Old 07-19-2011, 04:47 PM   #646
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by corallyman View Post
JayBee,
My LW LTC-R mounted just fine, Kody actually did it and it went smooth as buttahh. I actually have removed 1mm shim from behind the front arm, moving the arm towards the motor (shorter) and I moved 2mm of shims in front of the rear arm, thus moving the rear arms away from the motor.
My car is really good on its first and only run (dang rain out last week).
Steve
I guess I should've been more direct- are you guys running your bodies more forward or rearward? I don't know the cars inherent tendencies ie. steering characteristics. Especially on a low to medium bite parking lot, up to high bite asphalt conditions.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-19-2011, 07:25 PM   #647
skypilot's Avatar
Trader Rating: 14 (100%+)
I say wait 5 weeks and have Kody mount the body..
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-19-2011, 10:07 PM   #648
Originally Posted by Jamison R View Post
I really wanted to try front gear diff. Ordered gear diff from RcMarket and here is retrurn email. Serpent says there is no revision to diff case. RcMarket says different:
Dear Sir,
Your orders we'll processing.
you ordered ( SERPENT 401383 GEAR DIFF SET ) this item will delay release.
because Manufacturer they need change (this item the " case ") ,
so, their shipment will delay arrive.
When we receive this item, we'll send orders to you, OK ?
Best Regards,
www.rcmarket.com.hk
Thank you for choosing RC Market!
Not sure if I got a bad one but I got an extra gear diff for front. The one that came with the kit is perfect but the extra one I got the whole casing is not centered.... After mounting it on the car if you spin it the whole thing is going up and down by around 1mm.... And it leaks like crazy..... Yes, I had makes sure the 4 screws which hold the casing together is tighten evenly and the small gap between the casing is nice and even. Anyone have the same issue?
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 07-20-2011, 12:29 AM   #649
Yes, I have the exact same issue with the diff that came with the kit. :-(
Strats is offline   Reply With Quote
Old 07-20-2011, 03:35 PM   #650
Default Info
guys why the s411 has the 2.5mm frame? how about this frame?
biagio23 is offline   Reply With Quote
Old 07-20-2011, 04:25 PM   #651
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
confused on your question..sorry
OVA is offline   Reply With Quote
Old 07-20-2011, 09:56 PM   #652
oh boy.... Anyone try the new xray gear diff in the 411 yet? I think it will fit and it is only 16g..... Waiting for my friend to show up at the track as he got it and will let me test fit it.
Old 07-20-2011, 10:03 PM   #653
OVA
OVA's Avatar
I have tried..yes the NT1 or the new xray T3 will works...you have to added some shims to take the play out..and you must use the Xray universal dogbone c/t Serpent axles ...
or get the 12X5mm bearing ,if you want to use 100% xray drive axles..
Old 07-20-2011, 10:09 PM   #654
Trader Rating: 21 (100%+)
why use xray gear diff?
fastbynature is offline   Reply With Quote
Old 07-20-2011, 10:14 PM   #655
cause it is only 16g and smooth as silk. Thanks for the quick reply guys. Another parts to order then.
Old 07-20-2011, 10:20 PM   #656
OVA
OVA's Avatar
Only one reason why I did ..when I first got the kit.I was missing parts for my serpent gear diff..I wanted to run my serpent the followering weekend saturday.and I could not get any parts for my car back then until now.
I must say the serpent gear Diff is awesome...
I thanks to Scott K.
Old 07-20-2011, 10:23 PM   #657
OVA
OVA's Avatar
get the 50mm fit just right
Old 07-21-2011, 06:48 AM   #658
What shims do you have to use? (Part number?) Also, are the serpent and Xray dog bones the same length?
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 07-21-2011, 06:56 AM   #659
Pattojnr's Avatar
Trader Rating: 19 (100%+)
ive had an Xray for a little while, and in no way will i be putting anything Xray on my serpent. infact, apart from a battery retainer and blades, i will not put any other brand of parts on my car. i baught a serpent to get away from Xray. and that way it will stay.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-21-2011, 07:36 AM   #660
Trader Rating: 55 (100%+)
Jamison R is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
