Old 10-22-2012, 09:02 AM   #4441
Geberit's Avatar
Originally Posted by BAD007SUZUKI View Post
By v2, you mean a 1piece motor mount? Does the top deck rub on the layshaft gear at all upon it flexing?
I have a spare roller Im selling on here, but I may keep it and try this mod. Is there a reason one side of the part is cut slightly higher?
Yes I use a one peace motor mount. The bearing holders are grind a little bit on the top so when the chassis flexes the top deck doesn't touch the holders. The parts are cut like this to prevent touching and by this limiting the flex at the back. Before that I was using shims under the top deck like Tryhard suggested and I liked it very much. Now I realized I'm running without the screws all the time so why not to try it this way.
Geberit is offline   Reply With Quote
Old 10-22-2012, 10:17 AM   #4442
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Is anyone running the antenna in a differant place? Pulling the top plate off is a pain in the butt with the tube being mounted where the instructions tell you to put it.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 10-22-2012, 01:00 PM   #4443
Johnny Wishbone's Avatar
Originally Posted by cwoods34 View Post
Also, has anyone ran the front toe blocks up 1mm and the rears on the chassis? The car wanted to continue rotating late corner exit.... although most other cars behaved the same. It was hard to tell if the back needed more roll or "stiffened" up to create more lateral/side bite.
I read somewhere where this is not desirable and has a very good explination why........but I can't remember where or why......but it was convincing enough to me that it shouldn't be used........I have to find it.
Originally Posted by Holmenkollen View Post
How do you guys get the car below 6 mm if youīre using the inner shock hole on the rear arm?
I generally run at 5.5mm but it usually means I'm only about 3 or 4 turns down from the top.
Originally Posted by VexVegaz View Post
does anyone know if the xray t3 ecs/djc will fit the 411?
thanks!
They would fit but you would have to change the spool or Diff as well because the ball end of the ecs is larger on the Xray parts. You would also have to change the inner bearing in the steering hubs as the Serpents use two different sizes and the Xray is one size all the way thru.
No, as the antenna mount is also used as a battery stop. Yes it is a pain.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-22-2012, 01:08 PM   #4444
BAD007SUZUKI's Avatar
Trader Rating: 96 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default i see
i think im gonna have mine milled. that way if i want to put the screws in i can shim it 2.5mm and use it as intended. i like the idea a lot though.
BAD007SUZUKI is offline   Reply With Quote
Old 10-22-2012, 01:11 PM   #4445
I am. I also use the Tamiya mounting hardware (blue ballstuds) so the shock is spaced away from the mounts a bit. They work great!
Being shorter, they also work great for trying the inner arm mounts and still getting proper ride height and uptravel.
Thanks. I think I will try them.
Nitroblood is offline   Reply With Quote
Old 10-22-2012, 01:19 PM   #4446
The colored Tamiya spring kit # 53440. Is this the common good choice of tuning springs that some people here are talking about? My LHS has this and wanted to make sure before I get it.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 10-22-2012, 01:27 PM   #4447
I try to stay with the stock Serpent springs as much as possible, just for ease of setup information, but, I also bought a set of the Tamiya spring kit, not sure about the part number, but the springs I ended up with where almost too short, had to have the collars way down the shock just to get ride height. All I can suggest is make sure that stack height is close to the stock Serpent spring, then you should be good. As far as the set itself for strength, I think they would be a pretty good substitute for the stock items, a good range even for just 4 springs.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-22-2012, 01:49 PM   #4448
Thank you J.W. ;-) I want to favor the actual Serpent parts also. I just saw people talking about Tamiya springs and then I decided to open up the set up sheets off the serpent site. And one for sure I saw said they were using the "Tamiya white and blue springs" I'll try to look at them more closely in person and see whats' up.
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Old 10-22-2012, 04:00 PM   #4449
TryHard's Avatar
If you talking carpet, the tamiya white and blue combo is a defacto setup that a lot of teams use, that and the Yokomo pink/blue.
Most of the tamiya team have run those on carpet since the original 415... So about 8years ago!
HiH
Ed
Old 10-22-2012, 11:10 PM   #4450
Holmenkollen's Avatar
HiH
Ed
Interesting that they use the same combo despite the cars being 150g lighter nowadays.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-23-2012, 12:49 AM   #4451
RasCalDK's Avatar
On carpet I'm always using Tamiya white and blue in comparison to the Serpent springs, they make the car feel easier and nicer to drive.
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 10-23-2012, 10:15 AM   #4452
I used last race (callīs NRW FUN Cup) Serpent Black and Gray Springs ! The Car was very Easy to drive and have very good Steering ! With my setup i drive a new Lap Reckord on this track .Itīs neer to the ETS Setup by David .
My setup file is to big Sorry ,any idea ??
Der_Mo is offline   Reply With Quote
Old 10-23-2012, 12:02 PM   #4453
orcadigital's Avatar
Trader Rating: 61 (100%+)
Originally Posted by CNTRFLD View Post
Hi guys! Sorry I started reading into this long thread and I got lost lol. I figured I would go ahead and just ask away...
Can someone please tell me the differences between the TE and the LE? I'm thinking about going all Serpent so, i'll need to pick up a new TC for this year. Isn't the TE a newer version correct? I know they only made 300 LE kits... anyone?
Thanks again guys.
Only thing not mentioned is chassis thickness. The LE's were 2.25, while the original V1's were 2.5 (? as I recall). I am not sure what the TE's have. I already have the V2 steering and motor mounts on my LE's, but am happy with the V1 shocks and diffs. The LE also comes with 2 diffs and a spool.
I personally love the orange, but that is just me.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 10-23-2012, 12:03 PM   #4454
The only thing thats worked for me in posting setups on here, is to get them onto the Petit RC site and then do a link on here to take you over there.
The Tamiya springs I bought where the right colours, but I think they may have been for another car not a TC, bad part is the use the same colours for all their springs. But the tried and true blue and white seems to be a pretty good combo, even after all these years.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-23-2012, 12:05 PM   #4455
I have had good luck with the serpent springs, but actually prefer the RSD springs. They seem to come in more inbetween weights, fit great, and feel very consistent. I have full sets of both (2+ pairs in most cases as well) along with a set of HPI and Xray springs. My custom pit board has the relative weights of all of those springs so it is easier to compare. No one else is running an S411 at my track anymore, so when the Xray guy next to me says he changed his 3.0's to 2.8's, I can reference how to accomplish it in other brands, or even run the same springs. It just gives me the options to try whatever I want.
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
