Old 07-16-2011, 12:35 AM   #601
JayBee's Avatar
Trader Rating: 31 (100%+)
Ditto
Well the chassis has the drivetrain and arms in w/an Associated 106t spur. I can definitely tell the difference between Serpents metal geardiff vs. my plastic-laden brand X. The 'feel' of the teeth meshing is something I'll have to get use to. The car is definitely a QUALITY piece and surprisingly simple. No handfitting yet except for a tad of arm-reaming. I blame myself for the slightly tight rotation of the drivetrain (didn't spray the bearings and give 'em my treatment) but they'll loosen up. I'll get some ceramics soon though.
Prolly finish up tomorrow and start throwing together the electronics.
More to come later.......
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-16-2011, 07:31 AM   #602
Will the RW brand of xray spurs fit on the S411?
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 07-16-2011, 07:39 AM   #603
corallyman's Avatar
Trader Rating: 97 (100%+)
It should. I have a RW spur on mine now for the non boost class and it fits. This is a white RW standard TC spur. As long as the spur has the "wide" mounting you should be good. Usually the inner mounting holes is 6. If its like 8 then it might be meant for 1/12th.
Jaybee,
I left my chassis edges alone, didn't even sand it, but I still might. I won't be CA'ing it for sure.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 07-16-2011, 08:02 AM   #604
Steve
Mine is black. Don't think it is a 1/12 spur because it says it's a Xray Spur. I hope it fits.
Old 07-16-2011, 08:05 AM   #605
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Any Xray Spur gear will fit
OVA is offline   Reply With Quote
Old 07-16-2011, 08:09 AM   #606
corallyman's Avatar
Look at the mounting holes as if it was a clock. If a hole is at 12 o'clock, 4 o'clock, and 8 o'clock then it will fit. You can visually see this. A 1/12th scale spur has so many holes for the diff balls then they actually are not lined up. You could do some dremel work on this type of spur and still make it work.
The RW Xray spur certainly looks correct, I just don't have one yet to make absolutely sure that it fits.
Steve
Old 07-16-2011, 10:01 AM   #607
JayBee's Avatar
The Associated (TC6) spurs fit perfect on this car; I have a 106t on mine.
Old 07-16-2011, 01:06 PM   #608
JayBee's Avatar
On the go at the moment but finished up the blocks, frt/rear hubs and all the linkage. This kit has been a complete breeze thus far. Excellent in its simplicity. Although I've been stuck at home sick.....I'm grinning and bearing it
Last minute question.....the gear mesh/ lash of the geardiff has been bothering me. In the BAG there was included 2 thin spacers but no pic of them used in the manual. Were those supposed to be used to push the small gears inward inside the gearcase? Inquiring minds wanna know.......
Old 07-16-2011, 01:48 PM   #609
OVA
OVA's Avatar
yes you are right...should be each washer behind the small spider gear..
Did you have the washer inside for the out drive where the pin go in before the big spider gear?
I also believe the washers protect the metal gear from rubbing againt the plastic gear case...
Old 07-16-2011, 01:53 PM   #610
JayBee's Avatar
Thanks Franko.....and yes, I build per BAC 5004-1
Old 07-16-2011, 06:47 PM   #611
gearhead_22's Avatar
Send a message via AIM to gearhead_22
ran the car today for the first time and very happy, had a couple of bugs to work out, but after four quals today I am sittin 3 in 17.5 boost.I am going to put in the D3 tomorrow and see if I can pick up the pace a littleand yes the diff is a little noisey, but the car is smooth on the track,also I am using xray spur gears.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 07-16-2011, 07:09 PM   #612
OVA
OVA's Avatar
BAC 5004-1 Hmmmmm...Installation of Permanent Fasteners ..Did I get it right? are you working on 787?
Old 07-17-2011, 02:56 AM   #613
I didn't use the washers when I built mine, I didn't see it in the instructions, and when I tried using them it seemed like it pushed the satellite gears too far into the main gear and the mesh was too tight. I just figured it was when the gears wear out and the mesh gets loose. I know that's how some/most 1/8 scale buggy diffs are, they come with shims to compensate for wear of the gears. I guess we will see if I did the right thing when I run it.
Does anyone know if they make plastic replacement gears, or a diff with 4 satellite gears?
Old 07-17-2011, 02:59 AM   #614
JayBee's Avatar
The 'black mamba' is on the loose at a track near you
Old 07-17-2011, 03:01 AM   #615
Trader Rating: 54 (100%+)
This is exactly what I am doing( no shims). I have ran the car 3 days. No wear on diff yet.
Jamison R is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
