Old 02-22-2013, 02:39 AM   #5251
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Johnny Wishbone View Post
The last time I ran into a weird tweak issue like that, I also thought it was caused by the upper bulkhead/shock tower. I finally got the car flat by having the shock towers on, the upper bulkheads secured properly and had the top plate on the car as well. Then I loosened the bottom chassis 2 screws on the lower bulkhead on the side that was on the low side, the car almost poped into place and I haven't had a issue since. I really though the problem was coming from up top, but it wasn't. This may be your issue as well. My 2.0 is very flat and tweak free.
Originally Posted by TryHard View Post
Hmmm, my car tweaks up perfect on my MIP tweak station, shocks all equal l-r.
When your putting the towers on, make sure to tighten up the countersinks first, before tightening down the clamp tops. Also worth loosening and retightening all the bottom screws as Gary mentions.
Thanks for the suggestions guys. I got the tweak out after about 2 hours of messing around. I think it was a combination of not doing up the shock towers as described and a tweak in the motor mount when I changed from flex to stiff. I also found my sway bars were not 100% either so it's been a good exercise in being more thorough with a new car.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 02-25-2013, 05:53 AM   #5252
Geberit's Avatar
Any info how was Fischer doing on the TITC 2013?
Geberit is offline   Reply With Quote
Old 02-25-2013, 08:58 AM   #5253
performula's Avatar
The S411 RTR and S411 Sport are the same correct? How are the Dragon components?
performula is offline   Reply With Quote
Old 02-25-2013, 10:12 AM   #5254
Finshed now, but I'm not sure. I would like to know too.
I think he qualified 10th in B main. And another Serpent driver Ryan Maker also in the B.
gerg is offline   Reply With Quote
Old 02-25-2013, 04:30 PM   #5255
TryHard's Avatar
Fischer came in 10th or 9th in the B I think, but I know Ryan qualified 14th, and had two very good finals to take out the B main win, ahead of guys like Hagberg. Very good result, given the depth of the field this year (Tam, Xray, Yokomo, HB all had v.strong teams).
Ed
Old 02-25-2013, 10:57 PM   #5256
I have questions regarding the different diffs and the "compatibility"
How do I see the difference between the "old" V1 and V2 diffs? Is the "old" V2 housing the same as V2 composite. Can I use the smaller composite gears in the old V2 together with the metal bigger gears?
Maybe there is something in the older threads but I did not find it.
Linguster is offline   Reply With Quote
Old 02-26-2013, 12:09 AM   #5257
Benzaah's Avatar
How do I see the difference between the "old" V1 and V2 diffs? Is the "old" V2 housing the same as V2 composite. Can I use the smaller composite gears in the old V2 together with the metal bigger gears? yes
The difference between V1 and V2 diffs is the satellite gears have changed pin diameter and gear shape and are not interchangeable. You can fit the smaller diameter V2 gears in a V1 diff but it makes a mess quickly. There have been changes in the gears between the V2 and composite diff but the satellite gears are interchangeable. The larger gears have stayed the same size but are attached via a pin slot now instead of a screw. Avoid buying any of the cheap diffs most shops are clearing out currently. Only invest in p/n http://serpent.com/product/401592/
Adelaide RC
Walter Rc Hobby
Old 02-26-2013, 04:26 AM   #5258
Originally Posted by Benzaah View Post
Only invest in p/n 401592
I was pleasantly surprised that these new diff were less than $25 for the complete diff, so much cheaper than the old one. I bought two so I can easily compare changes by swapping the diff out, as well as one for the front.
At least from the shop I bought from....... not sure about the others.
Old 02-26-2013, 09:24 AM   #5259
Toughbeard's Avatar
The Sport kit had the plastic shocks. the RTR have alu shocks in the kits we ordered...
Mustafa Won the race in Cyprus using a Sport in Stock class as the Eryx was not in yet. He actually beat the times in Mod with it as well.
We will do a test soon to see how the dragon rc stuff works. I do not think there will be any issues.
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 03-01-2013, 02:48 AM   #5260
TryHard's Avatar
What... page 3?!?!?!
Old 03-01-2013, 03:30 AM   #5261
M7H
M7H's Avatar
OEM is Hobbywing, take your conclusion from there.
Serpent
M7H is offline   Reply With Quote
Old 03-01-2013, 04:18 AM   #5262
Toughbeard's Avatar
it works LOL
Serdar Aytemiz
Old 03-01-2013, 04:23 AM   #5263
Geberit's Avatar
The indoor season is ending here in middle Europe. Outdoor season starts around April depends on weather Ö at the moment we have still snow and low temperatures. So not much racing here.
ETS Gran Canarias started today hope the Serpent Team does well:
http://teamserpent.com/2013/03/spain...tc-110-and-f1/
Got my ERXY this week, will prepare it for the outdoor season. Maybe end of March my firs outing if Iím lucky.
Now Iím very interested how the car will perform on low to medium bite tarmac.
Old 03-01-2013, 05:09 AM   #5264
M7H
M7H's Avatar
Originally Posted by Toughbeard View Post
it works LOL
indeed, and that's all there is.
The RX/TX set is nice actually, ran it once indoor, to answer some questions there were about the car.
Although it is a sensorless set, it drives quiet nice.
Serpent
Old 03-01-2013, 05:38 AM   #5265
TryHard's Avatar
Well, we're meant to be in the middle of summer here in Australia at the moment... and I haven't raced in almost a month due to it mainly having been raining every weekend!! Typical, eh!
Still, very interested to see how the ETS turns out, with the new car on a more normal traction surface (TITC always tends to throw up some crazy settings!)
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
