Old 02-01-2013, 02:19 AM   #5116
Geberit's Avatar
Originally Posted by jimjav View Post
One small question, How do you prepare de cf parts? In some days i have to start preparing a new chassis and I have never done that.
cheers
http://www.teamcrc.com/crc/modules.p...article&sid=16
Geberit is offline   Reply With Quote
Old 02-01-2013, 02:19 AM   #5117
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Benzaah View Post
Can you check your tracking as mines says my parcel has not even been collected to leave Sydney yet
i have mine. just about to start the build. try to get it ready for testing tommorow arvo.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-01-2013, 02:21 AM   #5118
LOW ET's Avatar
Trader Rating: 95 (100%+)
do the carbon battery stays come with the new kit?
LOW ET is offline   Reply With Quote
Old 02-01-2013, 02:29 AM   #5119
Pattojnr's Avatar
yes they do.
Serpent - Walter RC
Old 02-01-2013, 03:01 AM   #5120
Geberit's Avatar
Regarding battery taping. Top racers don't use the carbon LiPo retainers they just tape the battery. So my question is how firm do they tape it and how does this affect the flex?
Old 02-01-2013, 04:48 AM   #5121
Pattojnr's Avatar
here is a pic of the new full floating servo mount. 2 screws attatch it to the steering posts. its very nicely thaught up.
Serpent - Walter RC
Old 02-01-2013, 06:37 AM   #5122
andyw2's Avatar
Just a simple question from a fairly newby. What thickness are the standard wheel hexes on the earliest model (2.5mm carbon chassis). I'm having trouble getting the VTA wheels inner rim to clear the front steering blocks, and at the rear shockie bottom mounts. I have 0.5mm washers on the front and used the rear shockie inner bottom mount hole which has resolved the problem. But I got the +1mm wheel hexes (401387) which are 5.2mm width, same as was already on the car!
Andy W
Mugen 1/8 GTconverted eco buggy
Mugen SCT converted eco buggy
andyw2 is offline   Reply With Quote
Old 02-01-2013, 08:23 AM   #5123
Johnny Wishbone's Avatar
They all use the same hex........not sure what the +1mm hex actually means as its the same width as every other Serpent hex I've ever had. If you want to get wider in the front, the Xray +1.75 hexes will work, the pin depth is the same, but you will have to open the hole up slightly for the axle shoulder to pass thru. There is still lots of axle thread left if you run them as well.
As far as battery taping goes, I ended up making some retainers from some standoffs, they just cover the front and rear of the battery, but allow for the battery to float a little without tweaking the car. I've run this for about 2 months now and haven't lost a battery yet. The setup still uses the stock lower retainers, but no tape is nice not having to deal with. This is similar to the setup that RSD offers, well worth looking into.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-01-2013, 09:19 AM   #5124
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
First thing i bought for the car was the velcro straps. I use the plastic bits and a couple weights to keep it sliding inboard. Ahim up te lipo blocks 2-3 mm and i dont have to sinch it down any.
My stuff
| Sanwa - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 02-01-2013, 02:46 PM   #5125
Holmenkollen's Avatar
The car went together nicely. A few issues: one of the wheel axles was little bit too large so the bearing didnīt fit. Luckily I had an extra one. The shock collars sits really loose on the shock body. Donīt know if this is a issue on the track but it could be. The dampers are really nice though, big improvement.
The drive pins now have a flat spot so you can really crank down the set screw.
The spur gear assembly had a lot of side-to-side play, never had this much on the TE. A few shims took care of it.
These issues will surely be addressed in the next batch.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 02-01-2013, 08:02 PM   #5126
Pattojnr's Avatar
i hope Serpent release a long set of these shocks. they are so much better. i can also see why Marc is having way more success with this new car. shocks, steering, arms, and overall quality is by far much better. but in saying this i have a problem with my top deck. i havent looked into it much yet, but looks like the hieght of the bearing housing for the spur gear are way higher than the support post. i tighten the top deck, and it bends like a bananna over the bearing housing. may need to grind a flat, or i may shim up the top deck for today. hope to give it a run in a few hours time.
Serpent - Walter RC
Old 02-01-2013, 09:47 PM   #5127
Moderator
DaveVera's Avatar
That sounds odd. Are you using the 2, 1 mm washers that go at the very rear under the top deck?
Motiv, Gravity RC, Joe Conte Racing ,Blast RC Paint, Sanwa, #~MASAMI~ . ROAR#27050
DaveVera is offline   Reply With Quote
Old 02-01-2013, 11:14 PM   #5128
corallyman's Avatar
Trader Rating: 98 (100%+)
My ERYX is about 70% done. The car is fantastic and everything looks and feels great. I'll finish it off in the morning.
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 02-02-2013, 12:08 AM   #5129
Pattojnr's Avatar
thats what you get for skipping instructions. haha. i went to put the top deck on just to set my battery up for clearance. all sorted. i did how ever get to that part later. but i have also found an issue with an Axle also. thanks for spares i can go for a run shortly. the thread is partly there. whell nut went on by 5-6 turns then went all loose. i could not get it off. luckily i put on an old set of tyres to set cambers. i had to try to pull the rim off as i was trying to unscrew the wheel nut. my shock collars are also quite easy to turn when the springs are on. i think a different O ring will fix that. ill see how it goes. other than the Axle, no real issues. love the servo setup, so easy to work on.
Serpent - Walter RC
Old 02-02-2013, 03:41 AM   #5130
TryHard's Avatar
I was about to say... check the instructions, need to add 1mm shims there now!
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
