Old 07-05-2011, 06:51 AM   #496
mattwoodcraft's Avatar
cheers mate
i look forward to finishing my car when get back home from work
mattwoodcraft is offline   Reply With Quote
Old 07-05-2011, 07:28 AM   #497
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Was setting up one of these on the weekend, got it running really well and had a few laps after. Got it pretty close to spot on but im not sure if i was able to go as fast as my HB Definatly got potential though. Changed a lot from kit i believe.
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 07-05-2011, 08:36 AM   #498
29TC's Avatar
Send a message via ICQ to 29TC
Whats the biggest tooth spur that will fit in the S411 in 48P & 64P?
Also whats the internal ratio? Cannot seem to find any info from the downloaded manual.
- Ops....Found it 2.0 internal ratio
By the way you guys mentioned using xray spurs. Are you all using off-set spurs or not?
Thanks in advance.
29TC is offline   Reply With Quote
Old 07-05-2011, 09:03 AM   #499
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Thanks in advance.
No just standard xray spur
I know 48p/84t max...I think 104T...will check later in the day after work
OVA is offline   Reply With Quote
Old 07-05-2011, 09:16 AM   #500
Thanks in advance.
Im running 64p/112 but a guy I know squeezed in 114...?
joachimG is offline   Reply With Quote
Old 07-05-2011, 11:59 AM   #501
corallyman's Avatar
Trader Rating: 97 (100%+)
Thanks in advance.
I personally feel that a 84t 48 pitch and its equivalent 112t 64p spur are the largest I will ever put in my car. If you own a dremel you can create a little extra room for a bigger spur, but the teeth would be really close to hitting the ground when your chassis bottoms out, it's pretty darn close with a 112t now.
I have a PRS 112t in mine now and I think I am switching to a 106t 64p Team Associated TC6 spur gear.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 07-05-2011, 01:43 PM   #502
OVA
OVA's Avatar
Steve
Hey Steve
wouldn't you think the 106T spur it's kinda too big for 17.5 NB?
Old 07-05-2011, 05:04 PM   #503
corallyman's Avatar
Originally Posted by OVA View Post
Hey Steve
Maybe, probably. Honestly I have not spent that much time looking into it. I do own smaller spurs if needed. I recently just acquired some major mongo pinions when needed.
I do plan on running mod more than 17.5 NB.
Steve
Old 07-05-2011, 09:06 PM   #504
snoopyrc's Avatar
How is the crank compared to the S400? I was going to run an S400 in VTA but I think I will go USGT with it. So that is still geared up there on a 21.5.
I think the spurs I have been using are 1/12th spurs. Robinson or precision engineering? I will have to go look. Anyway none of them fit the crank. I have to drill out the two extra holes to get the spur to go on. At least with all of the screws. I may keep my eyes open for an S411 to come available used.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 07-05-2011, 09:18 PM   #505
corallyman's Avatar
Do you mean the center pulley shaft. If that is what you mean, then it has 3 holes in it. The spurs require the TC spacing. Usually the spurs meant for only TC use have 6 holes drilled nearest the center of the spur. 1/12th scale spurs have 8 or 12 holes around the center, if you use a dremel and make some modification than you can get almost any spur to work.
Xray has some small spurs in the TC configuration.
Steve
Old 07-05-2011, 09:40 PM   #506
Steve
Ya, I am using a xray 84T spur now. and it is very close to the bottom of the chassis already. Don't think it can go bigger without the spur stick out.....
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 07-05-2011, 09:50 PM   #507
snoopyrc's Avatar
Seems like a 104t would fit without any problem. Then again I am not looking at it.
Old 07-05-2011, 09:51 PM   #508
corallyman's Avatar
84t 48pitch correct, Yes I am using a 112t 64 pitch which is the same gear only in 64 pitch and I would not put anything bigger in. I definately think the teeth could get chipped by debris. I am swithing to a 106t 64 pitch.
Steve
Old 07-05-2011, 10:49 PM   #509
OVA
OVA's Avatar
Steve
Come on steve ..I was just messing with you...hope to see your mod serpent on the track.......
Hopefully JB got his ready...can't wait to hear JB serpent @FW this sunday..I'll be out of town this coming weekend...
Old 07-05-2011, 10:54 PM   #510
skypilot's Avatar
Trader Rating: 14 (100%+)
how in the heck are you going to hear his car if your outta town, I'm pretty sure he knows how to set gear mesh.
don't think hes even got it yet.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
