Old 12-13-2013, 10:25 AM   #6136
dan_vector's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Jim Frahm View Post
Are these in stock anywhere in the US?
Thanks,
Jim
Also here:
http://www.amainhobbies.com/product_...V3-Motor-Mount
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-13-2013, 11:14 AM   #6137
Default My New Eryx must have been made on a monday...
Back after training with the new Eryx. I am now at 20 runs with it and it is not working at all.
Two things sorted out, the shocks and the DJC axles. The outer Kyosho bearings will not make the pin rub on the bering. And picking the 4 o-rings out of 3 bags with the least resistance.
But new things occur. Running with Hagberg, Vässmar and Nilsson. I was all over the track, really "showing off" the beginner I am.... I could not run a consistance lap. Home again pulling the car appart.
Noticing that the arms are very "loose" on the inner pivot pin and that the steering rack was very loose even with the plastic bag "trick"
Comparing with my older Eryx's there is not near the slope in their arms. I have probably 300 runs on each of them. Now in the middle replacing front and rear arms with older "newer" medium arms. They have a nice snug fit on the pivot pin. The kit arms has M engraved, they seems to be from a really lousy batch.
I also tryed ones that are engraved with M of my spare parts. They do not fit snug on the pivot pin. I needed to look through my spares to find the older "newer" arms. The ones where the lid that holds the swaybar arm did not fit directly without modification.
If I understand correct, the idea is that the pivot pin should move in the pivot ball not that the arm should rotate on the pivot pin.
Linguster is offline   Reply With Quote
Old 12-13-2013, 11:51 AM   #6138
Johnny Wishbone's Avatar
Comparing with my older Eryx's there is not near the slope in ther arms. I have probably 300 runs on each of them. Now in the middle replacing front and rear arms with older "newer" medium arms. They have a nice snug fit on the pivot pin. The kit arms has M engraved, they seems to be from a really lousy batch.
I also tryed the ones that are engraved of my spare parts. They do not fit snug on the pivot pin. I needed to look through my spares to find the older "newer" arms. The ones where the lid that holds the swaybar arm did not fit directly without modification.
I had one arm that seemed a little looser than the other three on my car, seemed to not have a lot of time on it either. I ended up removing the arm and running some fast glue down the pin hole, let it dry and then used a 3mm reamer to reopen the hole to the proper size and angle. Put it back togeather and haven't had a issue with it since.
Thats correct, the pin should be snug in the arm and only pivots in the pivot ball.
You may have to re-do the steering rack with the bag mod but double up on the thickness to get all the slop out.
Then you should be able to go out and beat those guys.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-13-2013, 11:56 AM   #6139
The slop bugs me too, but I can never feel the difference on the track. I wouldn't worry about it too much.
Team Serpent
Steve S is offline   Reply With Quote
Old 12-13-2013, 02:16 PM   #6140
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Send a message via Yahoo to Jim Frahm
Thanks guys! V3 mount on the way.
Jim
Serpent S411 ERYX, Reedy 25.5, FLOW
AE 12R5.2, Trinity 17.5, ORCA
Jim Frahm is offline   Reply With Quote
Old 12-13-2013, 03:32 PM   #6141
chicky03's Avatar
Send a message via AIM to chicky03
The best thing I have found to cure the steering rack slop and have it stay good for a really long time is:
super glue the flanged bearings into the rack, top and bottom, You only need a little glue so it does not run all over the place
use the .13mm shim from this set and put one on the top of each of the flanged bearings http://www.amainhobbies.com/product_...pacer-Shim-Set
use a 3x5x.2mm shim in between the pressed in bearing and swing arms.
This way there will only be the play thats in the ball cups.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 12-14-2013, 08:40 AM   #6142
Danny-b23's Avatar
I think I speak for most of the WCICS drivers when I say; please, don't make your car any faster then it is already.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 12-14-2013, 10:11 AM   #6143
Hey man, somebody has to stop Wayne Mah
Team Serpent
Old 12-14-2013, 02:41 PM   #6144
dawgmeat's Avatar
What is the ideal body for carpet racing, I'm still trying to get up to speed from my long layoff from racing, thanks
dawgmeat is online now   Reply With Quote
Old 12-14-2013, 03:40 PM   #6145
Akhor's Avatar
Around here everyone runs the Mazda speed 6
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 12-14-2013, 05:01 PM   #6146
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
too bad you and wayne wont be at round 5 steve. its gonna be fricken epic this year.
not too much love for the serpent around here. i think only two in our club but a few more on the mainland.
i definitely wont be making a stab at the podium this year. but making the a main would be fantastic.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 12-14-2013, 06:46 PM   #6147
dan_vector's Avatar
In general I start with the Mazda Speed 6 on carpet and the LTC-R on asphalt. I will however try the other body on both surfaces to compare at some point during the day. I find the speed 6 is a very balanced body whereas the LTC-R has a bit more front end which can make the rear end loose on carpet.
Old 12-14-2013, 07:40 PM   #6148
dawgmeat's Avatar
Old 12-15-2013, 12:53 AM   #6149
Default 0,2 seconds "found" with snug pivot pins in arms but stilll 0,2 short
Back at the track again yesterday, "new" Eryx easier to drive but still slower compared to when I switch to older Eryx.
Back to taking the car appart and try to find/figure out where the "missing" time is.
Old 12-17-2013, 04:55 AM   #6150
Benzaah's Avatar
Trader Rating: 21 (96%+)
IMO running 2 cars in the same class is counter productive and you lose focus when tuning set up. 0.2 is starting to split hairs and could be many places in the car. My first query is are both your motors equal? Ie I have 3x d3.5's and 1 is definitely quicker than the other 2 at the same timing mark on the can. Are the tyres the same age and wear? How worn in is your diff? Cleaned and lubed bearings? (Kit bearings are full of crap grease) Are both cars tweak free and sway bars set the same? There is potentially 0.4 there!
For starters I'd put the electrics from the fast car in the slower car and repeat to make sure that's not the difference.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
