep over it... I got one of these over the weekend from a HK shop and there is good reason why it is so cheap.
The structure looks different to most normal chassis. This is quote obvious where material is removed in cross section (ie motor cutout, countersinks). It's hard to tell but I'm pretty certain not all of it is carbon fiber...
So I would approach this chassis with caution. Especially if your expectation is for a chassis that is 100% carbon.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 08-07-2011, 11:32 PM   #806
JayBee's Avatar
Hey guys here's a snapshot of my setup. The dual geardiff setup worked quite well today. The car got better than last week but too many mistakes kept me out of 'the money placings'. Let a fellow wheel drive the car and he came to the same conclusion........a bit more steering would be nice
Can ya help guys?
Last edited by JayBee; 08-07-2011 at 11:57 PM. Reason: sorry for the bad pic guys :(
Old 08-08-2011, 01:12 AM   #807
corallyman's Avatar
Trader Rating: 97 (100%+)
Can ya help guys?
JayB,
I have a good amount of steering in my "AWESOMENESS" Serpent.
I am still running the spool up front as I don't yet own a second gear diff. One difference in our cars is I am running my rears arms almost all the way to the back, I have a 1mm shim behind the rear arm and all the rest of the shims in the front. I also moved my front arms back to the steering linkage, I think there is also a 1mm shim behind the front arm with all the rest of the shims in the front.
I am doing the Sizzler but will most likely not get there until Saturday.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-08-2011, 01:16 AM   #808
JayBee's Avatar
I'm witcha there Steve-O. I won't be arriving until Saturday as well. I will try what you have on yours and see if that is the ticket. Still trying to figure out the slop up front but it doesn't seem to affect the drivability though but I need to tighten it up though to see. Can't wait buddy. What motor are you running? Gotta try and slither one of these snakes to a podium
BUT YOU BETTER RUN!!!!!
Old 08-08-2011, 01:20 AM   #809
corallyman's Avatar
My car is really good at Fasttrax in the fast sweepers and really good in the tight twisty's too. Yesterday I got inside of a couple of guys in the slow twisty section were no one else seemed able too, so I was pleased. I'll send you a PM later tomorrow at some point JB.
Steve
Old 08-08-2011, 01:31 AM   #810
JayBee's Avatar
Is that the only difference in our cars? PM me your setup.....
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
