Like Tree16Likes
Serpent S411
Old 01-17-2013, 10:01 PM
  #5011
corallyman's Avatar
Trader Rating: 101 (100%+)
Originally Posted by TryHard
something else I just picked up on... shock volume is the same with the lower shocks... so does that mean bigger diameter bodies (and new pistons?) or has the height all been removed from other parts, so the damper body is still the same size... looking at the pics, I'm guessing the latter
Hello Ed,
You can pretty much see what they appear to have done to the shocks. The top and bottom aluminum parts look to be shorter, and also the top and bottom plastic parts are shorter as well. This appears to be were they made the difference and still allow the standard length springs to be used. They mention that pretty much all the parts are interchangeable within the other versions and the new car. Time will tell though.
I think the new car looks great and they did some very clever things on the new car. Can't wait to get one.
Steve
corallyman is offline
Old 01-17-2013, 10:47 PM
  #5012
It looks like you could almost use the shorter plastics on the old shocks and they might be short enough for the new tower.
Steve S is offline
Old 01-18-2013, 01:27 AM
  #5013
Originally Posted by corallyman
Hello Ed,
Steve
The new shorter shocks have only one silicone o-ring. The old shocks have two plus a second delrin shim. That shortend the inside with aprx. 3 mm. Another thing is the top. The top is lowered and a new membrane is in the top. That is another maybe 2 mm you can add to the inside volume. You can use the same springs as the bottom linkage is shortend up and the spring collar is lowered, therefore, you can use the same lenght of springs.
BCDK is offline
Old 01-18-2013, 01:28 AM
  #5014
RC MARKET's Avatar
Serpent released Servo Mount Direct
RC MARKET is offline
Old 01-18-2013, 02:12 PM
  #5015
LOW ET's Avatar
Trader Rating: 109 (100%+)
i wonder which chassis, top deck, and motor mount everyone will end up using.
LOW ET is offline
Old 01-19-2013, 06:35 AM
  #5016
corallyman's Avatar
Default Short summary---Check out the full coverage
The new car is doing very well at the on-going ETS race. Marc Fischer finished 4th in the second round, and second in the third round. Volker got him by 4 hundreths of a second.
Not too bad for a guy who missed the first heat of practice because of travel issues and had to run someone else's car in the second practice because he did not have time to get his own car ready having just arrived. Pretty darn impressive. Other Serpent drivers are doing well as well.
Coverage is on Redrc
Old 01-19-2013, 10:01 PM
  #5017
Now that is cool .
fasteddie d is offline
Old 01-20-2013, 01:55 AM
  #5018
whityboy's Avatar
some pics and info on marc fisher's car
http://ets.redrc.net/2013/01/chassis-focus-marc-fisher/
whityboy is offline
Old 01-20-2013, 02:39 AM
  #5019
Marc is in the first place after 2 finals.
DomenL is offline
Old 01-20-2013, 02:20 PM
  #5020
Benzaah's Avatar
Trader Rating: 24 (96%+)
Fischer second overall at ETS. Car looks awesome on track. Can't wait to get my hands on this ride!
Benzaah is offline
Old 01-20-2013, 02:39 PM
  #5021
Trader Rating: 84 (100%+)
Car looks great . Good run Fischer despite lack of practice
jeff jenkins is offline
Old 01-20-2013, 03:33 PM
  #5022
LOW ET's Avatar
here's a question for everyone, how high are the bottom of your bodies from the racing surface, front, sides? after looking at some pictures from the euro series it seems that the bodies are really slammed on the chassis or they are cut pretty high off the ground. looking at the front splitters, they seem to be very thin compared to all the bodies i've done and seen in person.
LOW ET is offline
Old 01-20-2013, 04:48 PM
  #5023
Wow, that was a great race
Steve S is offline
Old 01-20-2013, 07:09 PM
  #5024
duckman996's Avatar
Trader Rating: 14 (100%+)
I would think the dots have something to do with the height, especially the front splitter.
duckman996 is offline
Old 01-20-2013, 07:36 PM
  #5025
valk's Avatar
any idea when the new parts will be available. I might look at upgrading one of my TE's to the new spec. lower shocks, steering ect.
cheaper than a whole new car and there isnt really anything wrong with either of the cars atm.
valk is offline
