Old 03-18-2013, 10:25 AM   #5356
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
What is everyone using for servo savers?
I can't stand the horns anymore, one tap and they're stripped.
The xray tc one works but limits steering throw by quite a bit.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 03-18-2013, 10:30 AM   #5357
I can't stand the horns anymore, one tape and they're stripped.
I use Tamiya #51000 with the 3racing 18mm horn:
http://os.3racing.hk/products.php?products_key=4113
Very close to the same length as the kit horn.
Team Serpent
Steve S is offline   Reply With Quote
Old 03-18-2013, 07:36 PM   #5358
Johnny Wishbone's Avatar
John, I run the 4 spring Xray servo saver, just removing the material on the right side so as to get full lock to lock steering if needed.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-18-2013, 08:06 PM   #5359
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
ive been using standard 1/12 servo savers for the most part. not ellegant but they work.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 03-19-2013, 02:04 AM   #5360
snuvet75's Avatar
Trader Rating: 14 (94%+)
Originally Posted by jeff jenkins View Post
i realized i made a couple mistakes in my posted setup so i edited my post to include the correct setup. I originally had the wrong rear shock position now it has the correct one.
So Jeff, I'm debating between Eryx vs T4 vs BD7 to buy. I know you had Spec R1 some time ago too. Reading posting about Spec R1, it seems that it could be a big headache off of trying to save some bucks. So I dropped the idea. I own T3 '10 and it's getting old and getting behind. What can you say is better about Eryx than the other competitors like T4 or BD7?
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 03-19-2013, 02:19 AM   #5361
snuvet75's Avatar
Originally Posted by Team_Elli View Post
Don't you think it oversteers to much with more droop back than front? i have been struggeling with alot of oversteering(rear end very loose at corner exit) and i readjustet droop from 6F/5R to 5F/6R today and suddenly my S411 was locked up in the rear not loose at all it was driving on rails i'm running ride hight 5mmFront and 5,5mmRear and.I tried all sorts of setup adjustment's on the rear end before this.
Elli, you mean downstop when you're saying droops right?
Old 03-21-2013, 05:21 AM   #5362
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
Good Question, for me the spec-r was a great car but the Eryx is flat out more consistent. as for the BD7 and the T4 i have not had those cars, but have seen and know people that do have them. the bd7 is a nice car as well as the T4. but for me it comes down to the little stuff. all three cars are superior quality to the rest of the field. i feel the serpent and xray surpass the BD7 in terms of quality tho. BD7 is like any other car out there. but where the xray and serpent stand out is the lower CG. that they are trying to achieve going with the shorter shocks and towers. but here is what i like best about the ERYX that the xray is lacking. True floating servo mount, spring steel spool outdrives that are double pinned to the spool, aluminum shocks. narrow chassis , ability to tune the motor mount via standoffs as a kit standard. amazing kit build (xrays have excellent kit builds as well) . the ability to use standard length springs is a big plus! Hell I even like the ball stud and ball cup combo. no options ar needed to be competitive. The diff is also very nice. no leaks to report and still very smooth.
like i said its the little things that count.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 03-21-2013, 05:37 AM   #5363
tak4's Avatar
Finally ran my new Serpent Eryx today.
Quite impressed at its drivability out of the box but the car suffers from more understeer than I would like during slow on-power corners.
Will spend some time playing around with the set up and see how it goes.
My old ride (Xray T3'12) was a bit easier to drive but the Eryx seem to handle fast corners more confidently.
Here is a vid of our track... I had no involvement in it but I am super proud of it, especially as the RC community in the country does not exceed 50 people.
http://www.youtube.com/watch?v=tMqqcU_VlM0
P.s. Another Eryx crashed on its first day and broke the upper deck into three pieces >.< You would make a killing selling upperdecks in Brunei now. Everyone is breaking them left right and centre.
Nova powered MP9 Tki3
Hobbywing powered Kyosho MP9e (Tki3)
Orion powered Xray T4'14
Driven with Sanwa M12
tak4 is offline   Reply With Quote
Old 03-21-2013, 06:25 AM   #5364
gearhead_22's Avatar
Send a message via AIM to gearhead_22
paolo morganti running eletric TC
+ YouTube Video
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 03-22-2013, 10:40 PM   #5365
Benzaah's Avatar
Trader Rating: 21 (96%+)
Next on my list to try is short wheel base. Having built the car with all shims forward at the front and a 2/4 fr spacing in the rear I'm noticing a lot of sweep in the drive shafts and shocks. I've fixed the shock issue with 1mm of shim under each of the bottom mounts but I'm wondering if this driveshaft angle is detrimental to handling at all? I had no issues running the car 3/1 front and 3/3 rear with the same arm sweep in the front and rear and I figure serpent would have tested the car with the extremes of the cars set up range and not given us the option to run it if it was bad.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 03-23-2013, 04:00 AM   #5366
yes that's correct
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 03-25-2013, 01:37 AM   #5367
andyw2's Avatar
A bit of confusion by me on setup. The V1 manual states using inverted suspension blocks on the front rear with 4mm spacers underneath. Some of the setups use 0.5 or 1mm under the hinge pin blocks. I assume the hinge pin block is the same as the suspension block and by using 1mm do they imply using 4mm + 1mm under the front rear?
Thanks in advance for any help
Andy 17.5 blinky VTA (a local thing due to large track)
Andy W
Mugen 1/8 GTconverted eco buggy
Mugen SCT converted eco buggy
andyw2 is offline   Reply With Quote
Old 03-25-2013, 09:33 AM   #5368
Akhor's Avatar
3MM is the 0 point on the front rear block.
If you are matching 1 MM front front shim under the block then the front rear would need 4.
If you are matching .5 MM front front shim under the block then the front rear would need 3.5
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 03-25-2013, 09:44 AM   #5369
olhipster1's Avatar
Trader Rating: 97 (100%+)
Send a message via Yahoo to olhipster1
Default Desoto Racing
Serpent America
website is down
need to place an order, any other options to order parts?
i need a EYRX chassis, #401590
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-25-2013, 04:00 PM   #5370
gdiddy's Avatar
Originally Posted by olhipster1 View Post
Serpent America
website is down
try stormerhobbies.com or amainhobbies.com
The desired effect is what you get when you improve your interplanetary funksmanship.
gdiddy is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
