Old 04-11-2014, 02:35 AM   #6421
monkeyracing's Avatar
It does help, thanks. Won't get at it this week, but it's a good future consideration. As it sits, i was able to feed a driver through a hole in the spur. Ugly angle, but the job got done.
Funny thing I learned about Serpent tonight. Serpents international distributor is Team Titan. They also do Arc, Blitz and a few others. Interesting knowledge.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 04-11-2014, 02:40 AM   #6422
Trader Rating: 22 (100%+)
No problem. Good luck.
When you get a few hours have a look back over the thread as there are some really good hints and tips in running the 411 over the pages.... Certainly helped me when I started running mine (came from 1/8 Onroad gas!).
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-11-2014, 10:19 AM   #6423
Hey, new Serpent owner here. (I blame Steve) I picked up a pair of used S411 v1 and I've got questions about how things go together. Be gentle, it's my first grown up TC.
I'm using an Arc 64p 96t spur gear, with a 47t pinion, to start out with an FDR of about 4.1. The first problem i ran into was mounting the motor. With the spur in place, I couldn't get the rear motor screw into place. I ended up removing the motor mount, attaching the motor to it and reinstalling the assembly.
The second issue occurred when installing the pinion. In order to fit the pinion in place, I had to loosen the rearward section of the top plate to gain clearance to slide the pinion onto the motor shaft.
Thirdly (and finally) was setting the mesh and tightening the motor down. The forward motor screw was easy enough to reach, but getting to the rear screw proved difficult, as the spur gear was again in the way.
I guess I'm wondering if I missed something or did something wrong. Should I have invested in larger spur gears? (I call it invested, as these things were $10 each!)
Hey Jim, you actually need a smaller spur/pinion combo to avoid all the fit issues. The smaller pinion won't interfere with the top deck, and it will make the rear motor screw align with the hole in the spur. I typically use a 86 or 88 spur for gearing in the 3.7-3.9 range.
Team Serpent
Steve S is offline   Reply With Quote
Old 04-11-2014, 02:59 PM   #6424
cwoods34's Avatar
I recommend this motor mount.....
http://serpent.com/product/401601/
Or buy these spur gears.....
http://www.teameamotorsports.com/ind...product_id=122
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 04-14-2014, 09:22 AM   #6425
nathan c.'s Avatar
Ehrbar used the alu chassis already on the ETS in Germany, his car went really good. But I don't think it should be a standard part in a kit, maybe more as an option...?
Serpent
Eryx 2.0
f110
nathan c. is offline   Reply With Quote
Old 04-15-2014, 12:03 PM   #6426
scooby61's Avatar
hey guys, just purchased an eryx 2.0 used but in good shape. I plan on running it in modtc on a med grip asphalt track. probably with a 4.5t motor. can some one suggest a setup sheet to give me a good starting point for tuning. I love my Cobra GTE and cant wait to get this one up and running. and maybe a some gear selections not sure if I should run like a boosted setup with around a 8 fdr or all motor around 6 something.
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 04-15-2014, 05:41 PM   #6427
Adam B's Avatar
Anybody have news or info on the 3.0? Like when it will be released, or exactly what it comes with?
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 04-16-2014, 10:29 PM   #6428
svndayNZ's Avatar
Trader Rating: 20 (100%+)
hi all,
Does anybody know where to get a gear cover like this FF has on it?
http://www.rc-news.de/wp-content/upl...1-FF-RTR-1.jpg
I'm looking for one for mine..
svndayNZ is offline   Reply With Quote
Old 04-18-2014, 03:05 PM   #6429
buckeye dan's Avatar
Hi guys i have 2 serpents the one is for 17.5 the other is vta . 17.5 is hooked up and runnig well. looking for some setup help for the VTA anyone have good setup sheets for VTa carpet?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 04-18-2014, 07:47 PM   #6430
Adam B's Avatar
I would duplicate your 17.5 set up. Then see how it handles and adjust from there.
Old 04-19-2014, 01:58 AM   #6431
Benzaah's Avatar
Trader Rating: 21 (96%+)
When you have tyres as vastly different how can similar set ups work? Pm sent to op.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 04-19-2014, 05:27 AM   #6432
Adam B's Avatar
Yes the tires are different, as is the carpet in the USA to most other places. The OP profile shows they live in Ohio. I know of 3 tracks in Ohio with vastly different grip levels.
I guess I don't know much about setting up cars. Cars I have set up have only won snowbirds, and the USVTA southern nats. And I did duplicate one of my 17.5 set ups.
Old 04-19-2014, 12:57 PM   #6433
cwoods34's Avatar
I'd also start at a 17.5 setup, and if the track has good traction start taking out rear toe. Also try stiffer springs and/or swaybars (dependent on traction levels) but other than that it should be really close.
Adam B knows a few things about setup
Old 04-19-2014, 04:54 PM   #6434
Benzaah's Avatar
I was never doubting anyone's ability to set up a car. It was actually a question not having a crack! You did see the ??? Right? so yeah Adam can set up a car but by the sounds of it he can't drive it himself lol (sarcasm)
From my experience a harder rear than front has helped due to the huge side walls In the rear tyres. Seeing as I'm not American and I don't run these name dropped events I'll just crawl back in my hole yeah!
Adelaide RC
Walter Rc Hobby
Old 04-19-2014, 06:35 PM   #6435
Adam B's Avatar
Never has there been so much truth in one sentence. HA
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
