Old 05-26-2014, 05:44 PM   #6541
cwoods34's Avatar
Originally Posted by Johnny Wishbone View Post
Going to the front arm in the rear makes the shock angle placement quite a bit different and leaning the shock in is really reduced, that with either the new or old style front arms. For this reason I modified a set of rear arms to accept the c-hubs and steering blocks.
How exactly did you modify the arms? It looks like you could simply Dremel the webbing so that the caster block fits but I think this may allow the arm to flex too much. I have all of the parts to do this, but it would be bad to have super-flexible arms at my home track given how high the traction is. However, running only 2* or so of static rear toe may offset the slight increase in flex.
If you have pics, I'd like to see what you've done
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-26-2014, 06:54 PM   #6542
Johnny Wishbone's Avatar
Yes, cut out some webbing and a small relief for proper clearance. I used a set of the older medium arms just to mock it all up. Not sure what the flex characteristic of them are but it seems the durability is there as I hit a few things running this setup and broke nothing so far.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-26-2014, 07:21 PM   #6543
Adam B's Avatar
+1 on pictures please.
Johnny, I think the castor in the rear will have a bigger effect on your wheel base then it will on anything else.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 05-27-2014, 06:51 PM   #6544
Default RRS Pics
Here are some pics of the RRS.
As best as I can tell the wheelbase did not change either, maybe 0.5mm if that. The other reason I did the mod to the rear arms was so I could swap out the RRS for normal rear uprights without having to change the arms.
Serpent S411-dscf0428-2-.jpg   Serpent S411-dscf0429-2-.jpg   Serpent S411-dscf0430-2-.jpg   Serpent S411-dscf0431-2-.jpg   Serpent S411-dscf0432-2-.jpg
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-27-2014, 07:05 PM   #6545
Default A few other mods.
The first pic is showing the idler pulley bearing holder with 1mm taken off the top, done on both sides, just to get everything from touching the top deck.
Pics 2 and 3 show a tapped hole I put into the steering servo holder, with a spacer and drilling a hole into the top deck I get a front standoff option for more adjustments.
Pic 4 shows how the motor mount leg has to be cut to work with the V3 motor mount. Still allows top deck secured to the standoff, but gives you full access to the motor screws for those big pinions.
Serpent S411-dscf0433-2-.jpg   Serpent S411-dscf0434-2-.jpg   Serpent S411-dscf0435-2-.jpg   Serpent S411-dscf0436-2-.jpg
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-27-2014, 08:59 PM   #6546
Phoenix82's Avatar
Nice explanation Johnny. Hey guys, I saw the car run. looked real good.
Nick K
Phoenix82 is offline   Reply With Quote
Old 05-28-2014, 08:06 AM   #6547
Byronf1's Avatar
looks great... so RRS is about you did ?
Serpent Project 4X - 748-TQ -S811 Be 2.1
Byronf1 is offline   Reply With Quote
Old 05-28-2014, 03:25 PM   #6548
cwoods34's Avatar
Exactly how mine is looking.
However, my 3.0 showed up last night so that now has priority
Old 05-28-2014, 03:35 PM   #6549
Trader Rating: 14 (94%+)
Where did you get the 3.0 from??
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 05-28-2014, 04:16 PM   #6550
Adam B's Avatar
Got mine last week and haven't opened the box yet. Stupid life keeps getting in the way.
Old 05-28-2014, 04:49 PM   #6551
cwoods34's Avatar
priorities man, what's wrong with you?
Old 05-28-2014, 07:02 PM   #6552
tiago890's Avatar
Hey guys have my s411 TE for sale if anyone is interested
Serpent s411 TE rtr or roller
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 05-29-2014, 01:26 AM   #6553
Benzaah's Avatar
Trader Rating: 21 (96%+)
Can someone who has a new and old kit measure the bulk heads and tell me if there is much difference in the new parts? Whether the diffs sit higher or lower in the new bulks is my main query. Also if the new spur gear holders are different to the old ones. I'm converting a 2.0 with the new chassis and motor mount only. My spur holders are fouling the top deck I have one that was modified that doesn't foul the deck. Time to call up a favour with my Dremel owning buddy.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 05-29-2014, 09:30 AM   #6554
I've heard some complain about the spur holders. What is exactly the problem?
Capricorn LAB C03
Old 05-29-2014, 04:01 PM   #6555
mazmo's Avatar
Hi all.
Spur gears. What other brands will fit the Eryx 2.0?
Need 58t 48p for 21.5
Thanks in advance
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
