Old 05-24-2013, 07:05 AM   #5566
Niky_Freaky's Avatar
Default New to the electric on road game
Hello,
Next week I am gonna order the ERYX and want to ask couple of things. I am gonna run modified on asphalt track and sometimes carpet.
What motor do you think I should get? 4.5? 5.0?...
What Body works good with this car ?
what spare parts should I get?
What gears?
And option parts ?
Thanks in advance
TEAM SERPENT BULGARIA
SERPENT 811b sponsored by VpPro
Niky_Freaky is offline   Reply With Quote
Old 05-24-2013, 12:36 PM   #5567
whityboy's Avatar
ready for the weekend
The weather sucks this year here in belgium.
The first natiional is this weekend so I am prepared
whityboy is offline   Reply With Quote
Old 05-24-2013, 12:45 PM   #5568
whityboy's Avatar
Originally Posted by Niky_Freaky View Post
Hello,
What gears?
And option parts ?
Thanks in advance
Motor a 4.5
body: I really like the serpent body but it is to heavy. you can't go wrong with a mazda 6 speed or a LTC best hav both.
spare parts is difficult to say. do you like to hit stuff. get some arms.
only broke one front arm on the new car.
option parts I only recommend the DJC's. maybe some 1.5/0.5 split blocks if you like some more tuning opportunities
Old 05-24-2013, 01:01 PM   #5569
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Hello,
What gears?
And option parts ?
Thanks in advance
you should get the aluminum center small gears that sit on the out side of the spur. I striped my plastic ones last season running mod. As for motor, I ran a 8.5 with boost smooth on the in field and very fast on the straight.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 05-24-2013, 06:13 PM   #5570
TryHard's Avatar
Originally Posted by Geberit View Post
I would like to buy additional shocks #160124 for my ERYX. Somewhere I read the kit is not fully complete!? Has someone info no that?
Thanks, Lojz
Remembered the post you mention, this one from Pattojnr.
Originally Posted by Pattojnr
Anyone thinking of getting spare shocks, there is the bottom seal cap missing from the shock sets 160124. if you are to buy some, then please add 160125 to your order so you can use your shocks.
Post 5281
Not sure if the kits have been fixed though.
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-24-2013, 07:13 PM   #5571
TryHard's Avatar
Hello,
Depends a lot on the size of track. For decent sized outdoor tracks, 4.5t is a good choice, as the wind means it can be tuned for a decent range of tracks (tighter, less boost, more open, more boost). For tight indoors I'd look towards a 5.5t. If your taking mod seriously, then I strongly recommend getting a faster motor from the start, and backing down the throttle EPA and adding expo until your used to it, rather than running a slower motor. It'll teach you better throttle control, and save having to up the motor when you want more power
Normal two choices would be the Pf Speed6 and LTC-R. Pretty much LTC for outdoors, Speed6 for carpet.
The serpent cars are really tough, in my whole time of running mod with the car I've done one rear hub... So I would just get a spare set of all the plastics (arms, wishbones, hub's). Also grab a set of belts, just in case.
Last part to grab would be a spare set of diff gears (#401594)
[quote]What gears?[quote]
For a 4.5, using the kit 84t spur, look for 20, 21 and 22t pinions (will give FDR range of 8.4 - 7.6)
And option parts ?
Thanks in advance
Options wise, I strongly recommend the following;
#401445 - DCJ driveshafts for the front
#401597 - 1.5/0.5 mirrored blocks (to help remove some of the front arm sweep)
#160110 - Clear o-rings, a must to help stop the shocks leaking.
Optional's that are not essential, but well worth picking up;
#401585 - Second set of 0.0/2.0 mirrored blocks (to run wider, straight arms)
#401418 - 1.5 One-piece block (for front straight arms, narrower)
#401375 - 0.0 One-piece block (use in RF, helps to give more steering on wide open tracks)
#401591 - 2.0mm stiff chassis... seems to be the ticket for indoor carpet, but the kit chassis is better for outdoors.
#401427 - 19t Alloy pulleys. I personally never had an issue with the plastic pulleys (even running mod), but the alloy ones are nicer, and definitely won't strip!
#401592 - Spare composite diff... essential if you want to run a front gear diff, although most still use a spool.
Otherwise, just the usuals on springs (HPI and RIDE work well) and oils (400-600 for the shocks, 1k-3k for the diff) , and your all set
HiH
Ed
Old 05-24-2013, 07:24 PM   #5572
FastPete's Avatar
Trader Rating: 44 (100%+)
All the talk about springs I see, HPI, Ride, etc...Are the Serpent option springs not good?
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-25-2013, 12:28 AM   #5573
Geberit's Avatar
We were testing the Serpent springs (Black, Yellow and Gray). The combo Black/Black turned out to work really good on asphalt medium bite track. Also Black front Yellow back is not a bad combination but with a little different shock position.
I would say Blacks and Yellows are worth to try on asphalt everything else is a no go since it's way of what normally works on these days TC's.
Geberit is offline   Reply With Quote
Old 05-25-2013, 04:51 AM   #5574
Default ьцьз
Originally Posted by TryHard View Post
Originally Posted by whityboy View Post
Thank you both, that really helped me.
Old 05-25-2013, 11:53 PM   #5575
Hi,
Just wanted some opinions on top decks and alloy options. After breaking the standard 2mm flex top deck in the eryx kit is it worth replacing with the same top deck or one of the other options considering change in flex etc.
Also are the alloy c hubs or alloy steering blocks worth looking at or better to stick with plastic?
Thanks!
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 05-26-2013, 04:41 AM   #5576
vadersing's Avatar
Default Ball joints
I have just received my eryx kit, and enjoying the quality and the build so far.
However, I noticed that the material of the ball joints is rather hard and brittle compared to my previous Xray T3'12.
Has anyone faced any problems with their ball joints breaking or popping in races?
Any substitutes to consider (without having to replace the 4.5mm ball connectors)?
vadersing is offline   Reply With Quote
Old 05-26-2013, 04:57 AM   #5577
Timbo99's Avatar
Trader Rating: 14 (94%+)
Send a message via ICQ to Timbo99 Send a message via AIM to Timbo99 Send a message via MSN to Timbo99 Send a message via Skype™ to Timbo99
Originally Posted by luda View Post
Hi,
Thanks!
Hey,
I've tried alloy blocks and c-hubs and they are finer for 21.5,but if your running in mod,you will welcome the composite ones as alloy tends to scrub out the front with understeer.
You can get away with them in 13.5,just need to adjust your arm sweep,and or change tyres.
Is this for running at Dandenong?
Or elsewhere?
Cheers
Tim
PS. I've adjusted my front end to run with alloy,and I run the alloy uprights.
They look awesome.....lol
Serpent ERYX/S411 Le#189,#024,TE/Airtronics/MuchMore FLETA 4/Ryan Dezign-
"The finest RC paintwork in Australia"/LEESPEED/Ame T-Shox/THiNK Carbon.
"If at first you don't succeed,.....tell'em it's the "Beta" 1.0 version"
Timbo99 is offline   Reply With Quote
Old 05-26-2013, 05:01 AM   #5578
Timbo99's Avatar
Default Tightness
Hi,
Just built mine last week,and they will be a lot stronger than you think.
They also seem way to tight as well,but after a couple of runs......ciao bella...all good!
Regards
Tim
Old 05-26-2013, 05:10 AM   #5579
Timbo99's Avatar
http://www.serpent.com/product/400013/tech-tips/
Also check out this tech tip link.
Tim
Old 05-26-2013, 05:25 AM   #5580
Timbo99's Avatar
Page 21, A25 - 22.85mm
Page 23, A30 - 24.80mm
Page 27, A38 - 10.00mm
Page 30, A47 - 12.45mm
ERYX correct link lengths as per the link provided.
Front toe
Servo arm
Rear camber
Front camber
(for the lazy ones or people with no pc)
Tim
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
