Old 04-19-2014, 07:11 PM   #6436
cwoods34's Avatar
Originally Posted by Benzaah View Post
I was never doubting anyone's ability to set up a car. It was actually a question not having a crack! You did see the ??? Right? so yeah Adam can set up a car but by the sounds of it he can't drive it himself lol (sarcasm)
From my experience a harder rear than front has helped due to the huge side walls In the rear tyres. Seeing as I'm not American and I don't run these name dropped events I'll just crawl back in my hole yeah!
You forgot to use the sarcasm font! So either way it's your fault
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 04-21-2014, 12:44 AM   #6437
svndayNZ's Avatar
Trader Rating: 20 (100%+)
hi, a quick question for anyone that can answer it. I took my S411 down to the local track today, got halfway through a pack and was finding the thing an absolute pig to drive. It was spinning like top on the track. Letting go of power would see it swap ends. The kit is largely setup as stock so I pulled it off lay the back springs down put some softer springs on the back and tried again, absolutely nothing happened.
Was still horrible, one thing I struggle with having only owned tamiyas is how to setup these sway bars. I feel some of the lack of traction in the rear comes from A. The sway bars B. The front being too soft so the weight is transferring to the front too much.
It's the FF version but the principles remain the same, anyone have a video / link on setting up serpent sway bars?
Cheers
Dane
svndayNZ is offline   Reply With Quote
Old 04-21-2014, 12:44 AM   #6438
svndayNZ's Avatar
Cheers
Dane
Old 04-21-2014, 01:13 AM   #6439
Trader Rating: 22 (100%+)
Cheers
Dane
There is a thread specific for the FWD version. This thread is for the 4WD version.
You can find it at SERPENT S411 FWD
However to answer your Q the Sway bars are easy to set up. Start with the rods equal length and ensure the downstops are set correctly. Then with the wheels off the ground connect the sway bar and make sure there is no bias left or right. Adjust as required. Finally connect the shocks and tweek out the car as normal.
Also bring in the UK the grip is probably very low and so you'll need to set the car accordingly. What tires were you using?
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-21-2014, 05:09 AM   #6440
svndayNZ's Avatar
Thanks I saw that, but that thread is barely ever watched or commented on.
Thanks for the advice on sway bars. So far it's not well setup at all. But I'll get to work on it see what I can do. Thanks again
Old 04-21-2014, 05:12 AM   #6441
Yeah definitely something way out of wack. Reset it all to kit standard and make sure you set with accurate gauges etc.
Old 04-21-2014, 07:55 AM   #6442
scooby61's Avatar
Just getting my 411 eryx 2.0 up and running and haveing read through most of this thread I see a lot of posts about the slop in the center shaft. Is there a final solution to this issue and is it a performance damaging problem? I couldnt find a definite answer in the thread if any has some insight on this I would appreciate it. Found a YouTube video whee the guy said that the bearing carrier for the TE would fix it but all the part numbers I find are the same.
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 04-21-2014, 10:46 AM   #6443
Johnny Wishbone's Avatar
Not really sure of this problem, but as long as the spur gear doesn't hit the edges of the top deck, having a bit of float in the center shaft is not a problem as it allows the pulleys to follow the belts.
If the side to side movement is enough to hit the top deck edges you can either shim the center shaft or file the top deck enough to allow clearance.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 04-21-2014, 10:51 AM   #6444
scooby61's Avatar
Didn't seem like a serious issue
I think I was confusing the posts about the steering rack but it does seem to have a lot of play in that center shaft but no where near enough to hot the deck.
Losi 5T (awesome)
Old 04-21-2014, 07:26 PM   #6445
Trader Rating: 89 (100%+)
17.5 blinky mode carpet track 30-40ft straight some technical areas. What should be a good start for gearing. Thank you guys
..x-ray xb4 2014....rt6....sct410...eb48.2....et48....tc4 vta....rc10 gold pan re-release ....TF2 and D90 scale trucks..scx10 .mcculloughs in sarver pa.
Revo Dan is offline   Reply With Quote
Old 04-21-2014, 07:58 PM   #6446
cwoods34's Avatar
40ft?
Depends on motor, but that short of a straight start at 4.2ish. I ran an R1 at a 4.0 (max timing) on a 65x40ish track on Friday and the gearing felt good. Add teeth from there as necessary.
Old 04-22-2014, 03:43 AM   #6447
Tekin gen 2
Old 04-22-2014, 08:45 AM   #6448
I'm new to this so do you think 80 spur and 38 pinion
Old 04-22-2014, 08:59 AM   #6449
I'm new to this so do you think 80 spurge and 38 pinion
http://www.serpent.com/file.php?FileID=5257
Here is the FDR calculator which will allow you to select the right spur/pinion for the 411.
38/80 in 48dp would give you 4.2 but I doubt it'll fit unless you have the v3 motor mount.
Old 04-22-2014, 05:09 PM   #6450
Adam B's Avatar
Oops....
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
