Like Tree10Likes
Old 11-22-2012, 01:26 AM   #4696
miket3 I am using the kimbrough medium (reference 201) with no problems, and it's way cheaper than the xray one.
jimjav is offline   Reply With Quote
Old 11-22-2012, 07:03 AM   #4697
Trader Rating: 42 (100%+)
thanks.
miket3 is offline   Reply With Quote
Old 11-22-2012, 09:46 AM   #4698
gearhead_22's Avatar
Send a message via AIM to gearhead_22
the new serpent prepainted and precut race ready body
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 11-22-2012, 09:51 AM   #4699
after stickers
Juwan Hunter
Old 11-22-2012, 10:48 AM   #4700
BigRon's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to BigRon
What are you guys using for offset spacers? Also, I was on a carpet track yesterday that is med/high bite. I found myself fighting the car from traction rolling troughout the track. I'm running a 17.5 blinky box setup with black/grey (f/r) springs. I'm going back this weekend. Should I start off with Gary's Vegas (http://www.petitrc.com/reglages/serp...IIC2012100106/) setup, or is there a better one I should start with? Thanks
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 11-22-2012, 11:31 AM   #4701
BigRon's Avatar
Are you guys using standard or ceramic bearings throughout the drivetrain of the car?
*Serpent America*
Old 11-22-2012, 11:49 AM   #4702
Johnny Wishbone's Avatar
Hi Ron, you can use either the Tamiya spacers or the Xray spacers, if you use the Xray you will have to ream the holes slightly, the Tamiya will slip right on without mods. The wider stance will help with the grip roll issues, but also take note of your tire doping, how much, how long and what kind your using will help to cure some of the roll problem to. The Vegas setup is pretty good, although I'm still not sure what you'd really call the grip level of the carpet, but then again, we had some unusual Jack The Gripper that made for some strange goings on too.
Lots of people will try to make the car really soft to stop the grip roll problems. Martin even suggested to have the car so soft that it actaully would run on the chassis in the hard corners and skate across instead of digging in.
I would try the Vegas setup, but loose the anti-dive. If anything you could even go with bigger hex spacers, like 1mm in the front and .5mm in the back.
I use the standard bearings that come with the kit.
If its your own setup maybe post it then we could see if something else is causing the problem.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-22-2012, 05:09 PM   #4703
At what point of the turn are you traction rolling.... is it a quick roll right at corner entry or mid to late corner during full weight transfer? This can help determine many things in terms of where to go with adjustments. Also... interms of set-up. I found the kit set-up to be too aggressive on carpet. Try startining with Martin Crisps Canadian Champ set-up. The track was medium bite and with that set-up pretty easy to drive.
duckman996 is offline   Reply With Quote
Old 11-22-2012, 05:21 PM   #4704
Any chance you could share the weight of that body? I hate painting
Team Serpent
Steve S is offline   Reply With Quote
Old 11-22-2012, 07:05 PM   #4705
after stickers
Where can I find this body.
http://www.facebook.com/VancouverRRR
http://joshuasouthoaks.blogspot.com for blog, pictures and video of race events
fasteddie d is offline   Reply With Quote
Old 11-22-2012, 07:27 PM   #4706
Trader Rating: 38 (100%+)
I saw them at serpentamerica and amain. Mine from Amain is due to arrive Monday. I can post a weight when I get it.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 11-22-2012, 08:12 PM   #4707
I just go the body from a main and I will be racing it sat but am going for practice fri. so I will get the weight of it fri and post it.
Juwan Hunter
Old 11-23-2012, 09:17 AM   #4708
orcadigital's Avatar
Trader Rating: 61 (100%+)
Originally Posted by miket3 View Post
does anyone have a part number for the HD xray servo saver ? Or a recommendation for one that works good?
http://www.nexusracing.com/product_i...48e8fcc71d225c
37502 = Stiff
37503 = X-Stiff
By far my choice in servo savers. Reliable and durable.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 11-23-2012, 09:30 AM   #4709
Just an update.
Went to the track last night after the tracks GM finished Thanksgiving and the 2 of us ran laps late into the night with our TC's.
Track was cold, temp at the carpet around 61*. Running well used Sweep QTS 32's (36 batteries on them previous to last night). Front end felt like it had a little too much grip and was overworking the rear. I could induce traction roll with too violent of a steering correction, especially in the chicanes. Increased the spacers on the rear upper outer links from 1mm to 2mm and moved the front upper shock mounts to the 2nd hole from the outside. Car felt really good, but developed a bit of an on power push. One thing I have not tried yet is running a wider front front block and a narrower front rear (called arm sweep I think?). This would build toe out into the suspension geometry. I would still run 0.5* toe out on each side, but I am wondering how this might affect the on-power push? I might also drop the shocks back in a little, as the rear roll center changes might have been enough.
I am running 2* blocks front and rear on the front right now, and would probably do 2.5 front, 1.5 rear to try and maintain the front track, and then adjust from there.
I also broke both rear arms (2 seperate incidents) last Saturday. Replaced the hards with mediums (all I had left), and the car got slightly lazier in the rear, but actually felt a little more stable. I am definitely losing rear traction by the end of 6 minutes, and actually will sometimes get an almost uncontrollable snap out of the rear end when I get on the throttle too hard out of a 180*. Would thicker rear diff oil possibly help this? I am still running 100k front, 2k rear (have not sourced the thicker front oil yet).
Old 11-23-2012, 10:29 AM   #4710
I would have thought the opposite, but let us know what you find.
Team Serpent
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
