Old 07-01-2011, 04:19 AM   #466
venom54's Avatar
Default SPEC-R BLADES
Originally Posted by Akhor View Post
Where can we order those specR blades? I can not find them on A-Main or hobbypartz...
I you're still having trouble locating the blades we have these in stock.
Cheers
Ren
RAB Hobbies
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 07-01-2011, 11:10 AM   #467
corallyman's Avatar
Trader Rating: 97 (100%+)
Cheers
Ren
RAB Hobbies
Did you also say that TC6 blades also work, I have not yet had a chance to get spares and if I need to switch out in a hurry I would like to be prepared.
Thanks,
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 07-01-2011, 11:48 AM   #468
Verndog's Avatar
Trader Rating: 16 (100%+)
Thanks,
Steve
Steve, I have several packs of TC6 blades we can test Saturday. Xray 3.5mm blades will fit the TC6 also and are thicker and take spool hits better as well...but at $1.00+ ea they otta.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-01-2011, 12:53 PM   #469
corallyman's Avatar
Cool, Thanks VernDog, see you on Sat.
Steve
Old 07-01-2011, 03:42 PM   #470
venom54's Avatar
Default S411 BLADES
Thanks,
Steve
Yes they do as well as the SPEC-R BD Blades and others. I've found the SPEC-R just to be a cleaner fit. The AE blades need to be lightly shaved on emery paper just so, as they are a slightly to tight into the cups. SAKURA ZERO blades fit as well.
Cheers
Ren
Old 07-02-2011, 12:35 AM   #471
JayBee's Avatar
Trader Rating: 31 (100%+)
Any ceramic bearing kits out for this car yet?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-02-2011, 07:41 AM   #472
Scott Kimbrow's Avatar
Originally Posted by OVA View Post
What's Empire hobby phone number to call..Thanks
Sorry guys. Been a crazy couple of days. You can reach me directly at 916-203-3109. Thanks
Serpent / Serpent America / Novarossi / Spektrum / Xceed Tires / Tornado Fuel / Empire Racing / Protoform / Thunder Power / Avid Bearings / A-main Hobbies / Dynamite
Scott Kimbrow is offline   Reply With Quote
Old 07-02-2011, 04:46 PM   #473
decibels's Avatar
i have a tc6 and my brother used some blades for his 411 and he went from changing a set a run to runnimg whole day and looking like the sand paper mark was still there with a 4.5 in the car. I alw habe 4.5 and habe done 3 race meets without killing any yet. Also very cheap
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 07-02-2011, 07:22 PM   #474
Hello Guys:
Probably this has bees asked before, but I can't find it. Can some one tell me what brand or spurs I can use?? I foudn that all Robinson or Hot bodies doesn't fit 3 hole system.
Edgar Millenium is offline   Reply With Quote
Old 07-02-2011, 08:26 PM   #475
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Thanks..Scott....
I put on 2mm chassis today it was okay...I was getting too much rear grip after two minute marks...it statred to drive like a dump truck...
I even changed the rear roll center to high and stiffer spings in the rear (yellow to orange) front red spring
Some how the car drive perfect for stock,but for mod it is lacking forward bite later in the middle of the run...could be the chassis is too thin?
OVA is offline   Reply With Quote
Old 07-02-2011, 08:29 PM   #476
OVA
OVA's Avatar
Originally Posted by Edgar Millenium View Post
Hello Guys:
used the Xray spur they fit better and you can tighten the motor screw thur the holes
Old 07-02-2011, 08:31 PM   #477
corallyman's Avatar
Hello Guys:
Hello,
I have a PRS TC spur on mine. I think Associated TC6 spurs will work and I also think the Xenon spurs that they made for the HB TCX should work.
Steve
Old 07-02-2011, 08:36 PM   #478
OVA
OVA's Avatar
Hello,
I have a PRS TC spur on mine. I think Associated TC6 spurs will work and I also think the Xenon spurs that they made for the HPI TCX should work.
Steve
hey steve ..there's something you have to watchout.. about the thin spur gear,the three screws are almost too long .it is going thur other side of the layshaft mid pulley...
Old 07-02-2011, 09:01 PM   #479
corallyman's Avatar
Yeah, I noticed that and went to a short screw, whenever I build a new car I locate my dremel if anything comes up and I need to shorten a screw or whatever.
Steve
Old 07-02-2011, 10:56 PM   #480
OVA
OVA's Avatar
Steve
Hey Steve
Hopefully you will have your ready in a few weeks....I could use some help ..we gotta get the serpent dialed at Fastrax
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
