Like Tree7Likes
Old 01-01-2013, 11:55 AM   #4891
LOW ET's Avatar
Trader Rating: 97 (100%+)
Originally Posted by 4wdmonster View Post
I run 64p 17.5 with a 96/49 and change pinion a tooth or 2 depending on track size
thanks for the info.
LOW ET is offline   Reply With Quote
Old 01-01-2013, 02:57 PM   #4892
No prob hope it helps
4wdmonster is offline   Reply With Quote
Old 01-01-2013, 04:02 PM   #4893
LOW ET's Avatar
i don't have pinions that big, only up to 47. i wonder what's the smallest spur that can be used and still have adjustment for pinion mesh.
Old 01-01-2013, 05:12 PM   #4894
Trader Rating: 42 (100%+)
Default 48 p
i have measured 48P 69 tooth to be very close to 96 tooth 64P.
I have them ordered and will let you know how it fits by thursday.
The reason i want 48P is easier to set mesh and 48P can handle a little carpet fuzz with less issues.
Mike
miket3 is offline   Reply With Quote
Old 01-01-2013, 06:04 PM   #4895
Johnny Wishbone's Avatar
Hey guys I'm new to the serpent worlds have owned several other touring. Cars but got a heck if a deal on a serpent and its one of the only brands I haven't driven so I figured I would give it a try .does anyone know of a good site to look for a good basic setup for a high bite carpet /ozite track . All I have found is older setups and I'm just wondering if there is any up to date ones .. Thanks in advance
Try the setup section of the Serpent site, (http://www.serpent.com/racing/setups/) as well as Petit RC (http://www.petitrc.com/reglages/serp...rpentS411.html) site has a lot of carpet setups. Remember that from the S411 thru to the S411TE the car is basically the same so the setups really don't change. A good starting baseline setup is Martin Crisps Canadian Nationals setup.
what he said^^^
what pinion/spurs are you guys running in 17.5 blinky (64p for me)?
I run 64p 90 tooth, but I can tell you that without knowing what your running for a motor, speed control and how much motor timing you run and the size of the track, giving you a pinion size is pretty useless. A good all around starting fdr is 4.0, watch your temps and re-gear as required.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-01-2013, 06:13 PM   #4896
Default Stock Servo mount mod
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-01-2013, 07:02 PM   #4897
LOW ET's Avatar
that's what i was guessing, somewhere between 3.7-4.0fdr. but there are many ways to come up with that number. i'm more interested in what gears will fit in the car. for example will a 82/44 or 82/41 combo fit in the car, giving proper adjustment for mesh? i don't know because i don't have the gears here to try.
Old 01-01-2013, 07:18 PM   #4898
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
for 17.5 blinky i have 96-100 in car. 47-55 pinions seem to fit. 64p obviously. 47? weird eh. thats a ratio 4.22 but im trying it with a high rpm rotor to see how it stacks with the higher torque motors like the d3.5.
Have the stock rotor too, but from testing at our last indoor night, the power band was easier to handle. less likely to rip the ass end aruond exiting corners and had more top end rip on the straight.
3.6-4.0 seems the norm for this class. 3.8 seemed pretty lazy though. fast..but i tend to slow down for corners to save my tires. drive a shorter line if possible.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 01-02-2013, 12:11 AM   #4899
Holmenkollen's Avatar
Originally Posted by TryHard View Post
So, tonight I had a little play around with the steering rack on my car. Given the talk of using FF steering posts recently to lower the rack a little, I had a thought that with the space on the car, possibly it could be lower still, opening up some more options for tuning the bump steer.
The pics show what I ended up with. Flipping the bellcranks (to the original 411 style) and servo post, and then using a 1.5mm shim underneath, the whole rack has dropped about 2.5mm.
With the standard TE rack install, the cross brace is about 11mm off the chassis (pic shows 11.5 ish, but the angle is off), whilst the lowered rack is 8.5mm. Only special parts I needed was a standard nut on the forward screw of the servo mount (third pic), and to trim a little material off the battery brace for full lock. I will also trim down the servo posts for clearance of the servo tie-rod. Clearance is fine, no issues with catching the belt at all
With that setup, running 2.5mm shims on the steering hub gives the same bumpsteer setting as kit, but also means less can be run as well... hopefully will get to try this out this weekend Might need a slight tweak to the ackerman spacers as well though, as a lower outer ball joint will move slightly forward (steering hub is at 4° due to castor), will have a play around with it if I get the chance.
Regards
Ed
Are you flipping the FF steering posts or the standard TE ones?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 01-02-2013, 02:13 AM   #4900
TryHard's Avatar
Standard TE ones, although these are now cut short so I can't flip them back. Everything else is lowered as well, as I've flipped the bell cranks (back to the way up the original 411 v1 steering had them), so the deeper section is at the bottom. This is why I only have 1mm under the 'flipped' posts.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-02-2013, 02:20 AM   #4901
@jimjav
hi! Javier,
if you use Xray diff you only have to dremel it a little bit and it fits perfect.
ok, I know, it is not Serpent original spare part... but it works and, I know it, the diff is muche more expensive than Serpentīs... but the weight is 15gr less...
gonzo_design is offline   Reply With Quote
Old 01-02-2013, 08:24 AM   #4902
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Is roar minimum weight 1350 or 1380 I could have sworn I saw 1350 but the carpet regionals I am entering says 1380 (my car is 1340 fully loaded with side balancing weight)
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 01-02-2013, 08:33 AM   #4903
valk's Avatar
1380. you must have really light electrics. i came in at 1374 right down to body pins ha.
My stuff
My RC
Old 01-02-2013, 08:37 AM   #4904
gearhead_22's Avatar
Send a message via AIM to gearhead_22
1340 damn are you using a pro lite body?
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 01-02-2013, 08:37 AM   #4905
Maybe. lol I did build the kit with all titanium screws and I use sweep KittyRug tires and inserts. idk but I swear that's what it is. Thanks.
Maybe I can just instal the steel hardware and get to where I need to be.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
