Old 11-05-2012, 08:43 AM   #4546
FaanP's Avatar
Originally Posted by TryHard View Post
For VBC, can go direct - http://www.vbcracing.com/ or to CRC in the US http://www.teamcrc.com/
HiH
Ed
Sorry ... not thinking straight to today .... ignore this post ...
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 11-05-2012, 08:51 AM   #4547
Akhor's Avatar
Originally Posted by FaanP View Post
I don't think the serpent spurs will fit when I install this diff - Am I right? Only X-Ray spurs?
Pretty sure this diff will not effect your spur selection. It's in a separate area of the car...
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 11-05-2012, 08:57 AM   #4548
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Originally Posted by RasCalDK View Post
As it is my setup I know it quiet well
As you can see, I'm not running a standard TE diff. I'm using 4 small Xceed plastic gears, instead of the 2 small metal gears. I assume that your diff is standard, which means you will need to use a thicker diff oil.
When running the standard diff, you will be looking at something around 2000 cst instead of the 1200 I used.
When you use to soft diff oil, you can get some strange behavior from the car. I have experienced that to soft oil, can make the rear step out coming into a corner, but not every time. I could go through corner 4 times, but the 5. time the rear would just slide without any warning.
I'm glad that I can see people using my setups, and liking them, really makes me wanna help and keep on posting setups
Well insted of cracking the diff open I changed the camber to -2 rear, -1 front. Layed the rear shocks down a tad more and reduced my d/r on my radio. And Bingo! seem to solve my stepping out in the rear at corner exit. I always have to try the simple stuff first. Car is awesome. And is it me or am I the only one running a 3.54FDR with 17.5 Blinky? Everyone else says to stick around 4.0fdr+. My temps are within reason and it's a carpet track around 90ftx40ft I believe. Does that seem too far fetched?
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 11-05-2012, 08:59 AM   #4549
FaanP's Avatar
Yeah .... as I said in the reason for my post edit - I'm an idiot ... blue Monday I guess
Old 11-05-2012, 09:54 AM   #4550
Johnny Wishbone's Avatar
Originally Posted by TJames987 View Post
Hey ya’all I was wondering if s411 owners opinions on the Team Edition versus the original s411 I have?
Anyone using the Derlin driveshaft adapters for front spool, what is its purpose?
I have the “soft” rear A-arms, are most people upgrading them to “medium” or “hard” parts?
Thanks. ya'all. This car was the only one that made the a-main this weekend at my local carpet track the rest were T4 XRAYS
Both are great cars, I pretty much run a combination of both cars as there are great tuning options between them all.
The Delrin adapter is a much lighter version of the aluminum spool, it seems to have very good durability, haven't broke one yet. It just lightens the car and the rotational mass.
Most go to the "Hard" parts, makes the car feel more predictable.
Great results.
Originally Posted by Cestaric View Post
Thanks Lock,
this diff would be a direct change on my S411TE ?
Just take to Stock diff off and use this one from CRC ?
Cestaric
I think you have to change out the pin cushions and the axles as well. Check back for Tryhards post a few pages back, he gives a list of the parts needed to change over.
It really depends on what motor you run and what combination of parts you're using in the motor, and what timing you run on the motor. I wouldn't worry so much about what others run, but what makes you fast. I find with the combination of parts I run, that my FDR is never close to what the others are running.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-05-2012, 10:36 AM   #4551
RasCalDK's Avatar
Good to hear, glad that you got the car sorted out
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 11-05-2012, 06:05 PM   #4552
Originally Posted by Johnny Wishbone View Post
I had a pretty good weekend at the first WCIC series race, the report and setups should be posted in the next couple days.....I'll post the link when its up.
Here it is.
http://www.petitrc.com/reglages/serp...CIC2012102627/
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-06-2012, 04:55 AM   #4553
crabboy's Avatar
Trader Rating: 58 (98%+)
I have used the Delrin spool outdrives a few times and they break after about one run with a 4.5 mod car, we use hard arm front and rear, they seem to work good.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-06-2012, 05:41 AM   #4554
Toughbeard's Avatar
Rhys
will be fine for stock racing. but currently people use the delrin spool from the sport....
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 11-06-2012, 02:03 PM   #4555
Rhys
Thats my bad......completely forgot about the delrin outdrives, which don't last very long, but the delrin spool is very durable. Sorry.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-06-2012, 08:47 PM   #4556
TryHard's Avatar
In stock the nylon spool is probably ok, but after five runs in mod, there is noticeable notching going on in the outdrives (fair enough after a couple of grassy momemts). Does seem to give a bit more steering, but that to be expected given its just under half the weight of the stock spool (14g vs 8g).
Ed
Old 11-06-2012, 11:32 PM   #4557
Benzaah's Avatar
Trader Rating: 21 (96%+)
I have about 60 runs on a nylon spool in 17.5 boosted and i reckon its due for a change.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 11-07-2012, 04:17 AM   #4558
BigRon's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to BigRon
Will any other brand servo lever work on this car?
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 11-07-2012, 04:26 AM   #4559
Toughbeard's Avatar
http://www.evilhobbyshop.com/Steerin...u,PR-1488.html
but others should work no problem. just make sure the lenght is correct. or the tierod will hit the upper deck..
Serdar Aytemiz
Old 11-07-2012, 07:57 AM   #4560
orcadigital's Avatar
Trader Rating: 61 (100%+)
Ran the S411 this past weekend at the GORC (Georgia On Road Championship), a regional race at our local track. Thursday practice had me running 10.5 with the fast guys around 10.0.
Changed camber from 1.5/2.0 to 1.5 all around, softened the entire car, lowered the rear roll centers and the car got very mellow and easier to drive. I had switched to a front diff with 100k in it, and am really liking the feel, even though I know it is costing me a couple tenths. It is a lot more consistent and easy to drive which leads to better qualifiers if not faster laps. Started on Sweep QTS 32's and switched to Jaco Blues (both were spec tire options) on Friday as traction came up and the jacos were more consitent through the 6 min. With 10+ hours of practice friday, got the car down to a 10.0 with the fast guys hitting 9.7's. I also changed the springs from Serpent to RSD (I have the RSD on my VTA) and the car felt better in the chicanes (the weight transfer left to right felt less abrubt and the car felt more planted).
Saturday morning, rebuilt the shocks (with same 35wt oil), cleaned carpet bits out of the diff pullies and went back to work. Hit a 9.9 in controlled practice before the qualifiers started. We did qual points (which still confuses me) but had 3 decent qualifiers (with resorts was running in the "b-main" quals) and qualified 7th overall in the A-Main. There was a little knocking around at the beginning, and I got into 4th in the first lap. The first 3 cars included 2 sponsored drivers and one previously sponsored driver running a TC6.1, Xray T4 and Tamiya 417. One of our fastest drivers (who was TQ until the last qualifier) in his T3 2012 caught me about half way through and I held on to 5th for the remainder of the main, a lap down from the leaders.
Will try a spool sometime soon, as I stil have gobs of steering and when traction comes up, the back end becomes a little looser then I like. I was down to treating only the inner half of the front tires with SXT, and full rears.
It seems a little odd, while trying to dial the car in, I ended up removing all of the shims under the rear hinge pin blocks, and running more on the front (+1.5mm under both fronts). My understanding is this is raising the roll center in the front (removing front traction) while lowering it in the rear (and adding traction). It seems extreme to me though. Any thoughts?
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
