Old 12-08-2012, 05:44 PM   #4801
I asked the same question 2 pages ago Looks like the Xray might be close, but I think I will go with some smaller spur gears instead of fiddling with pulleys.
Team Serpent
Steve S is offline   Reply With Quote
Old 12-08-2012, 11:28 PM   #4802
Unless the T4 has different gears, xray gears will not fit. Tried last year and they are too wide to fit in the bulkheads. Too much to even machine some off.
duckman996 is offline   Reply With Quote
Old 12-09-2012, 04:41 AM   #4803
Toughbeard's Avatar
Originally Posted by Johnny Wishbone View Post
401512 according to exploded drawing diagram, BUT if you look at the spare and option parts for the FF it gives other numbers again. When I search either number (410512 or 401512) on the Serpent site, I get nothing???
I have couple FF cars... I ll take photo and send
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 12-09-2012, 01:53 PM   #4804
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
So. had my stock car out last night and quite surprised how it handled the 12th scale track.
setup "couldnt save pdf, sorry!"
put a pack and a bit worth of practice on the car between 12th scale heats and the car was quite easy to drive considering the confines of the track. i expected it to slide around more than it did. actually was very direct and responsive which definitely turned a few heads walking by the track.
average amain 12th scale laptimes were 9.5-9.7 in 17.5 boost and i was able to pull 10.6-11.1 with old OLD rubber tires. quite happy so far. able to keep up to the mid heat 12th scale drivers which is kinda cool.
i tried the stock rotor with a typcial 3.8-4.0 fdr but i think there was too much slowing down on this track and it came off north of 160 that way.
swapped to the 12.3x24.5 rotor and a 4.2 ratio and it seemed to go a lot better. smoother power and better speed overall. probably leave that rotor in there depending on the layout at the winspear.
now have to figure out the mod car... probably similar setup with a little more droop and less arb.
any suggestions?
My stuff
| Sanwa - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 12-09-2012, 11:12 PM   #4805
Holmenkollen's Avatar
Last practice I tried the flex top deck vs standard 2 mm (401374) and my car worked better with the standard top deck. Grip conditions was low-medium. The car felt too safe with the flex top deck, maybe it´s better when the grip is really high. I drive modified on carpet.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 12-11-2012, 03:51 AM   #4806
Originally Posted by BCDK View Post
Hi.
If you are racing the DHI Cup in Denmark in January 2013, please take a look on the Serpent homepage under Team blog.
I will try to arrange a pit area for Serpents only.
Hi.
At the moment I've booked at table at the DHI Cup for 12 Serpent drivers.
If you haven't send me a message, and still want to sit at the Serpent table, please do it soon. Later it may be impossible due to other wishes from other brands or clubs.
Thank you.
See you at the DHI Cup in Odense in less than a month.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 12-11-2012, 02:57 PM   #4807
Flux's Avatar
Can someone please explain a split top deck to me?
Flux is offline   Reply With Quote
Old 12-11-2012, 03:16 PM   #4808
Trader Rating: 14 (100%+)
Its when you cut the last brace on the rear of the top deck. Its the brace with the hole that secures to the v1 motor mount. If you take your top deck and cut right through that brace you will notice it really makes the car a lot more consistent. Hope this helps
Alston Kelso
Destiny USA•SMC Batteries•Reilly Paint•CEFX
Detroit Racing Team
"Let's See, Open it up" -Chris Goetz
98tahoeboy is offline   Reply With Quote
Old 12-11-2012, 03:59 PM   #4809
I have a V2 motor mount. Do I need to do this. I have the TE. A picture would be great.
1airborne
serpent cobra 811TE, Cobra 811T,Serpent S411TE,rebel12 pan car, VPfuel, Buku clutches, Novi motors
1airborne is offline   Reply With Quote
Old 12-11-2012, 04:29 PM   #4810
Flux's Avatar
Thanks for the quick reply.
So are you saying there is no screw connecting the top deck to the motor mount, and you cut out that middle section?
A picture would be most helpful
Old 12-11-2012, 04:58 PM   #4811
Ok so the v2 motor mount is the only way I run my car. If u run the v2 motor mount the correct way there is no reason for the rear brace what so ever. Some people run the v2/v1 which is y some still run the full top deck. I find the car really inconsistent with the top deck not cut. But here are the pics.
Alston Kelso
Detroit Racing Team
Old 12-11-2012, 05:49 PM   #4812
valk's Avatar
Is one motor mount better than the other? looks like my TE car has a two peice motor mount where the mod car has a one peice mount. both of the top decks look the sam e thickness but the te car has cutouts in the front of the top deck.
My stuff
My RC
Old 12-11-2012, 07:30 PM   #4813
Ok it's all based on preference of how u want the car to feel. I believe we all want a consistent car and through much testing I have found the 1 piece motor mount and a cut 2mm standard top deck to be the best. On your TE the top deck you have is a 2mm flex that's y more carbon is cut away. The 2 mm standard is on your other car.
Alston Kelso
Detroit Racing Team
Old 12-11-2012, 07:51 PM   #4814
valk's Avatar
so should i leave the flex deck on the te car for stock, and the one peice motor mount on the mod car? i don't have a lot of tracktime with touring cars sadly =(
the stock car felt pretty good when i had it out, just want some more out of the mod car if i can.
My stuff
My RC
Old 12-11-2012, 07:52 PM   #4815
valk's Avatar
My stuff
My RC
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
