Old 05-26-2013, 03:22 PM   #5581
Originally Posted by Timbo99 View Post
Hey,
I've tried alloy blocks and c-hubs and they are finer for 21.5,but if your running in mod,you will welcome the composite ones as alloy tends to scrub out the front with understeer.
You can get away with them in 13.5,just need to adjust your arm sweep,and or change tyres.
Is this for running at Dandenong?
Or elsewhere?
Cheers
Tim
PS. I've adjusted my front end to run with alloy,and I run the alloy uprights.
They look awesome.....lol
Thanks for the tips. Yes this will be for running at Dandenong.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 05-26-2013, 09:18 PM   #5582
TryHard's Avatar
Originally Posted by Geberit View Post
We were testing the Serpent springs (Black, Yellow and Gray). The combo Black/Black turned out to work really good on asphalt medium bite track. Also Black front Yellow back is not a bad combination but with a little different shock position.
I would say Blacks and Yellows are worth to try on asphalt everything else is a no go since it's way of what normally works on these days TC's.
On the serpent spings, I actually believe Marc Fischer ended up using Gray/gray F/R at the last ETS, so don't quite rule them out yet.
The biggest issue with the serpent springs for me is that the rates are quite far apart, which can make it difficult to tune with them. For me the Ride springs have very nice close rates, which makes it a little easier to tweak the springs.
HiH
Ed
Old 05-26-2013, 10:40 PM   #5583
Default Maybe off topic
Hello all! New to this forum and I am sure that I am most likely breaking some unknown rule, I apologize in advance.
I have been reading this forum for information on the s411 anticipating the day it arrived. That day was yesterday. Ran the car on the track tonight and it handled like a dream, almost like it was riding on glass. Anyways, after being happy with track performance, I of course had to get a speed run in on 3s . First was a moderate run clocked at 73 mph, I then decided to be a bit more bolder and try a 2nd one. I shouldn't of, the car went airborne like I knew it was possible . I only broke an upright and a cvd insert and pin. Just wanted to say that I like the car and I learned my lesson. No more speed runs, the car is pretty light as everyone already knows.
Thanks for all the input everyone has been writing about, it has helped me quite a bit. Keep up the good work.
RCJunkie77 is offline   Reply With Quote
Old 05-26-2013, 10:43 PM   #5584
Geberit's Avatar
HiH
Ed
No doubt the Gray springs can get useful in some conditions. Maybe on a track with more grip they would work better. I our case we tried Serpent and Ride springs and in both cases harder springs were a better choice. Ride the Red/Red combo seemed to work better than Blue/Blue or Green/Green. On the Blues and Greens the car lack of grit at the start and got better after a few laps but still slide around a little more. The Reds gave good grip from the start. The same we observed with Serpent springs Black/Black, Yellow/Yellow and Gray/Gray were the Blacks were the best option.
This has certainly to do something with the track that we were riding on. It is a medium bite track when conditions are at its best so it tends more to low bite than high bite.
On high bite tracks softer springs may work better so Grays definitely would be worth to try.
Lojz
Geberit is offline   Reply With Quote
Old 05-27-2013, 07:43 AM   #5585
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Ed you have PM.
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 05-27-2013, 09:06 AM   #5586
TryHard's Avatar
Lojz
Certainly agree. Springs is still one of the major things I'm still not 100% settled on, at least in terms of a base setup. Changing track conditions, and other changes to the car mean I've been undecided between harder and softer. Recently, I've moved back towards a HPI silver/silver setup (not dissimilar to Ride Red/Red) over the Ride Green/Green I had been running. Also tried out the yokomo's again, but think the fact that the pink behaves more like a progressive, whilst the blue is linear, makes the car feel odd on asphalt...maybe a Yok Blue/Blue will work well for higher grip, and I do need to add Ride Red's to the pit box as well
Anyway, doesn't really solve much, lol, and more random mumblings than anything else... but does mean I have still more things to try out on my list in the future!
Ed you have PM.
Replied
Old 05-27-2013, 10:40 AM   #5587
Ed,
I tried some of the changes and car now no longer breaks away mid corner.
Went to Stafford for BTCC, track has been swept and washed, no grip and grained tires after one run, even for the top drivers.
I put on 1.0/1.0 blocks on front and 3mm bump washers, moved rear wishbones back (1mm at rear).
Put 0.5mm spacers under rear block, then tried 1mm.
Will be testing at Aldershot next week, track much kinder on tires.
Have also notice shocks are starting to leak, do you put in a extra spacer in with the o ring.
Chris.
Chris H.
Serpent S411 Eryx, Hobbywing, Vampire,
Livingston is offline   Reply With Quote
Old 05-27-2013, 05:13 PM   #5588
FastPete's Avatar
Trader Rating: 44 (100%+)
Thanks for the help guys. Back to spring questions. I have the 2.0 with two races on it. Stock setup black front grey rear . I noticed on the rear grey springs at 5mm droop which is stock. and 5mm ride height, when the car is on the stand, so tires hanging, one spring was alittle loose, no preload. But the other side did have alittle preload. I went through everything and its the springs one is a good mm shorter or so. Now the car does handle great! But that cant be good, when u let off the throttle rear weight wouldn't transfer forward even right? No spring pressure pushing up to get it to the droop screw.
Just always trying to make things better right? And if u agree I should fix it, should I get Ride springs or? And what ones? The stock rate to me feels good, and might want one step stiffer. And where to get them?
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-27-2013, 07:29 PM   #5589
http://www.serpent.com/product/400013/tech-tips/
Also check out this tech tip link.
Tim
Page 21, A25 - 22.85mm
Page 23, A30 - 24.80mm
Page 27, A38 - 10.00mm
Page 30, A47 - 12.45mm
ERYX correct link lengths as per the link provided.
Front toe
Servo arm
Rear camber
Front camber
(for the lazy ones or people with no pc)
Tim
http://www.petitrc.com/reglages/serp...zer_BuildTips/
Arn0 is offline   Reply With Quote
Old 05-28-2013, 10:24 AM   #5590
FastPete's Avatar
Thoughts?
Old 05-28-2013, 04:04 PM   #5591
Timbo99's Avatar
Thoughts?
Hey Pete,
I wouldn't worry about it.
The cars weight transfer would have to be so great it lifts the rear wheels off the ground when braking,and that doesn't happen.
I'd keep the cash in your wallet and keep smiling!
Regards
Tim
Old 05-29-2013, 11:55 AM   #5592
Johnny Wishbone's Avatar
Just make sure that its not the paint build up on the spring thats making the stack difference. When you set your ride height do you have equal amounts of gap between the shock collars and the top cap? At static is the ride height the same left to right? If you have the car sitting static and lift it and do a "over ride height" measurement is it the same left to right?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-31-2013, 12:18 PM   #5593
gearhead_22's Avatar
Send a message via AIM to gearhead_22
http://www.serpent.com/product/401597 does anyone know why there are two different suspension bracket in this kit 0.5 and 1.5
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 05-31-2013, 12:20 PM   #5594
also I can grab my spur gear and move it side to side. Is this normal?
Old 05-31-2013, 12:41 PM   #5595
whityboy's Avatar
yes this is normal. some put a shim in to take the play away.
for the brackets you can choose between 0.5 and 1.5 depending on which side you place them on the chassis
VBC support team manager EU
whityboy is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
