Old 08-24-2013, 12:52 AM   #5821
TryHard's Avatar
Originally Posted by Bhodi11 View Post
I just wanted to report back this completely resolved my issue. Once I went back through all the rod ends to make sure they were completely free and used your recommendations on the sway bar setup Ta-da!!! car runs awesome. Thanks again!
Glad it helped. Setting the bars can be a pain, but I tend to find that once they are set, they rarely need re-adjusting, unless you switch out arms etc.
Regards
Ed
Old 08-26-2013, 08:23 AM   #5822
So i got my mitts on the s411 TE after returning from hospital
is it me or is it near identical to the ARC R10
PurcyP is offline   Reply With Quote
Old 08-26-2013, 09:26 AM   #5823
gearhead_22's Avatar
Send a message via AIM to gearhead_22
well well well my car was the best it ever was this weekend. I just can't get around the guys running the 3.1 fdr in there cars and not burning anything up in our 17.5 race. my new lrp drive train is working just fine. drop down to a 3.3 fdr and came off at 170 deg good power through the whole race. I will post my set up later and and see if anyone can give any pointers to get a little more corner speed.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 08-26-2013, 10:08 AM   #5824
Johnny Wishbone's Avatar
Actually, about the last 5 "new" cars that have been released all show similarities to our car. The main design layout of the car is tough to beat.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 08-26-2013, 10:18 AM   #5825
valid point! people say serpent copy n dont innovate although looking at its history i think its the other way round.
I have a mi5 also and to be honest...i think i like the layout n design of the 411 more, also the drivetrain sound a hell of a lot smoother than my mi5, might be down to my diff building but either way im liking the serpent as i thought i probably would.
also the serpent is so much more narrow n streamline!
Old 08-26-2013, 02:16 PM   #5826
my s411 ERYX with lrp power plant
Old 08-27-2013, 02:19 AM   #5827
Benzaah's Avatar
Trader Rating: 21 (96%+)
I had my worst state titles ever this weekend just gone. On an extremely tight boarded asphalt track I managed to wreck 2 bottom decks, a top deck, a steering rack, 4 sets of front arms, 3 pair of knuckles and 3 drive shafts. This is more parts than I've chewed up in 2 years running the car. DNF 4 out of 6 qualifiers and both b finals. I had a 4th and 7th in my good qualifiers Surprisingly with all this carnage I did not bend any bulk heads or toe blocks.
FWIW I would not recommend the new spool as it chews blades and if you miss changing them out the driveshafts chew up the opening as its not hardened very well.
The new motor mount on the other hand is awesome. It can only run in flex mode as there are no mounting points for the stiff leg of the original mount.
Lastly, Is anyone aware of an updated kit coming soon? I'm in need of a new one!
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 08-27-2013, 04:09 AM   #5828
I have recently bought two of the new spools, but not tried them yet. Maybe not a good move then.. when I already have blade problems with the V3 diff. I belive that I create an uplift in the sales curve already in the Serpents sales statistics in the blades salesreport
Linguster is offline   Reply With Quote
Old 08-27-2013, 08:35 AM   #5829
whityboy's Avatar
there is a new car in the pipeline.
only with some small changes, think end of next month or begin of october.
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 08-27-2013, 01:47 PM   #5830
Tough luck.....I certainly hope you wheren't the only one with all the breakage?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 08-27-2013, 08:00 PM   #5831
I'm running 17.5 blinky with a killshot. I just picked up a PRS 54T pinion. The neck on the pinion causes it to stick out past the 92T spur with it seeded as far back as the shaft will allow. So about 50% let's say is not contacting the spur. Can I shim the motor back some off the mount to make up the difference or do I need a new pinion?
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 08-27-2013, 08:11 PM   #5832
Try flipping the pinion around so the neck faces away from the motor?
-Mike
Old 08-27-2013, 09:50 PM   #5833
You mean you ran out of flat area on the motor pinion? I would first check the motor to make sure the rotor is not shimmed wrong in the can. Generally, you want the rotor very close to the sensors.
If that checks out, I would probably take the old dremel with a cutoff disc and carefully extend the flat on the shaft.
Team Serpent
Steve S is offline   Reply With Quote
Old 08-27-2013, 10:42 PM   #5834
I ran out of flat area that is correct. No issue with any other pinions I have a 41T, 46T, and 50T which are Robinson Racing. I think I may just pick up their 56T instead. Checked the motor and it looks fine.
Old 08-28-2013, 12:33 PM   #5835
orcadigital's Avatar
Trader Rating: 61 (100%+)
I just picked up some 4 degree c-hubs and not sure which way to put them in. There is an "S" etched on on side, I'm guessing that is the front and I want them tilted back. Is this correct?
The S is for soft and refers to the hardness of the plastic. Medium have no marking and hard have an H.
Other way around, but yes. One of their team drivers runs with us locally, and we were comparing parts. Some of the parts were even interchangable(layshaft pullies).
Is this a large outdoor track? We are running 3.8 to 4.5 on a smallish indoor carpet track, and would not know what to do with that kind of speed. I also doubt the temps would work unless running an LRP motor. I'm at a flat 4.0 right now and after a 6 min main come off at 125 or so. Now I have geared my VTA's down to as low as 2.9, but even 21.5 I think I ran at 3.3 to 3.5. All indoor carpet though.
Details please!
Are you using a standard spur or an offset Xray style? If it is an offset, flipping the spur may give you the mesh you want.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
