Like Tree13Likes
Old 01-07-2016, 02:08 PM   #6931
Johnny Wishbone's Avatar
Default Shock Springs
You can pretty much run all the springs out there by using either the RCm or the RCXX lower spring reatainer. I run the RCXX retainer with the 20mm Xray springs and have ample adjustment opposed to either being at the very top or the very bottom of the shock adjuster.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-14-2016, 11:07 AM   #6932
performula's Avatar
I went ahead and bought a sport to backup (21.5t) my eryx 3.0. Got it 180 shipped from australia. Hopefully it makes it in one piece.
Now should I use the stock 2.5 glass chassis or switch to an aluminum 3.0 or carbon 2.5 on stock configuration? It's for carpet. As I'd have all three.
performula is offline   Reply With Quote
Old 01-14-2016, 11:23 AM   #6933
dan_vector's Avatar
Trader Rating: 27 (100%+)
Alu 2.0mm chassis is my goto chassis for carpet.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-14-2016, 11:30 AM   #6934
performula's Avatar
I notice it has a lot of flex compared to the 2.5 graphite. Would you say the flex is similar between the 2.5 fibreglass chassis and the aluminum 2mm?
Old 01-14-2016, 11:38 AM   #6935
dan_vector's Avatar
I didn't feel the fibreglass chassis before (I've only ever had the 411 race kits) however I can only assume that the fibreglass is fairly stiff. I'd be inclined to leave the sport version car for what it is and run it stock initially. I've heard of people running the car stock and being competitive.
Old 01-14-2016, 01:59 PM   #6936
swerv512's Avatar
I remember this atricle when i was deciding on the sport or a 2.0... Looks like the sport chassis is very capable.
http://www.area52.cc/news/3243-serpe...or-racing.html
swerv512 is offline   Reply With Quote
Old 01-14-2016, 07:52 PM   #6937
performula's Avatar
Perfect for the stock class I intend to run. I wanted to race two classes so I wasnt bored between heats.
Old 01-14-2016, 08:03 PM   #6938
dan_vector's Avatar
Yes, I think you'll be fine with the car stock! Keep us posted!
Old 01-15-2016, 06:44 AM   #6939
Nice to see this article used. I wrote it for my son Rasmus, when I was the mechanic on his cars.
Another good idea maybe a to buy: all the wishbone blocks are made of plastic, and they have a built-in 1,0 mm high roll center. The alu blocks from all other 411 cars fits right in this car, and they have standard a 1 mm lower roll center using shims to adjust the roll center.
The car showing in the article is still running in our home club. A young driver bought it, and allthough it have have had a real tough life up to now, it is still running. He has upgrated the car with the alu blocks and a second old used diff with 500.000 cst oil in for the front.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 02-14-2016, 09:53 PM   #6940
swerv512's Avatar
How looking do you guys typically wait to replace your rear outdrives? Mine are getting pretty rounded and I seem to be replacing cvd blades every 8 to 10 packs before they look beaten up... I have a 2.0 with the v3 diff- aluminum outdrives.
Old 02-14-2016, 11:23 PM   #6941
monkeyracing's Avatar
Hey guys, I'm looking to stock up on parts and I'm wondering about some specific items. What difference do regular or hard wishbones, uprights and/or C-hubs make? Are the C-hubs really separate left and right pieces? (manual doesn't specify)
I'll be doing major maintenance in a few months, so I'm looking to do some other stuff, as well. I don't believe the diff oil in the rear has been changed in a few years. Is there a benchmark or indicator to let me when it should be done? It runs smoothly enough, I think. Other than diff and shock rebuilds, I'll be replacing every ball joint on the car.
Thanks for your help. I'm still learning about TC chassis.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-15-2016, 04:16 AM   #6942
dan_vector's Avatar
I've never changed out a rear out drive on any of my 411's. I've found the diff worn out before the out drives have so just replace the entire diff. 8 to 10 packs is about right for the blades really. I change mine out after each race day which is probably about 10 packs I'd say. Blades are very cheap so just keep on changing them because that's how the damage is done to the out drives.
Old 02-15-2016, 04:22 AM   #6943
dan_vector's Avatar
The hard versions of the plastics are standard now. They provide a more direct feeling to the car and are best for med/high traction. The medium plastics are the old version and are best in v low/low traction conditions. Most of us run the hard or X-hard now.
Yes C hubs are always handed left/right. The manual isn't specific because it assumes this to be convention. The hubs are swept back 2, 4 or 6 degrees and so would be handed left right. They come spare as a pair and 4 degree is common. If you are replacing the arms I'd recommend downloading the 3.0 or 4.0 manual and order the latest standard arms as they changed between the 2.0 and 3.0.
Diff oil should be changed regularly (as well as shock oil). I rebuild my shocks at least before every race and sometimes multiple times during the race day. Diff I generally rebuild before each race day. Some do it less frequently. Certainly more frequently than yours has!
Old 02-15-2016, 12:25 PM   #6944
spacendeman's Avatar
Send a message via MSN to spacendeman
If you go for new arms, check the XH arms. Those are the graphite arms.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 02-15-2016, 12:55 PM   #6945
CamLS's Avatar
The XH arms are so fragile I don't really see the benefit in them. The few tenths you might pick up isn't exactly a big reward for breaking and having a DNF in a big race.
CamLS is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
