Old 03-01-2013, 01:13 PM   #5266
whityboy's Avatar
the traction at the ETS is low. and tomorrow morning it wil probably rain so traction will be really low. everybody is looking for some bite to get ther cars around the corner
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 03-01-2013, 05:10 PM   #5267
dameetz's Avatar
Default Stabiliser ball end
I m building my Eryx right now and found that the stabiliser ball ends caps are too tight for the ball end causing binding. Any tips on how to loosen them?
Thanks.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-01-2013, 06:10 PM   #5268
rcwck's Avatar
Thanks.
Previous post and your problem is covered here
http://www.serpent.com/news/13643/Se...by-Gary-!.html
rcwck is offline   Reply With Quote
Old 03-01-2013, 08:07 PM   #5269
Default For sale 411-eryx and a 411TE
edit
serpent cobra 811TE, Cobra 811T,Serpent S411TE,rebel12 pan car, VPfuel, Buku clutches, Novi motors
1airborne is offline   Reply With Quote
Old 03-01-2013, 08:36 PM   #5270
Mitchy1986's Avatar
Default S411 21.5 stock gear ratio help
Hey guys I have a 411 with 21.5 thunder power HB flux pro esc 5000 65c lipos 84 spur and 25 pinion it's the bigger pitch not the finer one. The motor is over heating at 180-190 after 2-5 min and is struggling to get to top end speed is there a easy calculator out there or some to help find out what I should be running? I'm not good with maths. Thx
Mitchy1986 is offline   Reply With Quote
Old 03-01-2013, 10:16 PM   #5271
TryHard's Avatar
If you have an iPhone, GearIt is a useful little app for calculating gearing, and can save cars to it as well
GearIt v2
Are you using boosted or blinky software on the ESC? as that gearing is quite low, even for blinky (84 / 25 = 6.72 FDR)
Ed
Old 03-01-2013, 11:41 PM   #5272
Mitchy1986's Avatar
Hey ed I am not sure if I am using blindly mode or not just using the 17.5 stock mode on the esc program card bit of a newbie to rc touring thought I would start slow with the 21.5 class, hey just off topic are you the ed that races the 411 at meakin park in logan city? I have been trying to get in contact and starting membership with logancity rc club I will check that app out too thx mate. I have seen a few pin/spurs on eBay but trying to find the best supplier of serpent gear for here in brissy
Old 03-02-2013, 12:10 AM   #5273
TryHard's Avatar
Ah ok, what you probably want to do is switch the ESC to Mode 2 on the program box, which is zero timing mode (that is blinky mode). Car will be slower mind (as the profile you have on does have boost/turbo), but you'll need to run this mode at club meets.
And yes, thats me with the 411 at Meakin, feel free to come bring your car over if you have any q's next meeting, as I'm more than happy to help out.
Gearing wise, I'm not sure what the prefered setup for gearing is at Logan in 21.5t, good bet is to send an email to Dave over at ActionRC (heavy at actionrc.com.au), as he will be able to guide you on ratio's etc, and supply suitable spurs/pinions. He's at the track every meeting too, so is useful to know
As for Serpent parts, honestly, your best bet is to just order them from Walter RC Hobby. Jay is the Serpent Distributor here in Oz, and does a great job with really quick shipping on parts, and normally has a large stock level of parts. If I break something on a weekend (which thankfully rarely happens!) I usually have it in my hand on the following Wednesday. And he responds to emails fast as well. Very highly recommended.
HiH
Ed
Old 03-02-2013, 12:25 AM   #5274
JAM Racing's Avatar
ok if it 21.5 bl inky you'll have to purchase a @ 63 spur and 38-42- 44 pinion
that's working on rubber tires at 63 mm so need a fan for bigger pinions
Now last warning TEMP TEMP TEMP
all tracks and different speed controls are different.... even in blinky
yes it a pane as the motor retaining screws are covered by the spur as serpent spurs are not quite small enough but its the same for other brands as well
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 03-02-2013, 12:56 AM   #5275
performula's Avatar
Sport or RTR is the question...
They both seem good. I know I can buy a team kit but the RTR and Sport seem like great values.
performula is offline   Reply With Quote
Old 03-02-2013, 01:23 AM   #5276
Mitchy1986's Avatar
[QUOTE=JAM Racing;11880571]ok if it 21.5 bl inky you'll have to purchase a @ 63 spur and 38-42- 44 pinion
thanks heaps for all the helpful advice guys i will get onto the new gears asap
Old 03-02-2013, 02:23 AM   #5277
RasCalDK's Avatar
They are great value!
But it depends on what you are going to race, as that might need you to buy specific electronics? Which races or just club driving?
But i'd buy the Sport, and then get hold on some used electronics. it will properly be more costly, but you will also get better equipment for racing.
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 03-02-2013, 03:49 PM   #5278
Geberit's Avatar
Sounds promising for this summer!
http://teamserpent.com/2013/03/spain...tc-110-and-f1/
Geberit is offline   Reply With Quote
Old 03-02-2013, 09:11 PM   #5279
Mitchy1986's Avatar
So anyone out there running a s411 in stock 21.5??? Having trouble finding the right gear ratio! also need the gears from a supplier any info would be great thanks
Old 03-03-2013, 03:51 PM   #5280
Default s411TE
For sale in that section of the fourm
S411TE AND LOTS OF PARTS
1airborne
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
