Like Tree13Likes
Old 03-23-2015, 10:48 AM   #6751
scooby61's Avatar
Originally Posted by wwddww34 View Post
Yes I have had great luck with the RRS. I wrote about the RRS setup here in the Eryx 3.0 thread.
I'm running on a parking lot track medium grip would rrs work well on pavement? If I buy the rrs kit do I need additional parts to convert my eryx 2.0?
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 03-23-2015, 12:23 PM   #6752
Johnny Wishbone's Avatar
Can't comment on RRS on pavement, but the mount for the RRS uses the back holes of the chassis, so if you're running the 2 screw supported idler assembly, you would have to change to the newer motor mount/idler mount assembly to free up those two back screw holes.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-23-2015, 12:34 PM   #6753
Thanks for the help guys!
The links are very helpful.
Reading about all the different versions and setups tips is starting to make my head spin and falling into a black hole!!!
I guess different driver, different setup....
So, here is my understanding, versions starting from the most basic (oldest) to top of the line (newest)? Are all the parts interchangeable? The most noticeable different are Steering rack, motor mount, lower shock towers, shocks, servo mount, Diff gear....
S411 Sport
S411
S411 Team Edition
S411 Limited Edition
S411 Eryx 2.0 (how the hell do you pronounce this anyway???)
S411 Eryx 3.0
Still learning how to tune an engine......
Bingo883 is offline   Reply With Quote
Old 03-23-2015, 01:04 PM   #6754
wwddww34's Avatar
Trader Rating: 9 (91%+)
It can be pronounced two ways. \'eriks, or \'ir-iks
Do you know anybody with the name Eric? Well if you described his car as "Eric's" car, then that is the first way to pronounce Eryx.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 03-23-2015, 01:35 PM   #6755
Eric, E-Rex, Er-X, Ear-wax....
So many different versions of the car, so many ways to pronounce the names....
haha, good to know.
Old 03-23-2015, 08:49 PM   #6756
S411 Sport
S411
S411 Team Edition
S411 Eryx 3.0
With the exception of the 3.0 motor mount, everything else is a direct bolt on change. The 3.0 motor mount on a graphite chassis requires a very small modification to work, but very easy to do.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-24-2015, 05:58 PM   #6757
I don't think I will go with the 3.0 motor mount just because its a costly upgrade.
But am I safe to said using medium suspension pieces (arm, hub block...) will create less flex for the chassis which will put less stress on the separate motor mount on the TE?
Will this create too much flex for a medium traction, large, fast track?
Old 03-24-2015, 06:32 PM   #6758
Probably not. Also consider that you have two center leg options for that motor mount, so you can control your flex even more.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-29-2015, 10:56 PM   #6759
Seems like a lot of U.S. Dealers are out of stock on Solid Axle Drive Shaft SER401408, any replacement from other brands?
This part seems to wear out much faster than any other parts in the car.
Also, which brand of blades will last longer than the serpent ones?
Thanks!
Old 04-01-2015, 12:05 AM   #6760
Help guys...
I need the front spool axle out drive replacement but it's out of stock everywhere.
Any suggestion of other brands that will fit?
Which blade to use?
Thanks in advance.
Old 04-01-2015, 12:09 AM   #6761
dan_vector's Avatar
Trader Rating: 27 (100%+)
Help guys...
Which blade to use?
Thanks in advance.
The old style with the separate out drives was discontinued ages ago. You need to get the new style axle 401600.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-01-2015, 12:11 AM   #6762
dan_vector's Avatar
Thanks!
The newer batch serpent blades are a better plastic. I have no issues with the serpent blades and that's in the modified class. Probably get a full day of racing out of a set.
Old 04-01-2015, 01:19 AM   #6763
Benzaah's Avatar
Trader Rating: 21 (96%+)
I am having heaps of issues with the new spool and blades. If you punt a board and the blade gets damaged mid run by the time you finish your run the blade is toast and the out drive pin has hammered the so called hardened spool. I've chewed up 3 spools and 30 odd bucks a pop I'd rather the heavier old school version of the spool. Here's hoping we get the new bearing spool cup arrangement like the buggies are getting.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is online now   Reply With Quote
Old 04-01-2015, 10:54 AM   #6764
I picked up a v2.0 front axle from absolutehobbyz.com part # SER401380. It looks like they still have them in stock.
Ren13B is offline   Reply With Quote
Old 04-01-2015, 01:51 PM   #6765
I have gone back to old spool. Four wasted alu spools and tons of blades.
Linguster is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
