Old 10-28-2013, 10:11 PM   #5986
Trader Rating: 14 (94%+)
Originally Posted by TryHard View Post
This... Arm sweep works in a similar manner to inboard rear toe, in that it affects the rate of camber change. Adding more sweep will give more mid-exit, and less initial.
But also need to bare in mind that just adding sweep will also shorten the front wheelbase, which in turn also change the ackerman... it's why I would tend to adjust the wheelbase when changing sweep as well. Honestly, normally ended up on 1.5/1.5 or 2.0/1.5 front blocks, seemed to be the best compromise.
Regards
Ed
Ed, are you referring to track width? I don't understand what you mean "front wheelbase".
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 10-28-2013, 10:40 PM   #5987
I just noticed that there's a building tip from a guy named Gary. And he mentions the servo horn rubbing and servo savor touching the aluminum block.
"Page 22 A28, here is where you have to watch out a couple of things. If you follow the instructions and use the 1mm spacers between the servo and the mount, when you use the supplied servo horn as you rotate the servo, watch out for the clearance of the screw head to the carbon fiber support. This will be dependant of what brand of servo you use, but if you donít adjust for the clearance it will rub thru the sweep of the horn. I ended up using a 1mm spacer inside the horn to get a little clearance, but also managed to strip the horn on a harder crash. Now if you use a servo saver, youíll also have to trim it down so itís a little narrower as at full sweep of the servo the saver will hit the extreme right side of the aluminum mount, and full lock will not be possible. "
And I complained about this w/o knowing this article exists. As beautiful as the serpent manual is, I wish there was a bit of written explanation. Sometimes it's hard to understand things just by seeing pictures. It may be ok to you experts but it's not ok to mediocres. lol
Capricorn LAB C03
Old 10-28-2013, 11:34 PM   #5988
Johnny Wishbone's Avatar
When you arm sweep the actual wheelbase of the car changes. It ends up with a slightly shorter wheelbase, as well as your Ackerman changes, your shock angles change, the weight distribution changes, rc changes. Track width will also change slightly but the real big change will be the wheelbase, like removing some of the spacers between the arms and the suspension bridges.
The article is even more in depth if you go to the Petit RC site as it has the exerts from the instruction book that the build tips are referencing too. I can only hope that Serpent will include them as a supliment to the instruction book which was the intent of when I wrote them.
Or you can just ask here.....
The whole servo deal really depends on which one you use as some of them like a KO have better clearance than a Futaba or a Savox, which where the only two I had when I did the build tips.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-29-2013, 09:17 AM   #5989
chicky03's Avatar
Send a message via AIM to chicky03
Hey Guys!
I got to race my first big event with the 411 this past weekend. Here is the link to my setup. I thought it was really easy to drive. I was able to qualify 4th but the main didnt go as well as I would have liked. If you have any questions, ask here or email me, Paul@serpentamerica.com
http://www.serpent.com/file.php?FileID=5812
Serpent America, Picco, Blitz Bodies, Team Titan, Desoto Racing, LRP, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa.
chicky03 is offline   Reply With Quote
Old 10-29-2013, 02:01 PM   #5990
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Originally Posted by chicky03 View Post
Hey Guys!
yes yes Paul your car looked good and thank for the setup help, can't wait to run it this weekend.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 10-29-2013, 11:12 PM   #5991
xevias's Avatar
Hey Guys!
Hi Paul -
What top deck were you using?
Also, with all that weight added, do you know what your total weight was, 1380, 1400?
Going to try this set up for the AOC race at Yatabe Arena next month and they are going to let us run at 1350g.
xevias is offline   Reply With Quote
Old 10-30-2013, 03:19 AM   #5992
JAM Racing's Avatar
Default Manuals
And I complained about this w/o knowing this article exists. As beautiful as the serpent manual is, I wish there was a bit of written explanation. Sometimes it's hard to understand things just by seeing pictures. It may be ok to you experts but it's not ok to mediocres. lol[/QUOTE]
yes i understand but how many languages could they cover....in this day and age the download of the web in your language is probably as good as it going to get..or a usb supplied with the car cause even as we talk the cd rom is near the end of it life
other than that the forum is here and the web site the good
happy racing
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 10-30-2013, 05:39 AM   #5993
chicky03's Avatar
Originally Posted by xevias View Post
Hi Paul -
I used the std top deck with the kit. I think it's the 2.0 flex.
The rule for the race was 1380 so The car was 1384gr. I'd probably take out the 20gr one. My weight balance was 50/50 f/r so I'd try and keep it close to that after you remove the weight.
Old 11-01-2013, 08:40 AM   #5994
BardSmith's Avatar
Trader Rating: 58 (98%+)
For the Schumacher Mi5 Steering Rack install. I thought I'd add some pics with captions to show what I did. Hope it helps and feel free to contact me with Qs.
You dont have to drill new holes but it would be better to move the rack forward for a better ackerman.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 11-01-2013, 03:04 PM   #5995
Cheap one on eBay right now.
http://www.ebay.com/itm/Serpent-S411...E:B:BCA:0:1465
revrunner is offline   Reply With Quote
Old 11-01-2013, 04:56 PM   #5996
happy racing[/QUOTE]
Yeah I understand you too man. But I'm not saying that they have to put every single information in the manual but that they could mention briefly where to refer to when things can be hard to understand or confusing(like a link or simply say "check out website building help for further instruction").
To reply to your comment about how many languages, English is universal and they already use English in the manual. I don't understand why you even say that.
You are absolutely right about how easy it is to access to info and to download things from the web now days but it doesn't mean everybody has access to it when they are building the car, or at least when they are looking at the manual.
I don't know about you but I own a business and I know what to do to provide better customer experience. Putting a few more words in manual wouldn't cost them much if not at all and I would absolutely do that if that's the case.
You seem to have taken my opinion in somewhat a wrong way but I still love Serpent and will keep driving their car and just wanted them to strive to better customer care. So I gave my opinion. Not to just be a criticizer.
Capricorn LAB C03
Old 11-04-2013, 03:13 PM   #5997
Default ETS results
Some great results for the Serpent team at the CZ ETS race this weekend.
TQ and 1st in super stock, TQ and 1st in F1 for Jan Asmer, first time done in ETS history.
Placed 2 cars in the A main of Mod, no podiums but still a good showing.
Cars looking very competitve.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-04-2013, 04:03 PM   #5998
Very cool
Keep up the great work everyone !
http://www.facebook.com/VancouverRRR
http://joshuasouthoaks.blogspot.com for blog, pictures and video of race events
fasteddie d is offline   Reply With Quote
Old 11-04-2013, 04:06 PM   #5999
lookieaefanboi's Avatar
Trader Rating: 37 (100%+)
Hey johnny,
Any chance of getting jans s411 setup? Looking for a starting setup for AOC yatabe in a few weeks time.
lookieaefanboi is offline   Reply With Quote
Old 11-05-2013, 03:16 AM   #6000
JAM Racing's Avatar
Default your right not
um language and terminology
their is no Steering rack in the s411
regards Andrew
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
