Old 01-15-2014, 04:18 PM   #6211
I'm using the 5 spoke wheels, 13815 front and 13820 rear. I thought all the vintage series wheels were the same width and offsets, but never tried different styles of vintage wheels.
Also, to use my wider wheels hexes, I had to drill the 5mm axle hole all the way through the hex. The serpent axles have a step up to a larger size, and the hexes I'm using bottom out on that before the drive pin bottoms out in the cross slot.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 01-15-2014, 07:18 PM   #6212
snuvet75's Avatar
Trader Rating: 14 (94%+)
I think you're right. They have to be the HPI wheels and tires. I also have to shim out in the front wheels to avoid contact.
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 01-15-2014, 10:16 PM   #6213
Default S411 RTR upgrade
Hi guys I have purchased a RTR S411 recently. Due to budget constraint I am not getting a top of the line S411 model. Having said that, I am looking at a modest upgrade. What are the few essential parts that can bring it up to a more level playing field with the others? Thank you in advance for the advise.
F8Crusader is offline   Reply With Quote
Old 01-15-2014, 10:20 PM   #6214
dan_vector's Avatar
Trader Rating: 26 (100%+)
First upgrade I would do is go for the DJC front axles and put the current front Cvds in the rear. Other than that I'd just run it as it is and see how you get on! Good luck.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-16-2014, 01:50 AM   #6215
Holmenkollen's Avatar
We have a track with a fast chikane and my car "sits" in the middle of it, it scrubs a lot of speed. The front end dives in the middle. Setup tips?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 01-16-2014, 05:06 AM   #6216
peter george's Avatar
Trader Rating: 344 (100%+)
Default silly question
I have had a S411 LE and trying to decide about getting some spare parts. Any S411 parts are a direct fit right ? Does anyone know what the main diferences are from the 411 and the 411LE ? Thanks.
Team Underdog-Team UPURZ-Island Raceway & Hobby-If we trade lower feedback always ships first.#41-#18.HPI Pro-3- Associated B6-B5m-X-ray Xb2-CRC-Durango DEX210-DESC210-Intech-Tylenol-Pizza
peter george is online now   Reply With Quote
Old 01-16-2014, 05:36 AM   #6217
gearhead_22's Avatar
Send a message via AIM to gearhead_22
the first 411 and the LE are the same car
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 01-16-2014, 05:42 AM   #6218
Thank you sir
Old 01-16-2014, 06:05 AM   #6219
chicky03's Avatar
Send a message via AIM to chicky03
Maybe stand the front shocks up or stiffer front spring or oil.
Same for the back if the back is rolling too much,
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 01-16-2014, 08:48 AM   #6220
Johnny Wishbone's Avatar
Yes, these are HPI wheels and tires as well. I even took my car apart to show the other Serpent VTA driver here as we really couldn't see a wheel difference either, his where the 5 spokes and I had the black mags. But if its shims you need for clearance so be it.
I also had posted a while back that if you use some other brands of hexes that you'll have to drill all the way thru because of the stepped axle on the Serpent car. I have used the Xray hexes as the pin depth is correct and causes no bind issues between the hex and the hubs.
The only major difference between the (S411,S411V2,S411LE) and the S411TE is the shocks. The first cars all had the RCXX shocks or bottom loader shocks, the S411TE came with the RCM shocks or top loader bladder type shocks. Of course as the cars progressed there where factory change ups or parts upgrades such as motor mounts and gear diffs. The the S411 2.0 Eryx with the lowered shock towers and short shocks being the most current car.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-17-2014, 11:24 AM   #6221
Default V3 diff to tight
I have tried Gebrits tip to use the ARC o-rings in the diff. Then you have a smoth action on the outdrives. The drawback is that they leak. I also used the ARC diffhouse with better function.
At the DHIcup I built 3 new diffs, all of them stock. All three where ruff in in action. I took them appart several times and rebuild them with new o-rings with no improvements. I noticed that it was hard to get the pin into the outdrive shaft. I tried to sand of the outerpart of the diffhouse but it did not improve. I had to use one of my old diffs that are tight in the O-ring.
I have found out the problem, after taken appart old V3 diffs I realize that the bigger shim is 0.3mm thick on the 5 new set that I bought last right before christmas. Looking at my old used diffs and new ones that I have in bag they have a 0.2mm shims.
I get a little frustrated that I wasted many hours at DHI trying to accomplish something impossible. I wounder if there is a logical reason behind switching to 0.3 shims?
Linguster is offline   Reply With Quote
Old 01-17-2014, 04:47 PM   #6222
snuvet75's Avatar
My 747 has the same problem with the wheel hexes. It came with -0.75mm hex in the front and regular foam tire wheels touched the steering blocks. I had to put 1mm shims to get the clearance. Now I installed +0.75mm offset hexes so I don't need the shims anymore. These little things from Serpent always annoy me but well, every car has its own downsides I guess.
Old 01-19-2014, 07:42 PM   #6223
tiago890's Avatar
First time on the track today after a month and half off, put the djc's on last night And the difference was like night and day. Car handled better into and out of the turns which actually got me a few extra seconds on the race and 1 extra lap. Any one have any good solution to fix the leaking diff, besides replacing it with something else,
Cheers
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 01-19-2014, 07:43 PM   #6224
tiago890's Avatar
Cheers
Old 01-19-2014, 10:10 PM   #6225
jdawg81's Avatar
Default Front wheel nuts keep coming loose
I've been racing my S411 ERYX for a few months and I've noticed that the front wheel nuts always become loose. If I don't remember to tighten them back down after each race they just keep getting looser until the point it falls off along with my wheel. I've tried different wheel nuts and that hasn't helped at all. Is anyone else having this issue?
jdawg81 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
