Old 06-27-2011, 05:12 PM   #436
Originally Posted by Mark Stiles View Post
Hello all,
Chris Kerswell and I both ran our S411's for the first time yesterday. Like you we found that going to heavier diff oil transformed the car. We got as far as 2000, but nobody had anything heavier at the track and we didn't have the parts to try 4 bevel gears. We are thinking along exactly the same lines as you.We're not sure that 2 gears with 2000 is equivalent to 4 gears with 1000, but we're pretty sure a 4 gear setup will result in a more viscous diff.
We think the kit chassis is a bit stiff so will be trying the 2mm and 2.25mm versions when we get them through. The wishbones also seem awfully soft; Chris has some stiffer ones coming to try.
The wheelbase is quite short; the current British champions Schumacher is 6mm longer than our car with a kit setup! We went 3mm longer on the rear wheelbase yesterday.
We agree on the springs, and feel that the front is too hard as well. Chris ran Hara greys and I started on hara blacks.
The driveshaft blades are very soft! In mod with a 4 turn motor they were lasting less than 2 runs. Harder ones are on the way but until then we've modified TC6 ones to fit and they seem fine.
Overall we have been very impressed with the quality of the car, but we have some work to do on setups to get it to a competitive level. This will be our testing target in the next couple of weeks.
Like reading my mind....
I have played with flex a fair bit in the past and recentl and find more flex = slow lap times. I find that things like softer arms combined with a stiff chassis will give you a better platfom for ease of driving vs pace. I would be interested to hear your thoughts when you try different parts but for now I am looking to get the car smooth so I can make maximum use of its mamoth grip.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 06-27-2011, 05:24 PM   #437
venom54's Avatar
Default S411 Parts
Originally Posted by Jamison R View Post
I am going to ROAR nats in late July. Im gonna need front and rear arms, steering knuckles, C-Hubs(4 degree), rear uprights, steering bushings, belts, and ball cups. Also the bigger inner bearing for axle's.
Just follow the link below to the S411 spares page. All the above items in stock as of 10.09AM AEST Aus.
http://www.rabhobbies.com.au/estore/...p/cPath/62_397
As for the 12x6x4 bearings we have sold out but are receiving more in about 3 days.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
venom54 is offline   Reply With Quote
Old 06-27-2011, 08:34 PM   #438
rcaddict13's Avatar
Trader Rating: 67 (100%+)
Well we had a club race at ripon speedway and scott kimbrow had his serpent s411 up and runing and with just a few minor roll center adjustments the car looked dialed !!! He set fast lap and tq in the 3rd round and broke them both in the main with a perfect run. He said the car was so easy to drive and thinks that with a few more run's on the car it will get faster !!
Xray t4 17 >< top sabre s4 >< ripon r/c raceway >< Gensace >< R1 wurks >< Protoform >< Motiv >< Gravity R/C >< Sanwa m12
rcaddict13 is offline   Reply With Quote
Old 06-27-2011, 08:38 PM   #439
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
I forgot all about Scott join the Sperpent Team...
Here is report from Scott K.
You know the old saying, "you never get a second chance to make a first impression"...... well let me tell you, the Serpent S411 made a big first impression!
I got the car on Thursday, and wanted to go run it on Saturday night at Ripon Speedway but wasn't sure I could get the car built and ready to run that quickly. The car was an awesome build. every part had a perfect finish, no reaming or dremeling anything! It went together so quickly and easily, I even had time to paint 2 bodies on Saturday before heading to the track!
I headed down to Ripon Speedway hoping to shake the car down, work the bugs out, and start getting it up to speed. I was in for a very pleasant surprise.
Right off the trailer, the car felt really good with just the default setup (included in the kit). I ran a few practice runs and the car shook out real nice. I made only a few minor adjustments (see attached setup sheet) and the car was dialed! Using Thunder Power batteries and 4.5 motor, along with the Protoform P37 body, I couldn't believe how good the car felt. Tons of steering but still very easy to drive. I let several people drive the car and they all had the same response....WOW.
I went on to TQ and win the main..... a very nice first impression indeed. Ripon is a small and very technical track, and the S411 was very comfortable on that track. I am looking forward to getting the car out to some other local tracks and see how the car responds on the bigger tracks as well...... stay tuned!
Scott Kimbrow
Team Serpent America
OVA is offline   Reply With Quote
Old 06-27-2011, 09:25 PM   #440
OVA
OVA's Avatar
Scott TQ and wins 1st race with Serpent 411 .....good job scott
here is Scott set up sheet
Old 06-27-2011, 09:27 PM   #441
Jochim_18's Avatar
Who will be the parts dealer here in US?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-27-2011, 09:34 PM   #442
Scott Kimbrow's Avatar
Originally Posted by OVA View Post
I forgot all about Scott join the Sperpent Team... good news he getting better..keep us posted
what part did he break?
Hello! And thank you for reposting my setup. Been a looong day and was hoping to get it posted here before the end of the night.
My car was actually great and I did not break a single part. Even my rear blades held up to 10 mod runs. I was quite impressed with the car for the first time on track and will work on some changes next time to see how the car responds.
Serpent / Serpent America / Novarossi / Spektrum / Xceed Tires / Tornado Fuel / Empire Racing / Protoform / Thunder Power / Avid Bearings / A-main Hobbies / Dynamite
Scott Kimbrow is offline   Reply With Quote
Old 06-27-2011, 09:38 PM   #443
A full supply of spare parts should be en route to Serpent America now. We at Empire Racing will stock parts and be able to get parts to support the car. I plan to run it as much as time allows with my nitro schedule. If you need anything or have questions you can feel free to contact me at [email protected]
Old 06-27-2011, 09:57 PM   #444
Team Pink's Avatar
Trader Rating: 20 (100%+)
Yea his car was dialed. It was really fun to race with him in mod. His car looked to have a ton of steering and super stable. Hopefully next time I can give him a little more of challenge. All in all it was fun and the S411 looks to be a sweet. Caught my eye that is for sure.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 06-28-2011, 04:35 AM   #445
jensen123's Avatar
Originally Posted by JayBee View Post
I should be getting 2 of the 3 orders I've placed with RCMARKET this week. My experience has been fine thus far.
Agree x 2. So far so good for me!
jensen123 is offline   Reply With Quote
Old 06-28-2011, 04:36 AM   #446
jensen123's Avatar
Thumbs up
Good news again, great!
Old 06-28-2011, 05:08 AM   #447
Trader Rating: 55 (100%+)
Where is empire located? Is there a webstore?
Jamison R is offline   Reply With Quote
Old 06-28-2011, 05:09 AM   #448
anyone?
Old 06-28-2011, 05:59 AM   #449
Rogier's Avatar
@ RC Market; why selling the S411 for $449 while RCModel has got them for $389?? Huge difference...
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 06-28-2011, 07:45 AM   #450
Akhor's Avatar
Where can we order those specR blades? I can not find them on A-Main or hobbypartz...
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
