Old 06-05-2014, 01:46 PM   #6571
patorz31's Avatar
I was thinking of picking up a Eryx 2.0, I was wondering if it could be updated to a 3.0?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 06-05-2014, 02:03 PM   #6572
wwddww34's Avatar
Trader Rating: 9 (91%+)
Yes you can update it. You'll need to buy the following:
  1. Motormount V4 (3) (#401607)
  2. Chassis 411 alu 2mm 7075T6 (#401608)
  3. Double joint cardan set V2 (2) (#401610)
Also the Eryx 3.0 comes with composite antiroll bar mounts instead of aluminum mounts in the 2.0. As far as I can tell the composite antiroll bar mounts are not available to buy alone.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 06-05-2014, 02:24 PM   #6573
patorz31's Avatar
Thanks Much Appreciated.
Old 06-06-2014, 10:38 AM   #6574
scooby61's Avatar
Does anyone know if the rrs kit is available in the USA yet?
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 06-06-2014, 10:56 AM   #6575
Johnny Wishbone's Avatar
I don't think so.
But also note, when I look at this kit the aluminum inner link holder will only mount to the older cars if you update to the new 3.0 motor mount as well. The literature on this is a little misleading as it doesn't mention that part. Says its a direct bolt on, but if your running the older idler pulley assemblies, the ones using the two lower bolts for mounting to the chassis there would be no way to mount the new part without cutting up the older aluminum parts to free up the holes.
I'm also pretty sure those are modified rear arms and not front arms like they say.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-06-2014, 11:21 AM   #6576
scooby61's Avatar
Originally Posted by Johnny Wishbone View Post
I don't think so.
Thanks I'll just wait till more info is avail.
Losi 5T (awesome)
Old 06-07-2014, 01:28 PM   #6577
nathan c.'s Avatar
I don't think so.
Serpent says it can be used with the new and old motormount. I aswell don't understand how you can manage that. I self find the kit a little bit weird, on the chassis they use a single piece alluminium block for attaching the links. this has the same effect as when you use the single suspension bracket at the rear instead of the 0/2 blocks. so flex changes when the kit is used.. when not always wanted. i will post a pic of how i managed the rrs system
Serpent
Eryx 2.0
f110
nathan c. is offline   Reply With Quote
Old 06-09-2014, 06:54 AM   #6578
buckeye dan's Avatar
Here are some pics of the RRS.
As best as I can tell the wheelbase did not change either, maybe 0.5mm if that. The other reason I did the mod to the rear arms was so I could swap out the RRS for normal rear uprights without having to change the arms.
did you use serpent tie rod ends ? how long was the tie rod? how long was the inside screw? is that a 2 mm spacer on inside mount?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 06-09-2014, 07:12 AM   #6579
RC MARKET's Avatar
New RRS System released !
Serpent S411-ser-401617.jpg   Serpent S411-ser-401618.jpg   Serpent S411-ser-401619.jpg   Serpent S411-ser-401620.jpg
RC MARKET is offline   Reply With Quote
Old 06-09-2014, 11:01 AM   #6580
Byronf1's Avatar
Do you recommend to upgrade the ball bearings to ceramic... ACER?
Serpent Project 4X - 748-TQ -S811 Be 2.1
Byronf1 is offline   Reply With Quote
Old 06-09-2014, 12:09 PM   #6581
Adam B's Avatar
Ceramic bearings should cut down resistance. I ordered Boca ceramics for the drive train bearings, but haven't installed them yet. In the states we use click track or some sort of barrier system on the carpet tracks. Because of that, I wouldn't run ceramics in the hubs as a tap could blow them apart. On asphalt, or in let's say Europe where they use dots and no walls, I would think they would be fine in the hubs also. Just my opinion though.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 06-09-2014, 08:56 PM   #6582
The rod ends are made by Traxxas (about the only make my LHS has any abundance in).
The tie rods are old Xray parts, I think they come from the T2 or early T3, they are about 16mm long.
The long screw I bought at our local bolt supply store, its metric but is a + type steel screw. Its 20mm long.
The spacer is a 2mm, although it doesn't sit flush on the suspension bridge, about a 1mm gap there.
The nylocks are regular 5.5mm nuts.
The mod works pretty good so far, no breakage on the modified arms, and the car seems to able to car pretty decent corner speed.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-14-2014, 05:59 AM   #6583
Has anyone seen a price on the rrs kit ? gotta believe gonna be pricey ... I will try johnny's mods first ty ..
Buckeye Dan
Old 06-15-2014, 09:15 AM   #6584
paintchip31's Avatar
Trader Rating: 434 (100%+)
Send a message via ICQ to paintchip31
Alright Guy's I have done a search on here and looked for a good bit of time and have not found what I have been looking for. I have the eyrx 2.0 and bought it used. I ran it for the first time yesterday. The steering bell crank keeps popping off the bearings can anyone tell me where to find the fix for this please?
I have spent 3 hours looking for this but there is a lot to read on here about this car!
Heart of a hustler racing
TRICK GRAPHICS
The Loft RC Raceway ~ Columbus, OH ~ www.TheLoftRC.net
sponsored by
http://teameamotorsports.com/
paintchip31 is offline   Reply With Quote
Old 06-15-2014, 09:53 AM   #6585
Trader Rating: 14 (94%+)
I had the same problem too.
Put a layer of plastic bag over the bearings first, put the crank over them and push it in, the plastic must have been cut at the edges of the bearings, then remove the cut plastic pieces on top of bearing and you r done.
If that doesn't work, lift the crank safely from the car, put a drop of super glue on inner layer of holes where bearings go in and reinstall w bearings. When u do this, push into the bearings rather quickly and use plier to push the crank all the way down. Just be careful w glue or u may ruin the bearings.
Personally the plastic bag worked only for a short time but many say otherwise. Good luck.
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
