Old 06-28-2013, 06:48 AM   #5686
[QUOTE=Linguster;12297915]
Originally Posted by Madmaxaus View Post
Trying to find out if any one else has noticed the hole alignment is out on the engine mount and lay shaft
I have converted a TE and also built the Eryx and both bottom decks I had to elongate the holes to take out the tweak
In my Eryx that I rund indoor I have a tweek that I did not find any explanation to. I did not losen the engine mount, but the bulkehed and toe block's
I bought I new chassie to bolt on for the indoor season. But that might not do the trick if I read your post..
Yes I did the same thing so stripped the car and rebuilt it slowly checking everything and that's what I found
I also checked it on the new car I got same thing but no problem with the Team Edition
**Ausrab Industries**Destiny RX-10s**Futaba**LRP**GRP**SpeedyRC
Madmaxaus is offline   Reply With Quote
Old 06-28-2013, 07:34 AM   #5687
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
I run stock and mod with my 1251mg just fine. Great servo but if your budget allows for futaba all the more power to you.
I wouldnt mind trying an ssr sanwa but 3x the price for 20% at very best better. Also running savox on my nitro car which is definitely more work than electric tc for the servos ha.
Havent niticed a misalignment on the layshaft though i wish the arm mounts were keyed. Very easy for them to twist out of alignment. I follow jilles's video series on building vmthe cars and everything comes out awesome.
My stuff
| Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - Xray XB8/17 - ProAMPS - Hobbywing - Novarossi - ORCA |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 06-28-2013, 10:25 AM   #5688
whityboy's Avatar
Originally Posted by valk View Post
I cant be the only person who has noticed this but i had to put a 0.25mm endplay shim on all my axles between the bearings to keep them from compressing together when the wheel nut is applied. anyone else found the wheels to bind when you crank em tight? another small thing to add to the TC design bucket list for me! precision axles.
The first bach of the TE had that probleme. and got fixed in the next batch
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 06-28-2013, 10:39 AM   #5689
valk's Avatar
Tons of shimming on this rebuild though. Beautiful car buy has a lot if tolerance in new parts even. Shimed up everywhere in the front end and still have a good amount of wobble in the steering.
Hope the eryx parts that are harder fit tigter with less tollerance. Always thought the chub pin was too small or the Hole in the hubs too oversized.
Though after ancomplete teardown, she rolls pretty easily on ceramics. Maybe better if the pullies were ptfe/cast nylon for less belt friction. Should be fast.
My stuff
My RC
Old 06-30-2013, 11:58 AM   #5690
Niky_Freaky's Avatar
Default battery mounting
Hi can you post some pics how you mount your battery. I am new to on road and cant seem to do it with the original plastic tape things ()
TEAM SERPENT BULGARIA
SERPENT 811b sponsored by VpPro
Niky_Freaky is offline   Reply With Quote
Old 07-01-2013, 09:56 PM   #5691
whityboy's Avatar
My son won round 4 of the begium nats wit his s411 eryx in the stock classe. 17.5
His car was superfast and had plenty of grip and easy to drive.
on my mod car I had the same setup but with harder springs. car was also good but I don't have his talent :-D
https://www.dropbox.com/s/cdbwr1ng06zs3q1/bk%20genk.pdf
Old 07-01-2013, 10:02 PM   #5692
whityboy's Avatar
I never use the plastik tap things, With a bit of sandpaper I thake the edges of the batteryslots and just tape the battery on the chassis.
Old 07-01-2013, 10:48 PM   #5693
Geberit's Avatar
Nice tuning option but nothing on the official site??
Shock Tower mount V2
http://rcmarket.com.hk/product_info....c861862b5b691a
Geberit is offline   Reply With Quote
Old 07-01-2013, 11:18 PM   #5694
valk's Avatar
I use the serpent velco strap. not sure the part number though. those plastic things work alright but you have to modify them to get the most steering throw from the rack i noticed. maybe they fixed on the new car? had to shave 45-60 degrees of material off the block where the swingrack hits it.
My stuff
My RC
Old 07-02-2013, 06:54 AM   #5695
gearhead_22's Avatar
Send a message via AIM to gearhead_22
here is the part number for the strap http://www.serpent.com/product/401566/ and you only have to trim the battery brace if you are running the car with the battery in the foward postion.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 07-02-2013, 06:59 AM   #5696
limited edition #177
Old 07-02-2013, 07:02 AM   #5697
ERYX modded
Old 07-02-2013, 10:19 AM   #5698
brunelli ale's Avatar
new v2 Shock tower has a new middle position for camberlink and possibility to switch spool/geardiff in high position to get more cornerspeed in high grip conditions.
Tested last week, option to have!
brunelli ale is offline   Reply With Quote
Old 07-02-2013, 05:04 PM   #5699
valk's Avatar
it KINDA works in the rear position but still needs a hair taken off to get full lock on the one side. i moved the battery back, but not sure how that will change the cars balance. i have been liking the forward position thus far.
My stuff
My RC
Old 07-03-2013, 01:32 AM   #5700
Default "Soft" outdrives on the V3 Diff
I am experienceing that the material in the outdrives does not match the one in the Xray diffs.
I have several hundreds of runs on the Xray diffs that I used in my Serpent prior to Eryx and the V3 without getting the worn into the outdrives. I get that after around 30 runs on the V3 and it starts to eat blades for breakfast. I am now on my 3rd diff. Any thoughts or experience of this "out there"
The V2 diffs with Cleaning Gum that I use in the front, the outdrives lasts forever.
Last edited by Linguster; 07-03-2013 at 03:31 AM. Reason: Better english I hope...
Linguster is online now   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
