Old 02-20-2013, 01:50 AM   #5236
Holmenkollen's Avatar
Originally Posted by jimjav View Post
I am having some issues during the built of the eryx,
I have too much side to side movement in the midle axle, I am talking about 2 mm, I have also the same issue in the spool. For the spool I have try another set of eccentrics that I have as spare in my toolbox and the results is the same. For the middle axle I will tray another sets of bearing but I donīt belive that this will resolve the problem
Anyone has the same problems? Ideas for solution?
My first impresions abour the few things that I have built is that the gear diff it's so good, and the new arms seem quite better
regards
I also had the side-to-side play but a couple of shims took care of it. I also got a CVD wheel axle which was to big to fit a bearing. I had to wet sand it to make the bearing fit. My LE went together without any quality issues.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 02-20-2013, 02:52 AM   #5237
TryHard's Avatar
Originally Posted by TheZoof View Post
Thank you for the tip. I understand how to fix it however on a new product, this shouldn't be necessary. Especially on $75 cvd units. I will see what Serpent has to say before making my own fix. I would expect them to send me the individual part of the out-drive that is manufactured incorrectly, at minimum.
There is always solution to a problem, except I should certainly get what I paid for before using it.
Interesting. I've had 3 sets of DCJ's in my cars, never had this issue. Seems strange that two seperate people have had the same problem... maybe a bad batch
regards
As Holmenkollen said, shims are your friend here. Seems to be the same on all Eryx's (reminds me I need to check my centre shaft!)
Originally Posted by corallyman View Post
Thanks for the answer Ed, I followed the manual or at least I meant too. I will double check later today. I think my rear shocks might be shorter than they need to be for the settings that I currently have on the car. Despite a slight rush job to get the car running, it was still pretty good. I really like the Eryx.
Yeah, don't be afraid of unwinding the shock bottom a bit if your struggling to get the droop.
Old 02-20-2013, 04:06 AM   #5238
Ok, I will pic some shims and remove that play.
For the spool I am going to change from side the bearingblocks to see if I notice some difference in that side-to-side play
I willl try to finish my car this weekend and if the weather is nice trying to make the first runs on sunday, because the weather guy it's talking about snow during saturday morning :S
So many thanks guys
jimjav is offline   Reply With Quote
Old 02-20-2013, 01:14 PM   #5239
LOW ET's Avatar
Trader Rating: 95 (100%+)
what shims are you guys using on the middle axle? i only seem to have about 1mm play.
LOW ET is offline   Reply With Quote
Old 02-21-2013, 08:02 AM   #5240
rcwck's Avatar
Originally Posted by TryHard View Post
The next thing I had a play around with was springs again, and I'm pretty sure (although this was all down by calibrated hand on pit table ) that using the same springs front and rear isn't a good idea for the Eryx... let me explain.
Basically, I fitted the TE and Eryx with the same springs (Ride Blue F, Yellow R), put kit shock positions on both cars (Holes 3F 4R... although I already know they aren't quite the same). When doing a pushdown test, the Eryx felt both a lot softer on the front, and a little harder on the rear the TE.
Interestingly, I switched the TE back to the same spring F&R (Ride Green), and it felt very similar to the Eryx with the Blue/Yellow. A smidge softer on the front, and very similar on the rear. Moving the Eryx to hole 2 on the front tower, and both cars felt almost exactly the same on the table.
Obviously, this is only a guestimation based on a push test, but I think the findings were pretty interesting. I do know that I'll be leaving the Blue/Yellow combo on the car to start with this weekend, as the rates give a similar split (albeit softer all round) to the HPI Pink/Silver I ended up on last time out....
Wondering which springs you are testing. The Ride Soft Version or the Ride M-Chassis type? I want to test some and need to know which version is better fitting for the new short shock Eryx.
thx
rcwck is offline   Reply With Quote
Old 02-21-2013, 09:40 AM   #5241
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Eryx uses standard length springs
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 02-21-2013, 10:54 AM   #5242
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Jeff, did you manage to get to 4.8-5mm ride height in the front with yokomo springs? I'm at 5.5 and can't get much lower?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 02-21-2013, 11:56 AM   #5243
Depends on the tire. I'm runni.g the sweep qts32 with the new rims they have on the premounts. And I was down to 4.8 and had to adjust to get 5.0 in the front with my shocks in hole #2 on the tower. When I put on my old sweeps the car was at 5.2 with the collars all the way up.
Old 02-21-2013, 01:36 PM   #5244
Benzaah's Avatar
Trader Rating: 21 (96%+)
Has anyone got issues with either the shock towers or the bulk head clamps tweaking the car? The chassis is flat on the board when the towers are off and there is not a noticable tweak in the chassis by the flat edge of my Verniers. It's there on the hudy tweak station and I have it within a turn and a half on the shocks to dial it out but for a new kit I don't think this is acceptable. Is this something anyone else is experiencing? I feel like the counter sunk holes in the shock towers are tweaking both the front and back end.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 02-21-2013, 01:50 PM   #5245
Johnny Wishbone's Avatar
The last time I ran into a weird tweak issue like that, I also thought it was caused by the upper bulkhead/shock tower. I finally got the car flat by having the shock towers on, the upper bulkheads secured properly and had the top plate on the car as well. Then I loosened the bottom chassis 2 screws on the lower bulkhead on the side that was on the low side, the car almost poped into place and I haven't had a issue since. I really though the problem was coming from up top, but it wasn't. This may be your issue as well. My 2.0 is very flat and tweak free.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-21-2013, 03:34 PM   #5246
Good news.
Serpent will be sending me replacement parts for the shock shaft and DJC cvd issue.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 02-21-2013, 04:32 PM   #5247
TryHard's Avatar
Hmmm, my car tweaks up perfect on my MIP tweak station, shocks all equal l-r.
When your putting the towers on, make sure to tighten up the countersinks first, before tightening down the clamp tops. Also worth loosening and retightening all the bottom screws as Gary mentions.
Old 02-21-2013, 04:46 PM   #5248
TryHard's Avatar
thx
As mentioned, they are the Ride Softs, in White (13.9lb/248gf), Yellow (14.6lb/259gf), Green (15.2/272gf) and Blue (16.1lb/287gf).
One thing to note, is Ride also have a Silver spring that is quite close to the Green (15.0lb/268gf), but I tend to not run them as they have a different wire diameter to the soft versions, so tend to feel different on track.
Having said all that, I have Yokomo pink and blue on the car to test out next time anyway...
Oh, and in terms of ride height, I can happily get to less than 5.0mm on the front with both Yok and Ride springs. That's with Ride and MuchMore tyres though.
Old 02-21-2013, 08:50 PM   #5249
xevias's Avatar
3Racing 5mm shims worked great for me.
3RAC-SW05
xevias is offline   Reply With Quote
Old 02-22-2013, 12:11 AM   #5250
Finaly I remove the side-to-side play in the spool, only changing the side o the bulckheads.
Tamiya 5mm there is a nice set that came with ten units of each size: 0.1, 0.2 and 0.3.
Finally I only needed 0.4mm to remove the play.
Yesterday I have half an hour of free time to follow with the assembly and I discover that fiting a servosaver it's quite difficult, I am using kimgbrough midsize and I need to sand it a bit because it was rubing a bit with the cf part of the servo mounting.
cheers
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
