Old 05-29-2014, 04:04 PM   #6556
mazmo's Avatar
Benzaah.
Will have a look mate.
Won't be able to check till Saturday though.
Cheers
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 05-30-2014, 12:29 AM   #6557
Trader Rating: 14 (94%+)
Originally Posted by mazmo View Post
Hi all.
Spur gears. What other brands will fit the Eryx 2.0?
Need 58t 48p for 21.5
Thanks in advance
The ones with 6, 9, 12 holes. Xray, Kimborough, Precision racing, etc.. It might be hard to come by 58T, 48P gear that fits to Eryx, is it not? Try 74-78T 64 spur.
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 05-30-2014, 12:58 AM   #6558
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by snuvet75 View Post
I've heard some complain about the spur holders. What is exactly the problem?
If you look at the pic I posted you can see the front holder fouls the top deck and the back holder has been ground and clears the deck. I would have thought my post was self explanatory.
Benzaah.
Cheers
Mate, what's the go with your sig? Are you still running the red sled? Time to represent in your sig!
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 05-30-2014, 08:38 AM   #6559
mazmo's Avatar
lol .. ok will address .. in transition
My son is still red but raced eryx 2 tonight and liked it.
went faster too. Seems another eryx will be in the works soon.
He'll run the 2 again next week and decide.
Old 05-30-2014, 08:44 AM   #6560
mazmo's Avatar
cool thanks
Old 05-30-2014, 02:59 PM   #6561
LOW ET's Avatar
Trader Rating: 94 (100%+)
the complaint about the spur holder is the side to side play when everything is assembled. nothing two thin shims can't fix. this was on the s411 2.0 eryx, not sure if all of them were this way but the first few released had it.
LOW ET is offline   Reply With Quote
Old 05-30-2014, 03:22 PM   #6562
Oh now I can see. I didn't know what you meant by "Fouling" since it's not a specific term. Maybe I should check mine too.
Capricorn LAB C03
Old 06-01-2014, 10:24 AM   #6563
nathan c.'s Avatar
After seeing Johnny's version of the RRS I tried the same. The only thing i did different is that I dremeled material away on my c-hub instead of the arms, to keep some of the flex characteristics of the suspension arm. After a short test I can say that the car handles really wel, the car has crazy corner speed and is very stable wich makes it forgivable as well. I hope to test some more with this modification. Good thing that serpent will produce this as upgrade, the only thing i'm "scared" of is that they will again come out with new suspension arms, already have enough arms that i can't use because there are newer versions, however the evolution of the arms is good
Serpent
Eryx 2.0
f110
nathan c. is offline   Reply With Quote
Old 06-01-2014, 01:21 PM   #6564
jdawg81's Avatar
I have a Serpent S411 ERYX and I noticed that the wheelbase is a bit shorter when I was trying to line up a touring car body to make new mounting holes. It's not a big deal as I can trim the wheel wells to match the car. Is this normal for all Serpent cars?
jdawg81 is offline   Reply With Quote
Old 06-02-2014, 12:59 AM   #6565
JAM Racing's Avatar
no its a bit of a different body thing some fit better than others but it the same same with different manufacturers cars as well
focus on gettin the front right and the rear ends up where it has to go
What type of body???
Tourer or VTA
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 06-02-2014, 07:06 AM   #6566
jdawg81's Avatar
Tourer or VTA
I was using this car for vta and the Ford Mustang body fit just fine. But the Protoform Mazda touring body I tried to mount would not line up. With the front wheels lined up with the body, the rear wheels are a bit too far forward so I have to trim the body a bit. So I compared it to my other car and it is a bit shorter so just wondering if this was normal for serpent cars.
Old 06-02-2014, 09:29 AM   #6567
Johnny Wishbone's Avatar
Yes, the car has a shorter WB out of the box, but use the adjustment to fine tune for different tracks.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-02-2014, 12:08 PM   #6568
cwoods34's Avatar
I usually run a long wheelbase on mine. Car's way more stable on-throttle when you do this
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 06-03-2014, 06:56 AM   #6569
jdawg81's Avatar
That's good to know. I bought my car used so I wasn't sure if it was assembled differently or correctly. I am thinking the shorter wheelbase will help the car rotate and turn better on tight technical tracks.
Old 06-05-2014, 11:25 AM   #6570
Byronf1's Avatar
The RRS is oficial at serpent.com
Serpent Project 4X - 748-TQ -S811 Be 2.1
Byronf1 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
