Old 12-09-2013, 04:27 PM   #6106
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by Johnny Wishbone View Post
Had a really good weekend at the WCIC with a really sweet carpet setup.
Nice, where's the setup?!
Serpent America, Picco, Blitz Bodies, Team Titan, Desoto Racing, LRP, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa.
chicky03 is offline   Reply With Quote
Old 12-10-2013, 01:58 AM   #6107
Trader Rating: 22 (100%+)
I think one of the differences that shows up more than the stiffness of the chassis is the difference in the lower roll centers, something that is probably forgotten when changing plates or looking at setups.
Yeah that kind of makes sense! Thanks.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-10-2013, 01:59 AM   #6108
+1 would be really good to see it buddy!
Old 12-10-2013, 09:21 PM   #6109
Johnny Wishbone's Avatar
Default WCIC Airdrie setup
Here is the setup, enjoy. (Can't seem to attach anything, so try this link for setup)
http://www.petitrc.com/reglages/serp...RIE2013120608/
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 12-10-2013, 09:35 PM   #6110
Thanks for sharing. Some interesting things. In particular the 500wt in the rear diff and the bearing block roll centres. Gonna give them a try and see!
Old 12-10-2013, 09:41 PM   #6111
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
9mm front upper arm shims? thats.. a lot lol. and only 500 cst in the dif. holy cow. i thought my 900cst was light.
food for thought. coming out to victoria gary?
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 12-10-2013, 10:24 PM   #6112
And thats not a typo either, to get the 9 you have to ditch the stock ballstuds and either go after market balls and long bolts or maybe long grubs and stock balls.....I use xray balls and long bolts, just think they are a little stronger than a long grub screw. JMO.
I honestly can't get a good grasp of 500 to 2000 in the rear diff, so I usually just run what makes the diff feel smoothest on the bench and doesn't leak all over the place. It hasn't seemed to effect the on track performance that I can tell. Just looking for a diff that keeps diffing smoothly.
Victoria, much discussion going on about it thats' for sure, would really like to touch base with the Serpent supporters out there, just to put a face to the names. I think the big factor will be if the rest of the Serpent team decides to go to the Snowbirds, as I'd like to meet the EU guys too. There is a possibility that they will be at the Birds, but that race is also scheduled on a ETS race date, so I'm not sure if they'll go or not.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 12-10-2013, 11:29 PM   #6113
Send a message via ICQ to #iZzy Send a message via MSN to #iZzy Send a message via Yahoo to #iZzy
Fischer is for sure at the snowbirds and will not attend the ets.
Team Magic Europe - HRC-Distribution - GM-Racing - LMI - MR33 - Tonisport
#iZzy is offline   Reply With Quote
Old 12-10-2013, 11:45 PM   #6114
Holmenkollen's Avatar
Originally Posted by Geberit View Post
Yes stick with 1.4mm rear (long version). Currently we are driving high bite carpet and 1.6mm rear works very good (Asmer set-up ETS). I don't know why but it never felt good with thinner ARB's at the rear. I used 1.2 and 1.3 but always went back to 1.4 on asphalt medium grip track!
As with the o-rings in my diffs I ditched the x-ring and went with o-rings from ARC R10 #104006. If you use the x-ring from serpent you have to change them frequently since they swell from the silicon oil and start to bind and you get inconsistent diff action! This was also the info from Ehrbar (co-designer of the S411) on the ETS! So I will probably try the o-rings from ARC R10 #104002 for the shocks too see how they work.
I tried to fit the ARC #104006 in the diff but they are shorter in height than the Serpent. You get massive amount of play. Do you use shims to compensate?
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 12-10-2013, 11:58 PM   #6115
valk's Avatar
its shaping up to be a real great event now that team associated is onboard, sending out mr hebert =)
ill be running my 411te in modified and could definitely benefit from team experience
i haven't differed from the stock setup a whole lot, some very small adjustments.
My stuff
My RC
Old 12-11-2013, 01:56 AM   #6116
Geberit's Avatar
That's normal because the x ring is too wide and tightens everything up. I have axial play too and don't use any shims. I'm driving mod with 4.5T motors, no problems at all!
Now I fitted the white housing from ARC with internals from Serpent. It works great, will post some pictures today when I come home!
Geberit is offline   Reply With Quote
Old 12-11-2013, 02:14 AM   #6117
Phoenix82's Avatar
I ran with Johnny this past weekend. his car was damn near perfect. I ran almost the same set-up. car was great..
Nick K
Phoenix82 is offline   Reply With Quote
Old 12-11-2013, 03:07 AM   #6118
Would this setup work with a mod motor?
Old 12-11-2013, 04:08 AM   #6119
This works? I see, u are using Anti-Dive which will result in less steering in combination with such high camber links. pretty sure, you gain positive camber while cornering with a low CG which results in a massive rolling car. normally, your car will push all the way.
Can you explain what changed with the higher viscosity in the front shocks?
Old 12-11-2013, 05:07 AM   #6120
Geberit's Avatar
I would like to ask what's with the new three hole tower mounts? All set-up lists have still only two! What are you using in which conditions?
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
