Old 08-05-2014, 03:49 PM   #6661
FullMetalGrave's Avatar
Trader Rating: 32 (100%+)
Originally Posted by snuvet75 View Post
Smaller,tight track: FDR 3.4-3.6
Large, long track: FDR 3.2-3.4
Body: Any VTA body will fit. Just reamer the holes where the posts are. Just decide how forward you like the body is. If you are an novice, I would put the front end of the body closer to the bumper than usual. That way, you get more stable rear end and less chance to break the front grill of the body during crash. But again, it depends on the body type.
Awesome thanks. I'll do some more research on figuring out the FDR. I know what it is but not how to use it.
Are there any paint templates out there for VTA? I can't paint bodies to save my life so I'm looking to find an easy way to do it.
FullMetalGrave is offline   Reply With Quote
Old 08-05-2014, 05:36 PM   #6662
Trader Rating: 14 (94%+)
FDR (final drive ratio)= DTR( drive train ratio) x Spur teeth number/pinion teeth number. S411 DTR is 2.
If you use 96 spur and want to make FDR 4.2 for example, 2x96/pinion=4.2 FDR. So 2x96/4.2 FDR= 45.7 pinion. So you can use 46 teeth pinion to get close to 4.2 FDR.
There are many paint schemes. But if you don't bother to make it nice, just buy one color spray paint and use it for entire body. To put some design, liquid mask or masking tape can be used.
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 08-06-2014, 03:21 AM   #6663
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by CamLS View Post
Sorry, I didn't know I wasn't allowed to run any 3rd party parts on my Serpent cars. Not like tie rods and ball studs are going to change the dynamics of the cars, but your concern is noted.
Sorry to sound anal but I am a fan boy. FWIW the xray parts are about 0.5mm shorter in height than the serpent parts. So yes all your camber angles and heights will be different and the new car is that good I would imagine you will feel a difference.
Originally Posted by Adam B View Post
A lot of people run other companies products. Springs for one.
This is another area where I keep coming back to the kit springs. I have all the xray, yoko, ride and Hpi springs. And IMO with the right tuning the kit blk grey are the money.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 08-10-2014, 06:55 PM   #6664
pullstarter's Avatar
Trader Rating: 14 (100%+)
Hey Guys,
Looking at buying the 411 ERYX 3.0 and have a couple of questions:
Which springs come with the kit?
What brand of spur gears fit these apart from genuine Serpent (need super small ones for 21.5, 48 pitch 55-60T)?
Thanks guys
Simon
pullstarter is offline   Reply With Quote
Old 08-10-2014, 09:12 PM   #6665
scooby61's Avatar
Anyone have a picture of the shrink-wrap cvd pin retainer? It would help me understand exactly how to do it. Lost pin cost me a main today that sucked.
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 08-11-2014, 04:50 AM   #6666
dan_vector's Avatar
Trader Rating: 25 (100%+)
If it was on the front then I'd upgrade to the V2 DJC's as they won't fail you. I've personally never lost a rear CVD pin as I loctite the retaining Allen screw. The shrink wrap method in my opinion restricts the freedom of movement of the shaft when not inline with the diff out drive. If you want to do it make sure you use fairly thin heat shrink and use a piece about 8mm wide and shrink down over the pin area. Do this before installing the axle into the hub. I think the v1 DJC heat shrink covers may work...
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-11-2014, 04:55 AM   #6667
dan_vector's Avatar
Originally Posted by pullstarter View Post
Hey Guys,
Thanks guys
Simon
Serpent Gray and Black 23mm TC springs come with the kit. The 2.0 had just grays.
Most 3rd party spurs fit.
Old 08-11-2014, 04:58 AM   #6668
dan_vector's Avatar
Benzaah,
I totally agree. There is absolutely nothing wrong with the stock Serpent parts. In actual fact I find them among the highest quality out there. Certainly on par if not better than xrays offerings. I don't really understand why people change out things as the slightly different sizes etc must have a detrimental effect on roll centers etc making it difficult to compare set ups with other 411 drivers!
I'd also agree that the kit setup black/gray is a great combo and it's always my starting point which I usually end up back with!
Old 08-11-2014, 05:02 AM   #6669
dan_vector's Avatar
On the 411 just go by Serpents handy FDR table!
http://serpent.com/file.php?FileID=5257
Old 08-11-2014, 05:26 AM   #6670
Thanks Dan much appreciated.
Old 08-11-2014, 10:04 AM   #6671
Johnny Wishbone's Avatar
Serpent has pins that are notched already or just dremel a notch into the ones you have. As far as the shrink wrap, I have to disagree on using the really thin stuff, as I used to do that and actually had a pin rip threw the thin shrink wrap. I have found that the shrink wrap that is slightly thicker, usually has a insulator in it makes for a much better pin retainer as the wrap sets up and feels a little stiffer than a thin shrink wrap. Not sure how your shrink wrap is restricting the movement as, if done correctly, it shouldn't effect the articulation of the joint at all.
Ultimately the new clip type are the best to use, but make sure you have the spring clips rotating the proper direction when using them.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 08-11-2014, 02:49 PM   #6672
dan_vector's Avatar
The shrink wrap method just isn't for me as there are better ways to do it. Using the notched pins or dremeling your own notch in the existing pin with decent thread lock should be all that's needed. I've never lost a pin on my 411 in either mod or stock.
Old 08-11-2014, 03:03 PM   #6673
scooby61's Avatar
Haven't seen the clip type. I already have the notched pins but bought the chassis used so not sure if the builder thread locked the set screws. I'm going take them all apart and I ordered the top racing cvd retainers I think this should take care of the issue right?
Losi 5T (awesome)
Old 08-11-2014, 03:12 PM   #6674
CamLS's Avatar
Benzaah,
I never said there was anything wrong with the stock Serpent parts, I was simply looking for alternates to use as the stock ones can be difficult to source locally in town (LHS doesn't stock any TC brand parts), let alone in Canada. I'm not sponsored, so I don't exactly have the resources to stock spares of every single little part of my Serpent TC's.
Saying 3rd party parts can't be used due to geometry/dynamics reasons is one thing, but to say they can't be used just because of the manufacturers name seems a little farfetched. Everyone I knows uses the Xray Hard foam bumper as the stock Serpent foam bumper is far too soft for the hard track boards that we use. Broken front suspension parts dropped significantly once I switched to the Xray hard bumper.
Serpent S411 Eryx 2.0 (Mod)
Serpent S411 Eryx 3.0 (USGT)
Serpent S411 Eryx 4.0 (Stock)
HPI RS4 Pro (shelf queen)
CamLS is offline   Reply With Quote
Old 08-11-2014, 03:27 PM   #6675
But if we are talking about the DJC there are no set screws used, so the only alternative is the shrink wrap or the spring clips. Please share your better way for pin retention.
Cam I'm using the stock Serpent bumper, even my car you ran in Calgary was on the stock bumper. Don't sweat the rest, you have to use what works for you, but I can say I'm 100% on all stock Serpent parts on the new car, its just some things need to be used in the right places.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
