Old 07-18-2011, 04:19 AM   #631
Originally Posted by JayBee View Post
Great build; finished up a day or so ago and no hiccups. Great job Serpent Now to go shake it out on the track
Btw....when comparing the main chassis to my TC6, is was about 8mm shorter. Anyone else do any comparisons in that dept.?
Alot of people have mentioned it is quite short.... I was thinking of testing it longer and longer as it has a fair bit of adjustment but right now I have the rear at full length to give a bit more weight over the front.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-18-2011, 07:19 AM   #632
cheehtae's Avatar
Trader Rating: 15 (100%+)
where do you guys buys your spares at?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-18-2011, 07:47 AM   #633
RC MARKET's Avatar
Metal Cell Support for S411
RC MARKET is offline   Reply With Quote
Old 07-18-2011, 07:50 AM   #634
RC MARKET's Avatar
We had support 95%+ parts keep stock !
http://rcmarket.com.hk/index.php?cPath=51_98_156_319
Old 07-18-2011, 10:00 AM   #635
gearhead_22's Avatar
Send a message via AIM to gearhead_22
ok serpent the nats are next week, I would like to have some parts for back up here in the US. I ran the car this week and it held up very well,everyone at the track was waiting for it to break, fooled them even when I was slamed it to a wall by another driver it stayed together. I liked the way the bottom bummper was made. I give the car an a++++++++++++++++++. Now can we get some parts. thank you very
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 07-19-2011, 03:11 AM   #636
Trader Rating: 55 (100%+)
I really wanted to try front gear diff. Ordered gear diff from RcMarket and here is retrurn email. Serpent says there is no revision to diff case. RcMarket says different:
Dear Sir,
Your orders we'll processing.
you ordered ( SERPENT 401383 GEAR DIFF SET ) this item will delay release.
because Manufacturer they need change (this item the " case ") ,
so, their shipment will delay arrive.
When we receive this item, we'll send orders to you, OK ?
Best Regards,
www.rcmarket.com.hk
Thank you for choosing RC Market!
Jamison R is offline   Reply With Quote
Old 07-19-2011, 06:06 AM   #637
mattwoodcraft's Avatar
im getting some of these battery straps the alloy ones good thing.
i have seen the gear diffs in the front of the serpents all ready here running about
mattwoodcraft is offline   Reply With Quote
Old 07-19-2011, 06:47 AM   #638
How do you like the front gear diff?
Old 07-19-2011, 06:48 AM   #639
Not the gear diff. It says in stock, but its not. Read my above post
Old 07-19-2011, 06:56 AM   #640
Dear Sir,
Best Regards,
www.rcmarket.com.hk
I placed an order form them yesterday and I was going to order that part gald I didn't I would be really
Old 07-19-2011, 07:03 AM   #641
snoopyrc's Avatar
Did we ever figure out what parts will support the S400 from the S411? Can I use arms and C hubs and steering knuckles? How about Belts and CVD's?
Or can I get parts for the S400 again?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 07-19-2011, 07:09 AM   #642
I have both cars and the s411 takes a smaller outer bearing on the steering knuckles and cvd. now if you can put the hole arm, c hub, and all on it i haven'ttried it yet, but to me it look like it fits.
Old 07-19-2011, 02:48 PM   #643
JayBee's Avatar
Trader Rating: 31 (100%+)
So since these cars are a bit shorter, how are you guys mounting your bodies?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-19-2011, 03:49 PM   #644
corallyman's Avatar
Trader Rating: 99 (100%+)
JayBee,
My LW LTC-R mounted just fine, Kody actually did it and it went smooth as buttahh. I actually have removed 1mm shim from behind the front arm, moving the arm towards the motor (shorter) and I moved 2mm of shims in front of the rear arm, thus moving the rear arms away from the motor.
My car is really good on its first and only run (dang rain out last week).
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 07-19-2011, 04:27 PM   #645
No kidding.
-Mike
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
